    MMM-SimpleBGSlideshow (yet another background slideshow module)
    28 Posts 5 Posters 13.5k Views 6 Watching
      MagicInMe
      I remade most of Darick Carpenter’s BackgroundSlideshow because the original was crashing my magic mirror with synchronous file system calls. This one has far fewer options, but has no dependencies and should be easier to implement and use.
      Installation
      There are no dependencies or node-modules required for this module. To install, run the following commands:
      cd ~/MagicMirror/modules/
      git clone https://github.com/scottdrichards/MMM-SimpleBGSlideshow
      Usage
      You can add the following to your main configuration file:
          module: 'MMM-SimpleBGSlideshow',
          position: 'fullscreen_below',
              imagePaths: ['images/'],
              slideshowSpeed: 15000,
              randomizeImageOrder: false,
      Configuration
      Parameter Usage Example
      imagePaths An array of paths for images to be taken from ["images","oldImages"]
      slideshowSpeed Number of milliseconds to show each image 10000
      sortImagesBy Sort the images by name, random, created (file creation, not image date taken), or modified created
      sortImagesDescending Sort the images in descending order true
      randomizeImageOrder Randomize the order to show images. Each image will still be shown once per rotation false
      recursiveSubDirectories Include subdirectories of image paths? false
      validImageFileExtensions Which image extensions to include. Make sure to only do extensions that the browser can render. "bmp,jpg,jpeg,gif,png"
      brightenText Brightens the all MagicMirror text for easier viewing true
      gradient An object that describes the gradient to be applied so that text/modules are easier to read. see below
      Here is how to configure the gradient object
        direction: "linear", //vertical, horizontal, radial`
        opacity: 0.75, // 1 is black
        stop1: "40%", // linear first stop, radial start gradient
        stop2: "80%" // linear second start, radial end gradient (i.e., 120%)
      See the project here: https://github.com/scottdrichards/MMM-SimpleBGSlideshow/
        sdetweil @MagicInMe
        @magicinme all of THESE from node helper are dependencies
        const express = require("express");
        const Log = require("../../js/logger.js");
        const FSPromises = require("fs/promises");
        const pathModule = require("path");
        and should be listed in the package.json, IN CASE one of them were to go away
        as has happened in 2.15 and 2.16 with removal of request and associated packages
        and ical and its co dependencies…
          MagicInMe @sdetweil
          @sdetweil how would package.json have a listed dependency for fs and path (included in Node) or MagicMirror’s logger? I suppose express is a dependency I could maintain independently, but I rely upon the MM expressInstance.
            sdetweil @MagicInMe
            @magicinme do npm install --save in your module folder for those dependencies.
            then let npm install for your module figure out where to resolve them
            u might depend on the mm expess server INSTANCE but not the code to talk to that instance
              MagicInMe @sdetweil
              @sdetweil what’s the purpose of installing core node features as a module? Looking at npm path it says "This is an exact copy of the NodeJS ’path’ module published to the NPM registry. "
              Good point on express, I had thought I was just calling the express object but I do use express.static
                sdetweil @MagicInMe
                @magicinme you may not ‘install’ it, as npm will resolve , but you document that you USE it, SO, if things change, you stuff still works…
                I don’t know where stuff is packaged, and don’t want to know
                  MagicInMe @sdetweil
                  @sdetweil perhaps this is why https://www.npmjs.com/package/fs gets a million downloads a week even though it does nothing. I believe including core modules in package.json presents an unnecessary security risk (i.e., npm path is controlled by an individual). Unless there’s a way to include a package in package.json as a comment?
                    sdetweil @MagicInMe
                    @magicinme no comments in json.
                    whatever… I have given everything I know and my advice on helping insure users don’t encounter problems.
                    the high download counts are from build systems recreating the env from scratch…
                    not users
                      robertybob
                      Does this module stretch images to fit the mirror? The original module had two different options for this, if I recall correctly
                        MagicInMe @robertybob
                        @robertybob I currently have it so that it uses the css “cover” attribute which stretches to fill. Is that what you want?
                          rs
                          Hi MagicInMe,
                          Thank you for sharing your work!
                          I’ve installed MMM-SimpleBGSlideshow but for some reason the background stays black, I double-checked the images in the correct folder and i use the full path in the config as well:
                          				imagePaths: ['/home/pi/MagicMirror/modules/MMM-SimpleBGSlideshow/images'],
                          alt text
                          but… no joy…
                          I clearly missing something basic here :)
                          I appreciate any thought!
                          Best,
                          Ram
                            sdetweil @rs
                            @rs said in MMM-SimpleBGSlideshow (yet another background slideshow module):
                            the code says
                            imagePaths: [], // resolves relative to MM root. So ‘images’ => ~/MagicMirror/images
                            so, you cannot use the full absolute path
                            the folder MUST be in the MM folder tree…
                            like this, in your case
                            you could use a linked folder to access outside the MM folder tree
                            (I do this for my server shared images path for the MMM-ImagesPhotos module)
                            see the ln command
                              rs
                              @sdetweil, many thanks for pointing me to the right direction, the working path was:
                              modules/MMM-SimpleBGSlideshow/images/
                              Thanks again!
                              Cheers,
                              RS
                                rs
                                now that i have it working I have one more question:
                                while the mirror runs, the content of the images folder changes from time to time; looking at the console output, the module capture the changes in the files, for example, adding and removing files from the images folder:
                                [23.09.2021 12:20.44.712] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow: + 1 images
                                [23.09.2021 12:20.54.765] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow: + 1 images
                                [23.09.2021 12:20.56.258] [ERROR] ENOENT: no such file or directory, stat 'modules/MMM-SimpleBGSlideshow/images/black.jpg'
                                [23.09.2021 12:20.56.761] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow:  - 1 images
                                [23.09.2021 12:21.05.666] [ERROR] ENOENT: no such file or directory, stat 'modules/MMM-SimpleBGSlideshow/images/MirrorMsg.png'
                                [23.09.2021 12:21.06.169] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow:  - 1 images
                                [23.09.2021 12:21.08.725] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow: + 1 images
                                [23.09.2021 12:21.34.396] [ERROR] ENOENT: no such file or directory, stat 'modules/MMM-SimpleBGSlideshow/images/MirrorMsg.png'
                                [23.09.2021 12:21.34.900] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow:  - 1 images
                                [23.09.2021 12:21.45.058] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow: + 1 images
                                [23.09.2021 12:22.09.272] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow: + 1 images
                                [23.09.2021 12:22.28.684] [ERROR] ENOENT: no such file or directory, stat 'modules/MMM-SimpleBGSlideshow/images/MirrorMsg.png'
                                [23.09.2021 12:22.29.191] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow:  - 1 images
                                [23.09.2021 12:22.31.327] [ERROR] ENOENT: no such file or directory, stat 'modules/MMM-SimpleBGSlideshow/images/MirrorMsg2.png'
                                [23.09.2021 12:22.31.828] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow:  - 1 images
                                [23.09.2021 12:22.35.920] [INFO]  BGSS Sending update to 4690_module_0_MMM-SimpleBGSlideshow: + 1 images
                                However, the image shown on the mirror doesn’t change and stays the same (slideshowSpeed: 5000); is there a way to force the module to refresh itself without stopping the mirror?
                                Thx again!
                                S R 2 Replies Last reply Reply Quote 0
                                  sdetweil @rs
                                  @rs hm… the enoent means file not found
                                  and it doesn’t use the full path… weird…
                                  I don’t use that module myself.
                                    rs @rs
                                    @sdetweil said in MMM-SimpleBGSlideshow (yet another background slideshow module):
                                    it is what it is then :)
                                    Thx anyways!
                                      sdetweil @rs
                                      @rs I use this one,
                                      https://github.com/sdetweil/MMM-ImagesPhotos
                                      modified from original
                                      I don’t like my photos stretched etc…
                                      also has color or blur fill around pic
                                      uses only ONE source, ‘uploads’ folder in the module folder… I just symlink to another (my mounted server share) using the ln command
                                      R R 2 Replies Last reply Reply Quote 0
                                        rs @sdetweil
                                        @sdetweil, agree, this is the one i finally use, it updates the shown photos when the folder content changes, good enough for my current needs!
                                        Cheers,
                                        RS
                                          sdetweil @rs
                                          @rs i also have a module that shows a qr code and lets users upload pics from their phone (to the images location)…
                                          see
                                          https://github.com/sdetweil/uploadPics
                                            robertybob @sdetweil
                                            @sdetweil I’ve just tried out this module and the Readme on your github needs editing to point the installation link (git clone) to your one, rather than the original Github link :) Also, could you update the example in the Readme to detail exactly how to correctly size images? e.g.
                                            For percentage:
                                            maxWidth:"50%",
                                            or for pixel dimensions:
                                            maxWidth:"50",
                                            For novices like myself, it isn’t very clear :)
                                            I can’t for the life of me get the module to respect the sizes that I specify, it’s always too big, goes off the screen and isn’t central (despite me not changing the default position)
                                            	module: "MMM-ImagesPhotos",
                                            	position: "middle_center",
                                            		opacity: 0.9,
                                            		animationSpeed: 500,
                                            		updateInterval: 11000,
                                            		maxWidth:"50%",
                                            		maxHeight:"70%",
                                            		backgroundColor: 'grey',  // not used if fill is true
                                            		fill: true,   // fill around image with blurred copy of image
                                            		blur: 10,   // only used if fill is true
