    Generic CSS question when target is several layers down
    9 Posts 4 Posters 1.5k Views 3 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      How does one address what appears to be an attribute amenable to custom CSS tweaking when the item is several layers down as shown in attached picture? I figure it has to do with the crude example I sketched out below but not sure what is driver for when you insert spaces, or don’t.
      I see CSS that is
      .X.Y.Z {
      padding-left: 20px;
      While other times it may be
      .X.Y .Z {
      padding-left: 20px;
      S mumblebajM ? 5 Replies Last reply Reply Quote 0
        sdetweil @ankonaskiff17
        @ankonaskiff17 you have to chain together different selectors to target the element you want
        see
        https://www.w3schools.com/cssref/css_selectors.asp
        is id, module_1_calendar
        . is class , .module, .small
        neither is element name , aka div, img, li
        and there are operators that give u parent or child or direct child
        u currently cannot target an element with a specific value
        <li>2</li>
        • mumblebajM Offline
          mumblebaj Module Developer @ankonaskiff17
          @ankonaskiff17 Not an expert in CSS at all but in the first example you gave you are targeting a single element in the chain (.X.Y.Z single element Z in the chain of X/Y) whereas in the second example you are targeting two different elements (.X.Y and .Z).
            @ankonaskiff17 on the spaces question, it’s like immediate child with no space
              @ankonaskiff17 if u select an element in the center panel then it’s lieneage is shown on the bottom of that pane
                A Former User @ankonaskiff17
                  sdetweil @Guest
                  @hango because he has multiple instances of calendar running, he needs to use the ID
                  #module_1_calendar
                  instead of the class
                  ,calendar
                    A Former User @sdetweil
                      sdetweil @Guest
                      @hango said in Generic CSS question when target is several layers down:
                      if he put something between clock and calendar or change position the ID is changing
                      good point… I hadn’t thought of classes for that kind of purpose…
