    MMM-GoogleBirthdaysProvider giving Error
    2 Posts 2 Posters 796 Views 2 Watching
    • L Offline
      lu-need
      Re: MMM-GoogleBirthdaysProvider No red birthday cakeScreen Shot 2021-08-16 at 3.22.36 PM.png
      Hi! I am new here, building my first project and I am stuck. I cannot get the googlebirthdaysprovider to work. Here is the config:
      			header: "Upcoming Birthdays",
      				displayRepeatingCountTitle: true,
      							url: 'http://localhost:8080/mmm-googlebirthdaysprovider',
      							symbol: "birthday-cake",
      							repeatingCountTitle: "Birthday",
      							color: '#f00',
      							colored: true,
      							coloredSymbolOnly: true,
      		}, code_text
      it’s gotta be user error – what am I doing wrong? Thank you so much!
        joey @lu-need
        @lu-need
        Just to make sure, do you have the opening curly bracket before your first line above? Also, why do you have “code_text” after the comma at the end?
        I also notice that you use single quote marks instead of double-quotes in the config: block. I am not sure that matters, but all of the examples use double-quotes. (Single quotes should work, but there is always the chance that npm, MM, or some other component is expecting double-quotes.)
        When you say you cannot get it working, does having that block of code in your config.js cause MM not to launch correctly at all? (Ie., do you get a black screen or the “create a config or check the existng one for errors” message?) Or does MM launch correctly, and the module does not show up? Or it shows up, but just has a “Loading” message instead of the expected calendar?
