    Trouble getting Background Image to Show
    27 Posts 2 Posters 10.5k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil I’m more stumped now. The file name & location are good. If I hover over the url in your second example in VS Code it gives option to follow link and launches browser and loads picture just fine but no joy in MM.
        sdetweil @ankonaskiff17
        @ankonaskiff17 ignore what other apps do… MM is primative
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          @sdetweil I’m just saying that the file address is good as entered.
          In main.css you have
          html {
            cursor: none;
            overflow: hidden;
            background: var(--color-background);
            user-select: none;
            font-size: var(--font-size);
          set for background. Is that causing issues? custom.css should override that, shouldn’t it?
            @ankonaskiff17 where is your background set… body, there is an z-order too…
            i use fullscreen_background position for my background images
            if u look at the developer window elements tab to find your background, where is in the the css stack?
              @sdetweil Right at the top just below html. The way I understand is that it will load html first, then body. My html is an abbreviated version of main.css html
              custom.css
              main.css
                @ankonaskiff17 body supercedes
                html.
                u should look in the developers window, elements tab to see the actual css tree
                ctrl-shift-i, select elements tab.
                  @sdetweil I’ve been doing that.
                    @ankonaskiff17 so u can turn off things with a click in front. so disable the background color
                      @sdetweil I’ve wrestled with this all morning and exhausted every combination I could imagine, I decided to try sticking a color in as shown below. Not sure if anything can be inferred if it will accept a background color but not a background image. I am ignorant of the vagaries of js but is it possible that background: var(--color-background); in is locking me i n to only color options since the default is set in
                      :root {
                      --background-color #000
                      body {
                      background: red;
                        @ankonaskiff17 possibly… disable it in the dev window… uncheck it… right side, near the bottom (that is closest to main.css while top is closest to latest css.
