    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 117.5k Views 16 Watching
      peterh @goedh452
      @goedh452
      Hi
      rooms: [
                                          { idx: "17", name: "Status" },  // can only show switch status,, breaks if temp. in room?
                                          //{ idx: "14", name: "Testing" },
      I have a “room” plan set in Domoticz that contains various virtual devices, if i add a temperature device to it, the list of devices shown in MM stops at that device.
      With “mote” (temp & humidity) sensor in the room
      With no mote in the room.
      Please note: I have used custom css to shrink the members of the room to a more compact left justified list, rather than spread across the whole width of the screen.
      regards Peter
      G 2 Replies Last reply Reply Quote 0
      • G Offline
        goedh452 @peterh
        @peterh
        I can have a look at the temp/hum issue. I have several of these sensors myself and they do work in this layout. I would need the JSON-output of the specified device to figure out the problem.
        • G Offline
          goedh452 @peterh
          @peterh
          I tried, but am unable to reproduce your problem. If you would like me to have a look, please post the JSON result for the device “mote”.
            peterh @goedh452
            @goedh452
            Hi
            Sorry for the delayed response.
            It appears that the issue occurs when there is no temperature or humidity data in the json output.
            the sensor had no data while i was initially testing. After collecting some data it works as expected.
            sample json data:
            pi@MM-lite:~$ curl "http://10.60.2.252:8080/json.htm?type=devices&rid=196"
                    "ActTime" : 1623221642,
                    "AstrTwilightEnd" : "18:46",
                    "AstrTwilightStart" : "05:45",
                    "CivTwilightEnd" : "17:46",
                    "CivTwilightStart" : "06:45",
                    "DayLength" : "10:07",
                    "NautTwilightEnd" : "18:16",
                    "NautTwilightStart" : "06:15",
                    "ServerTime" : "2021-06-09 14:54:02",
                    "SunAtSouth" : "12:16",
                    "Sunrise" : "07:12",
                    "Sunset" : "17:19",
                    "app_version" : "2020.2 (build 12917)",
                    "result" :
                                    "AddjMulti" : 1.0,
                                    "AddjMulti2" : 1.0,
                                    "AddjValue" : 0.0,
                                    "AddjValue2" : 0.0,
                                    "BatteryLevel" : 255,
                                    "CustomImage" : 0,
                                    "Data" : "0, 27.0",
                                    "Description" : "temperature and humidity in my office. polled from mqtt",
                                    "Favorite" : 0,
                                    "HardwareDisabled" : false,
                                    "HardwareID" : 3,
                                    "HardwareName" : "virtual hardware",
                                    "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                                    "HardwareTypeVal" : 15,
                                    "ID" : "14114",
                                    "LastUpdate" : "2021-01-04 17:58:14",
                                    "Name" : "mote",
                                    "Notifications" : "false",
                                    "PlanID" : "0",
                                    "PlanIDs" :
                                    "Protected" : false,
                                    "ShowNotifications" : true,
                                    "SignalLevel" : "-",
                                    "SubType" : "THGN122/123/132, THGR122/228/238/268",
                                    "Timers" : "false",
                                    "Type" : "Temp + Humidity",
                                    "TypeImg" : "temperature",
                                    "Unit" : 1,
                                    "Used" : 1,
                                    "XOffset" : "0",
                                    "YOffset" : "0",
                                    "idx" : "196"
                    "status" : "OK",
                    "title" : "Devices"
            With Temperature and humidity
                    "ActTime" : 1623222662,
                    "ServerTime" : "2021-06-09 15:11:02",
                    "Sunset" : "17:19",
                    "result" :
                                    "AddjMulti" : 1.0,
                                    "AddjMulti2" : 1.0,
                                    "AddjValue" : 0.0,
                                    "AddjValue2" : 0.0,
                                    "BatteryLevel" : 14,
                                    "CustomImage" : 0,
                                    "Data" : "32.2 C, 34 %",
                                    "DewPoint" : "14.35",
                                    "Favorite" : 0,
                                    "HardwareID" : 3,
                                    "HaveTimeout" : false,
                                    "Humidity" : 34,
                                    "HumidityStatus" : "Comfortable",
                                    "ID" : "14114",
                                    "LastUpdate" : "2021-06-09 15:10:35",
                                    "Name" : "mote",
                                    "PlanID" : "0",
                                    "PlanIDs" :
                                    "Temp" : 32.19,
                                    "Timers" : "false",
                                    "Unit" : 1,
                                    "Used" : 1,
                                    "XOffset" : "0",
                                    "YOffset" : "0",
                                    "idx" : "196",
                                    "trend" : 1
                    "status" : "OK",
                    "title" : "Devices"
            mote sensor appears now, above the snake enclosure light.
            thanks again for your attention
              maxs
              Hi tanks for great module. I have a small problem with the counter today from the power consumption. this doesn’t show me the amount of use of the day. Gas and water working fine. see screenshot. Do you have a solution, or where I have to search? !!Schermafbeelding 2021-07-24 om 20.59.12.jpg
              • majsoftM Offline
                majsoft @Sp0nsje
                • G Offline
                  goedh452 @maxs
                  @maxs
                  Alle data is retrieved from the JSON response. Could you post it for the electricity counter?
                  • majsoftM Offline
                    majsoft
                    Hi everyone, please help with setting up customs.css
                    Can anyone advise me how to change the font and icon size only for the first three rooms? (Red marked)
                    I would also need to delete the dividing lines marked in green.
                    I will be very grateful for more detailed advice.
                    customs.css
                    .domoCellState {
                      text-align: right;
                    vertical-align: center;
                      padding-left: 10px;
                    font-size: 300%; 			/* velikost čísla teploměru */
                    color: #FFFFFF;
                    line-height: 100%;
                    .domoIconDiv {
                      padding-right: 5px;
                      font-size: 200%;                        /* velikost ikony teploměru */
                    .domoCell {
                      text-align: left;
                     font-size: 200%;			/* velikost pisma popisku teplomeru - vedle ikony teploměru */
                    line-height: 100%;
                    .domoRoomCell {
                      padding-right: 20px;
                    font-size: 0%;			/* velikost pisma nadpisu room */
                    Config.js
                    the room numbers for which I would like to change the font size are idx 1, 8, 9
                      module: "MMM-Domoticz-ext",
                      position: "bottom_bar",
                        apiBase: "192.168.2.80",
                        apiPort: "8081",
                            updateInterval: 15,
                    displayType: "room",
                              alwaysShowDashboard: false,
                              alwaysShowActions: false,
                              showButtons: false,
                                     horizontal: true,
                              columnCount: 3,
                              dashboardColumnCount: 12,
                              maxTitleLength: 18,
                         rooms: [
                          { idx: "1" },
                    { idx: "9" },
                    { idx: "8" },
                    { idx: "11" },
                    { idx: "12" },
                    { idx: "13" },
                    Another question is whether it is possible to replace the character C with ° (character Celsius)
                    G majsoftM 2 Replies Last reply Reply Quote 0
                    • G Offline
                      goedh452 @majsoft
                      @majsoft
                      I don’t think it is possible to just change the font for the first lines. All are in the same class.
                      • majsoftM Offline
                        majsoft @majsoft
                        @majsoft
                        How to remove the lines (marked in green) I have already come.
                        using this code
                        hr.domoDivider {
                          display: none;
                        If it is not possible to change the font size of only the first three sensors, it is possible to run 2 instances of the module in config.js, but I do not know how to distinguish these instances in customs.css
                        • G Offline
                          goedh452 @majsoft
                          @majsoft
                          I think this is also not possible, but I’m not an css expert. Maybe others have soms ideas.
                          You could create your own module based on the code and modify that css.
                          majsoftM 3 Replies Last reply Reply Quote 0
                          • majsoftM Offline
                            majsoft @goedh452
                            @goedh452
                            yes, I’m just trying to create a new mmm-domoticz-ext-2 module, but even if I replace the text mmm-domoticz-ext with mmm-domoticz-ext-2 in all files, it doesn’t work. then it would be easy in CSS to assign a font size to each module. I’m not a programmer either. I have to follow the trial and error method
                            • majsoftM Offline
                              majsoft @goedh452
                              @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
                              @majsoft
                              I can’t get the copied module up and running, it still reports loading. Basic methods for copying a module fail. Can you advise me how to copy the module?
                                  apiPort: "8081",
                                      updateInterval: 15,
                                        showButtons: false,
                                               horizontal: true,
                                        columnCount: 3,
                                        maxTitleLength: 18,
                               	     rooms: [
                                    { idx: "1" },
                              { idx: "9" },
                              { idx: "8" },
                                module: "MMM-Domoticz-ext2",
                                  apiPort: "8081",
                                      updateInterval: 20,
                                        showButtons: false,
                                               horizontal: true,
                                        columnCount: 3,
                                        maxTitleLength: 18,
                               	     rooms: [
                                    { idx: "11" },
                              { idx: "12" },
                              { idx: "13" },
                              majsoftM 1 Reply Last reply Reply Quote 0
                              • majsoftM Offline
                                majsoft @majsoft
                                @majsoft
                                I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
                                If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
                                  maxs @goedh452
                                  @goedh452
                                  Sorry for late reaction. Here is the file you request. I think I uploaded wrong, but I hope you can do something with it.
                                  “ActTime” : 1630944398,
                                  “AstrTwilightEnd” : “22:12”,
                                  “AstrTwilightStart” : “04:58”,
                                  “CivTwilightEnd” : “20:46”,
                                  “CivTwilightStart” : “06:24”,
                                  “DayLength” : “13:14”,
                                  “NautTwilightEnd” : “21:27”,
                                  “NautTwilightStart” : “05:43”,
                                  “ServerTime” : “2021-09-06 18:06:38”,
                                  “SunAtSouth” : “13:35”,
                                  “Sunrise” : “06:58”,
                                  “Sunset” : “20:12”,
                                  “app_version” : “2021.1”,
                                  “result” :
                                  “AddjMulti” : 1.0,
                                  “AddjMulti2” : 1.0,
                                  “AddjValue” : 0.0,
                                  “AddjValue2” : 0.0,
                                  “BatteryLevel” : 255,
                                  “Counter” : “5077.807”,
                                  “CounterDeliv” : “0.000”,
                                  “CounterDelivToday” : “18446744073709552.000 kWh”,
                                  “CounterToday” : “2.151 kWh”,
                                  “CustomImage” : 0,
                                  “Data” : “2794757;2283050;6;0;123;0”,
                                  “Description” : “”,
                                  “Favorite” : 1,
                                  “HardwareDisabled” : false,
                                  “HardwareID” : 2,
                                  “HardwareName” : “Smart Meter”,
                                  “HardwareType” : “P1 Smart Meter USB”,
                                  “HardwareTypeVal” : 4,
                                  “HaveTimeout” : false,
                                  “ID” : “0001”,
                                  “LastUpdate” : “2021-09-06 18:06:38”,
                                  “Name” : “Power”,
                                  “Notifications” : “false”,
                                  “PlanID” : “4”,
                                  “PlanIDs” :
                                  “Protected” : false,
                                  “ShowNotifications” : true,
                                  “SignalLevel” : “-”,
                                  “SubType” : “Energy”,
                                  “SwitchTypeVal” : 0,
                                  “Timers” : “false”,
                                  “Type” : “P1 Smart Meter”,
                                  “TypeImg” : “counter”,
                                  “Unit” : 1,
                                  “Usage” : “123 Watt”,
                                  “UsageDeliv” : “0 Watt”,
                                  “Used” : 1,
                                  “XOffset” : “0”,
                                  “YOffset” : “0”,
                                  “idx” : “1”
                                  “status” : “OK”,
                                  “title” : “Devices”
                                  • G Offline
                                    goedh452 @maxs
                                    @maxs
                                    I see what’s the problem. For the usage per day the CounterToday and CounterDelivToday are substracted. The value for your CounterDelivToday has a very strange value. Only option would be that such values are set to 0 in the code.
                                      maxs @goedh452
                                      @goedh452
                                      can I do that by my own? I have idee how, but maybe with some help from you? Thans for quick answer.
                                      • G Offline
                                        goedh452 @maxs
                                        @maxs I’ll see what I can do and let you know when you can download the new code from GitHub.
                                          maxs @goedh452
                                          @goedh452
                                          Thanks, that would be nice. I really like your module.
                                          • G Offline
                                            goedh452 @maxs
                                            @maxs
                                            I made some changes in the code. Can you download the latest version from GitHub and add the option enableReturn to the utility device? When set to false the return values are ignored and the correct value should be displayed. I’m unable to test properly since my device doesn’t generate this strange value.
                                            enableReturn: false,
                                            My config example looks like this:
                                            devices: [
                                                            idx: "304",
                                                            deviceHeader: "Elektriciteit",
                                                            useHeaderSymbol: true,
                                                            headerSymbol: "plug",
                                                            counterTodayLabel: "Vandaag",
                                                            counterTodayAppendText: "kWh",
                                                            gaugeMinValue: -3000,
                                                            gaugeMaxValue: 3000,
                                                            gaugeAppendText: "watt",
                                                            gaugeWidth: 200,
                                                            lineWidth: 16,
                                                            markerWidth: 16,
                                                            markerColor: "#F4D03F"
                                            • 4 / 7
