    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 122.5k Views 16 Watching
    • G
      goedh452 @majsoft
      @majsoft
      I don’t think it is possible to just change the font for the first lines. All are in the same class.
      • majsoftM
        majsoft @majsoft
        @majsoft
        How to remove the lines (marked in green) I have already come.
        using this code
        hr.domoDivider {
          display: none;
        If it is not possible to change the font size of only the first three sensors, it is possible to run 2 instances of the module in config.js, but I do not know how to distinguish these instances in customs.css
        G 1 Reply Last reply
        • G
          goedh452 @majsoft
          @majsoft
          I think this is also not possible, but I’m not an css expert. Maybe others have soms ideas.
          You could create your own module based on the code and modify that css.
          majsoftM 3 Replies Last reply
          • majsoftM
            majsoft @goedh452
            @goedh452
            yes, I’m just trying to create a new mmm-domoticz-ext-2 module, but even if I replace the text mmm-domoticz-ext with mmm-domoticz-ext-2 in all files, it doesn’t work. then it would be easy in CSS to assign a font size to each module. I’m not a programmer either. I have to follow the trial and error method
            • majsoftM
              majsoft @goedh452
              @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
              @majsoft
              I can’t get the copied module up and running, it still reports loading. Basic methods for copying a module fail. Can you advise me how to copy the module?
                module: "MMM-Domoticz-ext",
                  position: "bottom_bar",
                  apiBase: "192.168.2.80",
                  apiPort: "8081",
                      updateInterval: 15,
              displayType: "room",
                        alwaysShowDashboard: false,
                        alwaysShowActions: false,
                        showButtons: false,
                               horizontal: true,
                        columnCount: 3,
                        dashboardColumnCount: 12,
                        maxTitleLength: 18,
               	     rooms: [
                    { idx: "1" },
              { idx: "9" },
              { idx: "8" },
                module: "MMM-Domoticz-ext2",
                  apiPort: "8081",
                      updateInterval: 20,
                        showButtons: false,
                               horizontal: true,
                        columnCount: 3,
                        maxTitleLength: 18,
               	     rooms: [
                    { idx: "11" },
              { idx: "12" },
              { idx: "13" },
              majsoftM 1 Reply Last reply
              • majsoftM
                majsoft @majsoft
                @majsoft
                I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
                If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
                  maxs @goedh452
                  @goedh452
                  Sorry for late reaction. Here is the file you request. I think I uploaded wrong, but I hope you can do something with it.
                  “ActTime” : 1630944398,
                  “AstrTwilightEnd” : “22:12”,
                  “AstrTwilightStart” : “04:58”,
                  “CivTwilightEnd” : “20:46”,
                  “CivTwilightStart” : “06:24”,
                  “DayLength” : “13:14”,
                  “NautTwilightEnd” : “21:27”,
                  “NautTwilightStart” : “05:43”,
                  “ServerTime” : “2021-09-06 18:06:38”,
                  “SunAtSouth” : “13:35”,
                  “Sunrise” : “06:58”,
                  “Sunset” : “20:12”,
                  “app_version” : “2021.1”,
                  “result” :
                  “AddjMulti” : 1.0,
                  “AddjMulti2” : 1.0,
                  “AddjValue” : 0.0,
                  “AddjValue2” : 0.0,
                  “BatteryLevel” : 255,
                  “Counter” : “5077.807”,
                  “CounterDeliv” : “0.000”,
                  “CounterDelivToday” : “18446744073709552.000 kWh”,
                  “CounterToday” : “2.151 kWh”,
                  “CustomImage” : 0,
                  “Data” : “2794757;2283050;6;0;123;0”,
                  “Description” : “”,
                  “Favorite” : 1,
                  “HardwareDisabled” : false,
                  “HardwareID” : 2,
                  “HardwareName” : “Smart Meter”,
                  “HardwareType” : “P1 Smart Meter USB”,
                  “HardwareTypeVal” : 4,
                  “HaveTimeout” : false,
                  “ID” : “0001”,
                  “LastUpdate” : “2021-09-06 18:06:38”,
                  “Name” : “Power”,
                  “Notifications” : “false”,
                  “PlanID” : “4”,
                  “PlanIDs” :
                  “Protected” : false,
                  “ShowNotifications” : true,
                  “SignalLevel” : “-”,
                  “SubType” : “Energy”,
                  “SwitchTypeVal” : 0,
                  “Timers” : “false”,
                  “Type” : “P1 Smart Meter”,
                  “TypeImg” : “counter”,
                  “Unit” : 1,
                  “Usage” : “123 Watt”,
                  “UsageDeliv” : “0 Watt”,
                  “Used” : 1,
                  “XOffset” : “0”,
                  “YOffset” : “0”,
                  “idx” : “1”
                  “status” : “OK”,
                  “title” : “Devices”
                  • G
                    goedh452 @maxs
                    @maxs
                    I see what’s the problem. For the usage per day the CounterToday and CounterDelivToday are substracted. The value for your CounterDelivToday has a very strange value. Only option would be that such values are set to 0 in the code.
                      maxs @goedh452
                      @goedh452
                      can I do that by my own? I have idee how, but maybe with some help from you? Thans for quick answer.
                      G 2 Replies Last reply
                      • G
                        goedh452 @maxs
                        @maxs I’ll see what I can do and let you know when you can download the new code from GitHub.
                          maxs @goedh452
                          @goedh452
                          Thanks, that would be nice. I really like your module.
                          • G
                            goedh452 @maxs
                            @maxs
                            I made some changes in the code. Can you download the latest version from GitHub and add the option enableReturn to the utility device? When set to false the return values are ignored and the correct value should be displayed. I’m unable to test properly since my device doesn’t generate this strange value.
                            enableReturn: false,
                            My config example looks like this:
                            devices: [
                                            idx: "304",
                                            deviceHeader: "Elektriciteit",
                                            useHeaderSymbol: true,
                                            headerSymbol: "plug",
                                            counterTodayLabel: "Vandaag",
                                            counterTodayAppendText: "kWh",
                                            gaugeMinValue: -3000,
                                            gaugeMaxValue: 3000,
                                            gaugeAppendText: "watt",
                                            gaugeWidth: 200,
                                            lineWidth: 16,
                                            markerWidth: 16,
                                            markerColor: "#F4D03F"
                              maxs @goedh452
                              @goedh452
                              Thanks for quick reply. Test it and works like a charm.
                              :thumbs_up:
                              Thanks.
                              • majsoftM
                                majsoft @goedh452
                                  Manu663
                                  Hi all, I’m an old geek who’s trying to keep up but learning by doing without initial training is long, difficult and the age of my brain cells doesn’t help me much.
                                  Could you please post some examples of your MMM-Domoticz-ext config? (from the simplest to the most elaborate, I’ll take anything that comes along!)
                                  It would help me to test different configurations and customize mine.
                                  Thanks in advance !
                                  • G
                                    goedh452 @Manu663
                                    @manu663
                                    Please see the GitHub-page for some examples: MMM-Domoticz-ext
                                      Manu663 @goedh452
                                      @goedh452 Thank you for your quick reply, it’s much appreciated!
                                      I have read the whole github unfortunately, I don’t manage to get a convincing result. It doesn’t matter, I’ll calm down and read the github again over a cup of coffee and start all over again.
                                      But if others have examples, I’ll take them anyway ;-)
                                        Manu663 @Manu663
                                        Once I calmed down and reread everything from the beginning I finally managed to get a nice result.
                                        I feel ashamed that I called for help when it was just a silly syntax error. :sad_but_relieved_face:
                                        Anyway, thank you for the marvelous job done there !
                                        • G
                                          goedh452 @Manu663
                                          @manu663
                                          No problem at all! The module became a bit complex during the build :-)
                                            Shaitan
                                            Hi @goedh452,
                                            Your mod is so great, but I think you already know that ;-).
                                            Like the others, this is exactly what I was looking for.
                                            But after installing it, it doesn’t display anything, just the title on my MM. I notice in the domoticz log that he contacts him but I do not know if it is a problem of connection or reception of data…
                                            Thank a lot for your help
                                            Here are the informations and screenshots :
                                            Domoticz ip : 192.168.1.3
                                            MM’s ip : 192.168.1.40
                                            My Config.js
                                            			header: "Domoticz",
                                            			  apiBase: "192.168.1.3",
                                            			  apiPort: "8080",
                                            			  updateInterval: 5,
                                            			  animationSpeed: 0,
                                            			  displayType: "all",
                                            			  horizontal: true,
                                            			  dashboardColumnCount: 2,
                                            			  showTotals: true,
                                            			  dashboardRooms: [ "1", "2" ],
                                            My json for IDX 1
                                            	"ActTime" : xxxxxx,
                                            	"AstrTwilightEnd" : "xxxxx",
                                            	"AstrTwilightStart" : "xxxxx",
                                            	"CivTwilightEnd" : "xxxxxx",
                                            	"CivTwilightStart" : "xxxxx",
                                            	"DayLength" : "xxxxxx",
                                            	"NautTwilightEnd" : "xxxxx",
                                            	"NautTwilightStart" : "xxxxx",
                                            	"ServerTime" : "xxxxxxxxx",
                                            	"SunAtSouth" : "xxxxx",
                                            	"Sunrise" : "xxxxx",
                                            	"Sunset" : "xxxxx",
                                            	"app_version" : "2021.1",
                                            	"result" :
                                            			"AddjMulti" : 1.0,
                                            			"AddjMulti2" : 1.0,
                                            			"AddjValue" : 0.0,
                                            			"AddjValue2" : 0.0,
                                            			"BatteryLevel" : 255,
                                            			"CustomImage" : 0,
                                            			"Data" : "21.4 C, 56 %",
                                            			"Description" : "",
                                            			"DewPoint" : "12.26",
                                            			"Favorite" : 0,
                                            			"HardwareDisabled" : false,
                                            			"HardwareID" : 2,
                                            			"HardwareName" : "DHT 22 ext",
                                            			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                                            			"HardwareTypeVal" : 15,
                                            			"HaveTimeout" : false,
                                            			"Humidity" : 56,
                                            			"HumidityStatus" : "Comfortable",
                                            			"ID" : "14051",
                                            			"LastUpdate" : "2021-11-29 15:03:03",
                                            			"Name" : "DHT22 ext",
                                            			"Notifications" : "false",
                                            			"PlanID" : "0",
                                            			"PlanIDs" :
                                            			"Protected" : false,
                                            			"ShowNotifications" : true,
                                            			"SignalLevel" : 3,
                                            			"SubType" : "THGN122/123/132, THGR122/228/238/268",
                                            			"Temp" : 21.399999999999999,
                                            			"Timers" : "false",
                                            			"Type" : "Temp + Humidity",
                                            			"TypeImg" : "temperature",
                                            			"Unit" : 1,
                                            			"Used" : 1,
                                            			"XOffset" : "0",
                                            			"YOffset" : "0",
                                            			"idx" : "1",
                                            			"trend" : 2
                                            	"status" : "OK",
                                            	"title" : "Devices"
                                            My Setting on Domoticz
                                            Log domoticz
                                            My MM
                                            • 4 / 7
