    MMM-SimpleBGSlideshow (yet another background slideshow module)
    28 Posts 5 Posters 13.2k Views 6 Watching
      sdetweil @MagicInMe
      @magicinme do npm install --save in your module folder for those dependencies.
      then let npm install for your module figure out where to resolve them
      u might depend on the mm expess server INSTANCE but not the code to talk to that instance
        MagicInMe @sdetweil
        @sdetweil what’s the purpose of installing core node features as a module? Looking at npm path it says "This is an exact copy of the NodeJS ’path’ module published to the NPM registry. "
        Good point on express, I had thought I was just calling the express object but I do use express.static
          sdetweil @MagicInMe
          @magicinme you may not ‘install’ it, as npm will resolve , but you document that you USE it, SO, if things change, you stuff still works…
          I don’t know where stuff is packaged, and don’t want to know
            MagicInMe @sdetweil
            @sdetweil perhaps this is why https://www.npmjs.com/package/fs gets a million downloads a week even though it does nothing. I believe including core modules in package.json presents an unnecessary security risk (i.e., npm path is controlled by an individual). Unless there’s a way to include a package in package.json as a comment?
              sdetweil @MagicInMe
              @magicinme no comments in json.
              whatever… I have given everything I know and my advice on helping insure users don’t encounter problems.
              the high download counts are from build systems recreating the env from scratch…
              not users
                robertybob
                Does this module stretch images to fit the mirror? The original module had two different options for this, if I recall correctly
                  MagicInMe @robertybob
                  @robertybob I currently have it so that it uses the css “cover” attribute which stretches to fill. Is that what you want?
                    rs
                    Hi MagicInMe,
                    Thank you for sharing your work!
                    I’ve installed MMM-SimpleBGSlideshow but for some reason the background stays black, I double-checked the images in the correct folder and i use the full path in the config as well:
                    			module: 'MMM-SimpleBGSlideshow',
                    			position: 'fullscreen_below',
                    				imagePaths: ['/home/pi/MagicMirror/modules/MMM-SimpleBGSlideshow/images'],
                    				slideshowSpeed: 15000,
                    				randomizeImageOrder: false,
                    alt text
                    but… no joy…
                    I clearly missing something basic here :)
                    I appreciate any thought!
                    Best,
                    Ram
                      sdetweil @rs
                      @rs said in MMM-SimpleBGSlideshow (yet another background slideshow module):
                      the code says
                      imagePaths: [], // resolves relative to MM root. So ‘images’ => ~/MagicMirror/images
                      so, you cannot use the full absolute path
                      the folder MUST be in the MM folder tree…
                      like this, in your case
                      you could use a linked folder to access outside the MM folder tree
                      (I do this for my server shared images path for the MMM-ImagesPhotos module)
                      see the ln command
                        rs
                        @sdetweil, many thanks for pointing me to the right direction, the working path was:
                        modules/MMM-SimpleBGSlideshow/images/
                        Thanks again!
                        Cheers,
                        RS
