    Third Party modules not working
    8 Posts 4 Posters 1.6k Views 4 Watching
    • delta 1D Offline
      delta 1 @DJBOOB66
      @djboob66 said in Third Party modules not working: thanks for the response yea, is it in the correct order now ?
      • delta 1D Offline
        delta 1 @DJBOOB66
        @djboob66 tried that and still doesn’t work
          DJBOOB66
          @delta-1 said in Third Party modules not working:
          Alexa
          your config must line up
          		module: 'MMM-Screencast',
          		position: 'bottom_right',
          			position: 'bottomRight',
          			height: 300,
          			width: 500,
                  module: "MMM-awesome-alexa",
                  position: "bottom_bar",
                      wakeWord: "Alexa",
                      clientId: "YOUR_CLIENT_ID",
                      clientSecret: "YOUR_CLIENT_SECRET",
                      deviceId: "YOUR_DEVICE_ID",
                      refreshToken: "YOUR_REFRESH_TOKEN",
                      lite: false,
                      isSpeechVisualizationEnabled: false
            DJBOOB66
            Im not a alexa guy i use Google assistant V3 myself but below need fixing.
            cowboysdudeC S 2 Replies Last reply Reply Quote 0
            • cowboysdudeC Offline
              cowboysdude Module Developer @DJBOOB66
              Have to be careful if you’re cutting and pasting … for instance if you install a module and you go to the programmers page and copy and paste the config example the quotes will not translate. You will get errors.
                sdetweil @DJBOOB66
                @djboob66 there is nothing functionally wrong with his text…
                sure the braces aren’t lined up and the sections aren’t indented like I personally would like and do… but MagicMirror doesn’t care.
