    face recognizes display ON/OFF
    9 Posts 5 Posters 2.5k Views 5 Watching
      DJBOOB66
      hi I have been looking now for a few hours for a guide on how to get my face recognizes to turn my magic mirror display on when it recognizes my face can it be done and how thanks.
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @DJBOOB66
        @djboob66 look at the Pir modules
        there are 4 different commands
        tvservice - pi only turn off/on hdmi
        vcgencmd - turn off/on hdmi
        dpms - turn off/on hdmi
        cec-client - turn off/on monitor
        the 1st 3 will leave monitor on, and monitor may show a big ‘no signal/input’ screen for up to 15 minutes before powering off, this is energy star compliance
        none of the commands that turn off hdmi can turn on the monitor after it powers off
        I have two cec tvs, but one will turn off, but not back on, and other will turn on, but not off
        soooooo. I use a hide/show all modules process
          DJBOOB66
          I want a more securer way so My work Calander is not visible for other users this is why I’m going down the Face recognition .
          GAv3 can turn the screen ON OFF but anyone how to know the command can do so.
            sdetweil @DJBOOB66
            @djboob66 look at his code, he uses the same commands
              suvan @DJBOOB66
              @djboob66 Hey, have you found any code yet? I’m looking for the same thing as well. Really need help with this.
                sdetweil @suvan
                @suvan looking for what?
                  as I said before, look at the GA code that does this… its the same 4 commands as always
                  https://github.com/bugsounet/screen/blob/master/index.js
                  and
                   async setPowerDisplay (set) {
                      log("Display " + (set ? "ON." : "OFF."))
                      this.screen.power = set
                      this.SendScreenPowerState()
                      if (this.screen.awaitBeforeTurnOff && !set) await this.sleep(this.screen.awaitBeforeTurnOffTime)
                      // and finally apply rules !
                      switch (this.config.mode) {
                        case 1:
                          if (set) exec("/usr/bin/vcgencmd display_power 1")
                          else exec("/usr/bin/vcgencmd display_power 0")
                          break
                        case 2:
                          if (set) exec("DISPLAY=:0 xset dpms force on")
                          else exec("DISPLAY=:0 xset dpms force off")
                          break
                        case 3:
                          if (set) exec("tvservice -p && sudo chvt 6 && sudo chvt 7")
                          else exec("tvservice -o")
                          break
                        case 4:
                          if (set) exec("echo 'on 0' | cec-client -s")
                          else exec("echo 'standby 0' | cec-client -s")
                          break
                        case 5:
                          if (set) exec("xset dpms force on")
                          else exec("xset dpms force off")
                          break
                  you should try each command to see what the results are
                  do this from and ssh connection to your pi, so you don’t have to fight getting the screen back on to work…
                  note that most of these turn off the HDMI port, and NOT the actual monitor.
                  many newer displays (since 2016) are energy star compliant and will display an upgly no input signal when the hdmi port is turned off… no way to override that
                  (and these displays will NOT turn back on when the hdmi port is turned back on)
                  ps… none of my displays will work with any of these commands
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @sdetweil
                    @sdetweil on the PI3… I just got mine working again this is the commands that work:
                    ON:
                    #! /bin/bash
                    sudo vcgencmd display_power 1
                    OFF:
                    #! /bin/bash
                    sudo vcgencmd display_power 0
                      sdetweil @cowboysdude
                      @cowboysdude cool. what monitor is that with?
