    Any plan to replace "request" and "moment"?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    61 Posts 8 Posters 41.6k Views 8 Watching
    • 0m4r0 Offline
      0m4r Module Developer
      Is there any plan to migrate away from “request” and “moment”?
      https://github.com/request/request/issues/3142
      https://github.com/moment/moment#project-status
      https://github.com/0m4r
      S karsten13K 0m4r0 3 Replies Last reply Reply Quote 1
        sdetweil @0m4r
        @0m4r we have already moved away from request… it was removed in 2.16
        I hadn’t seen moment status
        I think we moved to moment.tz in calendar
        • karsten13K Online
          karsten13 @0m4r
          I think we should open an issue in the github repo to discuss the moment stuff there, if it should be replaced and with what. Found this article.
          In the current mm release 2.16.0 request is still a dev dependency but it is now totally removed on the develop branch (and so in the next release).
          0m4r0 1 Reply Last reply Reply Quote 1
          • BKeyportB Online
            BKeyport Module Developer
            My concern as a module handler that has two modules that currently use Moment, how do I switch, either now or later?
            S cowboysdudeC 2 Replies Last reply Reply Quote 0
              sdetweil @BKeyport
              @bkeyport now, and later, use the new library in your module and add it to your package.json.
              then if the system provides it npm install will say ‘done’
              and if the system doesn’t, then it will load it for your module…
              mumblebajM 1 Reply Last reply Reply Quote 2
              • mumblebajM Offline
                @sdetweil Just a question from myself, is there a preference from the platform side on what to use to replace request? I have just updated my module to use node-fetch. Are there preferences from the MMM platform side?
                S 0m4r0 2 Replies Last reply Reply Quote 0
                  sdetweil @mumblebaj
                  @mumblebaj no preference…
                  I use axios
                  see this list
                  https://github.com/request/request/issues/3143
                  mumblebajM 1 Reply Last reply Reply Quote 1
                    @sdetweil Thanks Sam. Yeah, I saw there are a few replacements for request. I had a look at axios previously as well.
                    • 0m4r0 Offline
                      0m4r Module Developer @mumblebaj
                      @mumblebaj there are many options. I am planning to replace all with node-fetch (https://github.com/node-fetch/node-fetch), and concerning moment, I think I’d go for date-fns: https://date-fns.org/
                      • 0m4r0 Offline
                        0m4r Module Developer @0m4r
                        @sdetweil ah, I had an old version that still included “request”. ID’ migrate my modules over to node-fetch!
                        About moment, I’d recommend taking a look at date-fns, many are moving over to it to replace moment - even tho the refactoring effort may not be trivial, the advantages seem to be more (including the smaller size of the final bundle)!
                        • 0m4r0 Offline
                          0m4r Module Developer @karsten13
                          @karsten13 said in Any plan to replace "request" and "moment"?:
                          this would be a breaking change for many modules, what’s the plan to communicate it to the module developers (and potentially, to the users?)
                          • karsten13K Online
                            karsten13 @0m4r
                            @0m4r we had similar discussions already here
                            swvalentiS 1 Reply Last reply Reply Quote 0
                            • swvalentiS Offline
                              swvalenti Project Sponsor @karsten13
                              How can I tell if a module will be compatible prior to the fall upgrade of 2.17.0? I don’t want to upgrade and half of my modules break.
                              0m4r0 1 Reply Last reply Reply Quote 0
                              • 0m4r0 Offline
                                0m4r Module Developer @swvalenti
                                @swvalenti if your module uses “request” to issue HTTP calls then it is.
                                so, if you import it in your node_helper.js (or an alike node pice of code).
                                i.e.
                                const request = require('request');
                                or
                                import request from 'request'
                                on way to preserve it is to add “request” as a dependency to your module, but your end-users will need to install them on their own.
                                To add it to your module, from its folder you can do:
                                npm install request ; this will update your package.json file (and package-lock.json) - commit the change to your git repo (this is most likely a breaking change and would require a major version increase - if you version your code!)
                                Once this is done, your existing (and new) end-user will need to update their copy of your module and run npm install on their own to download request and enable them to use it.
                                  swvalenti Project Sponsor @0m4r
                                  @0m4r said in Any plan to replace "request" and "moment"?:
                                  const request = require(‘request’);
                                  thank you for the explanation I understand better now
                                  • karsten13K Online
                                    karsten13 @swvalenti
                                    @swvalenti one addition: Only modules are affected which rely on that request is intalled in core mm (which is a dirty hack of the module developer), modules which install request on their own are not!
                                      sdetweil @karsten13
                                      no… don’t say it that way…
                                      lack of experience on the part of the developer…
                                      it just worked, so they didn’t know to ask if there was a more correct way…
                                      I had that problem early on in my nodejs development too…
                                      karsten13K 1 Reply Last reply Reply Quote 1
                                      • karsten13K Online
                                        karsten13 @sdetweil
                                        @sdetweil doing this in some of my own modules so I’m allowed to say this ;)
                                          sdetweil @karsten13
                                          @karsten13 doing it ON PURPOSE is a hack!!
                                          • 0m4r0 Offline
                                            0m4r Module Developer @sdetweil
                                            @sdetweil @sdetweil I am not convinced about both of your points of view. I mean technically yes.
                                            But… looking into the modules themselves, they are solely made to work with the MagicMirror code base (99% of the cases)
                                            What is the point to bloat the size of the installation with the same node module installed over and over again? when on, “global” can be used and relied upon? (well, yeah, I agree, “this situation” is one reason for it!). But why trade-off convenience over complexity?
                                            I see it as a part of the Magic Mirror ecosystem, provide some common “code” to be used by everyone to both ease the development and the set-up of it.
                                            As mentioned in the other thread, old legacy modules will probably stop working - forking them or re-doing them will fix them. This not only pushes forward the advancement of the whole MagicMirror tech stack, but it may strengthen the community and really push it to hold together and upgrade, modernize the code of the modules.
                                            bottom line, nobody says it is going to be easy, but it is a big opportunity.
                                            • 1 / 4
