    Trouble getting Background Image to Show
    27 Posts 2 Posters 12.5k Views 2 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 ignore what other apps do… MM is primative
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A Offline
        ankonaskiff17 @sdetweil
        @sdetweil I’m just saying that the file address is good as entered.
        In main.css you have
        html {
          cursor: none;
          overflow: hidden;
          background: var(--color-background);
          user-select: none;
          font-size: var(--font-size);
        set for background. Is that causing issues? custom.css should override that, shouldn’t it?
          @ankonaskiff17 where is your background set… body, there is an z-order too…
          i use fullscreen_background position for my background images
          if u look at the developer window elements tab to find your background, where is in the the css stack?
            @sdetweil Right at the top just below html. The way I understand is that it will load html first, then body. My html is an abbreviated version of main.css html
            custom.css
            main.css
              @ankonaskiff17 body supercedes
              html.
              u should look in the developers window, elements tab to see the actual css tree
              ctrl-shift-i, select elements tab.
                @sdetweil I’ve been doing that.
                  @ankonaskiff17 so u can turn off things with a click in front. so disable the background color
                    @sdetweil I’ve wrestled with this all morning and exhausted every combination I could imagine, I decided to try sticking a color in as shown below. Not sure if anything can be inferred if it will accept a background color but not a background image. I am ignorant of the vagaries of js but is it possible that background: var(--color-background); in is locking me i n to only color options since the default is set in
                    :root {
                    --background-color #000
                    body {
                    background: red;
                      @ankonaskiff17 possibly… disable it in the dev window… uncheck it… right side, near the bottom (that is closest to main.css while top is closest to latest css.
                        @ankonaskiff17 so I added a body with a background image, using the MM web server in my custom.css
                        body {
                          background-image: url("http://localhost:8090/modules/images/testimage.jpg")
                        and then started MM
                        and got
                        u can see the two body clauses on the right, top is custom.css (if u hover over the name it tells u where it came from)
                          then I added a root entry to custom.css
                          root: {
                            background-color: black;
                          html {
                          /*  cursor: none; */
                          body {
                          and got
                          notice border around pic
                          then turned it off in the dev window
                          border gone
                            same results with
                            root: {
                              --background-color: black;
                            html {
                            /*  cursor: none; */
                            body {
                              using file:// does NOT work
                              body {
                                background-image: url("file:///home/sam/MagicMirror/modules/images/testimage.jpg")
                              even tho it works in chrome
                                @sdetweil localhost is what shows in developer window? You show 8090 vs my 8080
                                  @ankonaskiff17 localhost, cause I am on the same machine as MM is running
                                  and port 8090 cause I have another app using 8080 …
                                    @sdetweil I am getting a Not allowed to load local resource
                                    I thought the image might have not been quite right so copied it fresh and did renaming in terminal but really sure what is going on.
                                    I’m a dummy. I do think the image file was messed up as I was getting file not found errors before I reloaded & renamed file in terminal vs in the Pi version of file manager. Windows habits die hard.
                                    After I did that I started getting the local resource message. I had been doing this through VNC on my laptop but pulled big screen tv over where I could read it, deleted the localhost address from file that I did in VNC and redid the exact same address via Pi directly and its all good now.
                                    Shame on me but is there some rule of thumb about what you can and can’t do remotely. I have built 5 of these things with no issues using VNC until this background sreen issue. Even on this one, I’ve loaded multiple modules, jumbo sized fonts etc.
                                      @ankonaskiff17
                                      where are u doing this? on pi, or remote(pc desktop)
                                      what is the address: in config.js?
                                        @sdetweil See my wordy edit above
                                          @ankonaskiff17 address: and ipWhitelist are not in any of your posts above
                                          i set address: my machine address 192.168.2.106
                                          and it failed with a macthing URL
                                          I still had ipWhitelist set as default, which prevented connect from other than localhost
                                          changed to ipWhitelist:[]
                                          and ip address url works and from a different machine…
                                            @sdetweil So I need to put laptop IP in whitelist what I think I understand you to be saying
