    Homeassistant und Magic Mirror problem whith MQTT character string help
    10 Posts 3 Posters 2.1k Views 4 Watching
      droncho @MaXi-XCeL
      @MaXi-XCeL thx…I am editing the module again to see if I can find the key to everything, I write again when I have the solution … Greetings and thanks. :)
        droncho
        Solved !! YUHUU!!!
        Thaks to bertdeelman (creator from this Module: MMM-MQTTfloorplan) its working !!!
        link: https://github.com/DMailMan/MMM-MQTTfloorplan
        in config.js
        topic: ‘tele/espejo1/SENSOR’, // MQTT Topic name
        label: ‘Temperature’, // Not displayed anywhere, but handy for you to know what you’re doing !
        type: ‘label’,
        jsonpointer: ‘/DHT11/Temperature’,
        display: { left: 265, top: 90, prefix: “”, suffix: “°C”, decimals: 1 },
        Modification in module MMM-MQTTfloorplan.js
        123 this.updateDivForItem(
        124 i,
        125 value,
        126 config);
          MaXi-XCeL Project Sponsor
          Perfection! Nicely done! Big-ups for all the Pro’s supporting this awesome platform!
          David
            droncho @MaXi-XCeL
            testing again and working !!!
              BriggTrim
              Hi…I’m not beyond any doubt which portion isn’t working, so to begin with off, get the MQTTBox installed. Then get that associated to your mqtt, and subscribe to cmnd/hallway/# to see in case you’ll get messages through on the mqtt. If not at that point it’s the mqtt setup, in case there’s , at that point it’s something in MM. You can moreover send MQTT commands throgh the MQTT Box straightforwardly to see on the off chance that the reflect responds to it.
