Third Party modules not working
8 Posts 4 Posters 1.0k Views 4 Watching
    delta 1
    hey, guys, I’ve installed Alexa, screencast, and some others, and doesn’t matter what I try non of them work can anybody help me with this.
      DJBOOB66
      fix your config
          module: "MMM-awesome-alexa",
          position: "bottom_bar",
              wakeWord: "Alexa",
              clientId: "YOUR_CLIENT_ID",
              clientSecret: "YOUR_CLIENT_SECRET",
              deviceId: "YOUR_DEVICE_ID",
              refreshToken: "YOUR_REFRESH_TOKEN",
              lite: false,
              isSpeechVisualizationEnabled: false
      D 2 Replies Last reply Aug 9, 2021, 8:59 PM Reply Quote 0
        delta 1 @DJBOOB66
        @djboob66 said in Third Party modules not working: thanks for the response yea, is it in the correct order now ?
          delta 1 @DJBOOB66
          @djboob66 tried that and still doesn’t work
            DJBOOB66
            @delta-1 said in Third Party modules not working:
            Alexa
            your config must line up
            		module: 'MMM-Screencast',
            		position: 'bottom_right',
            			position: 'bottomRight',
            			height: 300,
            			width: 500,
                        wakeWord: "Alexa",
                        lite: false,
              DJBOOB66
              Im not a alexa guy i use Google assistant V3 myself but below need fixing.
              C S 2 Replies Last reply Aug 10, 2021, 1:10 AM Reply Quote 0
                cowboysdude Module Developer @DJBOOB66
                Have to be careful if you’re cutting and pasting … for instance if you install a module and you go to the programmers page and copy and paste the config example the quotes will not translate. You will get errors.
                • S Away
                  sdetweil @DJBOOB66
                  @djboob66 there is nothing functionally wrong with his text…
                  sure the braces aren’t lined up and the sections aren’t indented like I personally would like and do… but MagicMirror doesn’t care.
