    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 120.7k Views 16 Watching
      Sp0nsje
      Hi @goedh452 ,
      Thanks for the MM Module its great!
      I’m an beginner with MM and Domoticz.
      Is it possible to display texts and distances (dummy text and Dummy Distance) i use the ‘‘both’’ function on my mirror.
      The distance is now grouped with the switches.
      I’m using it for my water softener salt level.
      Mayby its somehow possible to overrule the grouped option and show defined idx numbers at the bottom.
      Do you have a link on how u managed your luxaflex to work in domoticz ?
      (Hunter Douglas hub) i’ve got 2 top down bottom up blinds would love to read the state on my mirror.
      If its not possible let me know.
      gr,
      Martijn
      • G
        goedh452 @Sp0nsje
        @sp0nsje
        Would an option be that you add the module a second time in the config with option “All”? Then the devices are displayed separately.
        My luxaflex are operated with MQTT. I build in a servo myself and attached it to a NodeMCU. Domoticz sends an MQTT command when I press a dummy switch.
          peterh
          @goedh452
          Thanks for this awesome MagicMirror Domoticz module.
          I’ve switched over to using this one and the pretty gauges make it look great.
          Electricity use/consumption works well, but I cannot seem to get other “meter” type sensor/devices to show up.
          Temperature sensors appear in the module “Weather” section, but Text, Voltage (V) or Current (I) sensor in the Domoticz Utilities tab, do not appear to display in any section.
          Feature request :-)
          Is it possible to have an arbitrary numeric device displayed as a gauge in its own section of the display?
          thanks for your time so far.
          • G
            goedh452 @peterh
            @peterh I’ll have a look at it this weekend. Could you post the JSON output from the devices so I can have a look where de field with the data are?
            This can be done with the following link:
            "http://DOMOTICZ-IP:PORT/json.htm?type=devices&rid=IDX
              Sp0nsje @goedh452
              @goedh452 thanks fixed it by using the utility for actual usage so i don’t need it in the rooms layout.
              Is it posible to implement my distance Dummy sensor into a utility gauge?
              the sensor is receiving data in this format “Data” : “22.1 cm”,
              I can also make a dummy counter and it will be “Counter” : "22.035 ",
              If i try to add a gauge in the module it wont load. i think its because of the data provided by my IDX numbers.
              • G
                goedh452 @Sp0nsje
                @sp0nsje
                I think you are right why it is not loading. I’ll have a look at the multiple requests this weekend.
                  Sp0nsje @goedh452
                  @goedh452 thanks,
                  Is it true that the gauges switch position? added 2 of them (electr. usagage and gas usage) is see them switch position sometimes when they update apart from each other.
                  somehow my gass gauge updated and switched to the left side 10 sec later electr. gauge was updated and switched back to the left side.
                  Feature request
                  Would be nice to fix their position.
                  thanks allot for the module it looks Great!
                  • G
                    goedh452 @Sp0nsje
                    @sp0nsje
                    This sometimes seems to happen indeed. I notices it as well. The different gauges aren’t always processed in the same order and that causes the switch of position. I have a look at this as well. It should be possible to always order them according to the order in the config.
                    • G
                      goedh452 @goedh452
                      @Sp0nsje @peterh
                      I made some modifications to the code:
                      • Fixed the switching positions of gauges (I think, it doesn’t happen to me a lot, so testing is a bit difficult)
                      • Added ‘Custom gauges’. You can use every type of device to be displayed as a gauge as long as you specify the correct config settings (also see the readme).
                      My customGauge config is:
                      customGauges: {
                                  headerLabel: "Overige",
                                  showLabel: true,
                                  devices: [
                                      idx: "1356",
                                      deviceHeader: "Volt",
                                      lowerText: "Voltage",
                                      gaugeAppendText: "volt",
                                      gaugeMaxValue: 250,
                                      idx: "2057",
                                      deviceHeader: "Afstand",
                                      gaugeAppendText: "cm",
                                      gaugeMaxValue: 1000,
                                      markerColor: "#70db70"
                      This results in:
                      Please download the latest code from GitHub and give it a try! Let me know it you encounter any problems.
                        Sp0nsje
                        @goedh452
                        Thanks,
                        Works like a charm.
                        Will keep u posted if some errors show up.
                        S majsoftM 2 Replies Last reply Reply Quote 0
                          Sp0nsje @Sp0nsje
                          @goedh452
                          Looking at my post is spotted some differances in the gauges. they were my mistakes :P
                            peterh @goedh452
                            @goedh452
                            Hi and thanks again for your efforts.
                            Gauge swapping positions
                            I can confirm that this occurs occasionally, on a manual browser refresh if seems to have a 15% chance of occurring. ( i did 30 refreshes. and got 2 swaps) i only see the last 2 gauges, out of the 5 that i have showing, do the swap.
                            Custom Gauges
                            These work well and as expected. - thank you!
                            here is the config I am using:
                                                  module: "MMM-Domoticz-ext",
                                                  //header: "Domoticz - new",
                                                  //position: "bottom_left",
                                                  position: "bottom_bar",
                                                        apiBase: "10.60.2.252",
                                                        apiPort: "8080",
                                                        //apiUser: "XXXX",              // only works with domoticz "Setup|Settngs|Website protection = "Basic auth" add the MM Ip to the "Local Networks" list to allow access with no auth, then all sensors will be listed.
                                                        //apihPW: "YYYY",
                                                        //alwaysShowDashboard: true,
                                                        horizontal: "true",
                                                        columnCount: 3,
                                                        displayType: "all",     // show all switchs/lights status
                                                        //displayType: "dashboard",     // dashboard
                                                        //dashboardColumnCount: 3,
                                                        //switchIcon: "lightbulb",
                                                        weather: {
                                                        devices: [ "199", "200" ],    //snake temps
        weatherLabel: "Temperatures",
        gaugeWidth: 200,
        gaugeWindAppendText: "km/h",
        rainSuffix: "mm",
                                                        utilities: {
        utilityLabel: "Gas - Water - Elec",
        showLabel: false,
        devices: [
        idx: "164",
        deviceHeader: "Solar Gen",
        useHeaderSymbol: false,
        headerSymbol: "solar-panel",
        counterTodayLabel: "Today",
        gaugeMinValue: 0,
        gaugeMaxValue: 2000,
        gaugeAppendText: "Watts",
        gaugeWidth: 150,
        lineWidth: 12,
        markerWidth: 12,
        markerColor: "#F4D03F"
        idx: "191",
        deviceHeader: "PowGen/PowUse",
        gaugeMinValue: -2000,
        gaugeWidth: 150,
        lineWidth: 12,
        markerWidth: 12,
        markerColor: "#F4003F"
                                                        customGauges: {
        headerLabel: "Monitoring",
        showLabel: false,
        devices: [
        idx: "209",
        deviceHeader: "Toaster",
        gaugeAppendText: "volts",
        gaugeMaxValue: 255,
        gaugeWidth: 150,
        lineWidth: 12,
        markerWidth: 12,
        idx: "208",
        gaugeAppendText: "Amps",
        lowerText: "Current",
        gaugeMaxValue: 16,
        gaugeWidth: 150,
        lineWidth: 12,
        markerWidth: 12,
        idx: "232",
        deviceHeader: "Brightness",
        lowerText: "Manual Override",
        gaugeAppendText: "%",
        gaugeMaxValue: 100,
        gaugeWidth: 150,
        lineWidth: 12,
        markerWidth: 12,
        markerColor: "#707070",
                                                        rooms: [
        { idx: "17", name: "Status" },  // can only show switch status,, breaks if temp. in room?
        //{ idx: "14", name: "Testing" },
                            – Peter
                            • G
                              goedh452 @peterh
                              @peterh
                              Hi Peter,
                              Great it is working out for you! In the config there is a question that the lower part breaks when it encounters a temperature. Is that right? It should be able to show temperatures as well.
                                peterh @goedh452
                                @goedh452
                                Hi
                                rooms: [
                                I have a “room” plan set in Domoticz that contains various virtual devices, if i add a temperature device to it, the list of devices shown in MM stops at that device.
                                With “mote” (temp & humidity) sensor in the room
                                With no mote in the room.
                                Please note: I have used custom css to shrink the members of the room to a more compact left justified list, rather than spread across the whole width of the screen.
                                regards Peter
                                G 2 Replies Last reply Reply Quote 0
                                • G
                                  goedh452 @peterh
                                  @peterh
                                  I can have a look at the temp/hum issue. I have several of these sensors myself and they do work in this layout. I would need the JSON-output of the specified device to figure out the problem.
                                  • G
                                    goedh452 @peterh
                                    @peterh
                                    I tried, but am unable to reproduce your problem. If you would like me to have a look, please post the JSON result for the device “mote”.
                                      peterh @goedh452
                                      @goedh452
                                      Hi
                                      Sorry for the delayed response.
                                      It appears that the issue occurs when there is no temperature or humidity data in the json output.
                                      the sensor had no data while i was initially testing. After collecting some data it works as expected.
                                      sample json data:
                                      pi@MM-lite:~$ curl "http://10.60.2.252:8080/json.htm?type=devices&rid=196"
                                              "ActTime" : 1623221642,
                                              "AstrTwilightEnd" : "18:46",
                                              "AstrTwilightStart" : "05:45",
                                              "CivTwilightEnd" : "17:46",
                                              "CivTwilightStart" : "06:45",
                                              "DayLength" : "10:07",
                                              "NautTwilightEnd" : "18:16",
                                              "NautTwilightStart" : "06:15",
                                              "ServerTime" : "2021-06-09 14:54:02",
                                              "SunAtSouth" : "12:16",
                                              "Sunrise" : "07:12",
                                              "Sunset" : "17:19",
                                              "app_version" : "2020.2 (build 12917)",
                                              "result" :
                                                              "AddjMulti" : 1.0,
                                                              "AddjMulti2" : 1.0,
                                                              "AddjValue" : 0.0,
                                                              "AddjValue2" : 0.0,
                                                              "BatteryLevel" : 255,
                                                              "CustomImage" : 0,
                                                              "Data" : "0, 27.0",
                                                              "Description" : "temperature and humidity in my office. polled from mqtt",
                                                              "Favorite" : 0,
                                                              "HardwareDisabled" : false,
                                                              "HardwareID" : 3,
                                                              "HardwareName" : "virtual hardware",
                                                              "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                                                              "HardwareTypeVal" : 15,
                                                              "ID" : "14114",
                                                              "LastUpdate" : "2021-01-04 17:58:14",
                                                              "Name" : "mote",
                                                              "Notifications" : "false",
                                                              "PlanID" : "0",
                                                              "PlanIDs" :
                                                              "Protected" : false,
                                                              "ShowNotifications" : true,
                                                              "SignalLevel" : "-",
                                                              "SubType" : "THGN122/123/132, THGR122/228/238/268",
                                                              "Timers" : "false",
                                                              "Type" : "Temp + Humidity",
                                                              "TypeImg" : "temperature",
                                                              "Unit" : 1,
                                                              "Used" : 1,
                                                              "XOffset" : "0",
                                                              "YOffset" : "0",
                                                              "idx" : "196"
                                              "status" : "OK",
                                              "title" : "Devices"
                                      With Temperature and humidity
                                              "ActTime" : 1623222662,
                                              "ServerTime" : "2021-06-09 15:11:02",
                                              "Sunset" : "17:19",
                                              "result" :
                                                              "AddjMulti" : 1.0,
                                                              "AddjMulti2" : 1.0,
                                                              "AddjValue" : 0.0,
                                                              "AddjValue2" : 0.0,
                                                              "BatteryLevel" : 14,
                                                              "CustomImage" : 0,
                                                              "Data" : "32.2 C, 34 %",
                                                              "DewPoint" : "14.35",
                                                              "Favorite" : 0,
                                                              "HardwareID" : 3,
                                                              "HaveTimeout" : false,
                                                              "Humidity" : 34,
                                                              "HumidityStatus" : "Comfortable",
                                                              "ID" : "14114",
                                                              "LastUpdate" : "2021-06-09 15:10:35",
                                                              "Name" : "mote",
                                                              "PlanID" : "0",
                                                              "PlanIDs" :
                                                              "Temp" : 32.19,
                                                              "Timers" : "false",
                                                              "Unit" : 1,
                                                              "Used" : 1,
                                                              "XOffset" : "0",
                                                              "YOffset" : "0",
                                                              "idx" : "196",
                                                              "trend" : 1
                                              "status" : "OK",
                                              "title" : "Devices"
                                      mote sensor appears now, above the snake enclosure light.
                                      thanks again for your attention
                                        maxs
                                        Hi tanks for great module. I have a small problem with the counter today from the power consumption. this doesn’t show me the amount of use of the day. Gas and water working fine. see screenshot. Do you have a solution, or where I have to search? !!Schermafbeelding 2021-07-24 om 20.59.12.jpg
                                        • majsoftM
                                          majsoft @Sp0nsje
                                          • G
                                            goedh452 @maxs
                                            @maxs
                                            Alle data is retrieved from the JSON response. Could you post it for the electricity counter?
                                            • 3 / 7
