    Trouble getting Background Image to Show
    27 Posts 2 Posters 10.2k Views 2 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 case doesn’t matter as long as it matches what the REAL name has.
      note for a url u need
      http:// - from a web server
      // using MM web server, whose base is MagicMirror
      http://localhost:8080/Backgrounds/IMG_0169.JPG
      or file:// – direct from the file system
      background: url(“file:///home/pi/MagicMirror/Backgrounds/IMG_0169.JPG”)
      (note three /// two on the file://, and one on the root path)
      you should be able to put each in a browser and get it to show (outside of MM), that proves the url is right
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A Offline
        ankonaskiff17 @sdetweil
        @sdetweil I’m more stumped now. The file name & location are good. If I hover over the url in your second example in VS Code it gives option to follow link and launches browser and loads picture just fine but no joy in MM.
          @ankonaskiff17 ignore what other apps do… MM is primative
            @sdetweil I’m just saying that the file address is good as entered.
            In main.css you have
            html {
              cursor: none;
              overflow: hidden;
              background: var(--color-background);
              user-select: none;
              font-size: var(--font-size);
            set for background. Is that causing issues? custom.css should override that, shouldn’t it?
              @ankonaskiff17 where is your background set… body, there is an z-order too…
              i use fullscreen_background position for my background images
              if u look at the developer window elements tab to find your background, where is in the the css stack?
                @sdetweil Right at the top just below html. The way I understand is that it will load html first, then body. My html is an abbreviated version of main.css html
                custom.css
                main.css
                  @ankonaskiff17 body supercedes
                  html.
                  u should look in the developers window, elements tab to see the actual css tree
                  ctrl-shift-i, select elements tab.
                    @sdetweil I’ve been doing that.
                      @ankonaskiff17 so u can turn off things with a click in front. so disable the background color
                        @sdetweil I’ve wrestled with this all morning and exhausted every combination I could imagine, I decided to try sticking a color in as shown below. Not sure if anything can be inferred if it will accept a background color but not a background image. I am ignorant of the vagaries of js but is it possible that background: var(--color-background); in is locking me i n to only color options since the default is set in
                        :root {
                        --background-color #000
                        body {
                        background: red;
