    birthday list Implementation
    Scheduled Pinned Locked Moved Forum
    calendar
    6 Posts 3 Posters 2.1k Views 3 Watching
    • veldjeV Offline
      veldje
      My Raspberry Pi 4 with 24" monitor has a working default calendar, synchronized with my Google calendar. I would also like to have a birthday calendar, or the ability to display birthdays.
      I downloaded the birthday list module (https://github.com/sdetweil/birthdaylist)
      and installed. Also made a csv file with my own data.
      I don’t know what else needs to be done to get the birthday calendar, or anything like that, working. Is there a manual or step-by-step plan to consult? Thanks in advance for the help.
      S lavolp3L 2 Replies Last reply Reply Quote 0
        sdetweil @veldje
        @veldje tell me more…
        also have to do an npm install
        its a 2 column csv, but you cannot set the name, you MUST use data/bdl.csv
        date, name
        and in config.js
             module: "birthdaylist",
             position: "somewhere",
        veldjeV 1 Reply Last reply Reply Quote 0
        • lavolp3L Offline
          lavolp3 Module Developer @veldje
          @veldje I have solved this by including a “birthday” calendar from google and giving at an own symbol.
          For that I have created an own calendar within google, transferred all birthdays to that (didn’t take long) and included that calendar into the config.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • veldjeV Offline
            veldje @sdetweil
            @sdetweil Thanks for the quick response. Reinstalled now and it works.
            But I have a follow-up question about the bdl.csv:
            The layout of the text is now upper- or lowercase.
            Is it possible to display the text as (the layout) in the file bdl.scv, for example: “Bep van 't Veld-Pijpers”?
            If so, where should what be adjusted?
              sdetweil @veldje
              @veldje the uppercase is done in the css
              transform(uppercase)
              • veldjeV Offline
                veldje @sdetweil
                @sdetweil I placed in the folder: custom.css
                .birthdaylist .TD-BODY {
                font size: 18px;
                text transform: none;
                and the text layout conformed to that in bdl.scv
                Dissolved. Thanks for the suggestions
