    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 120.7k Views 16 Watching
    • G
      goedh452 @maxs
      @maxs
      Alle data is retrieved from the JSON response. Could you post it for the electricity counter?
      • majsoftM
        majsoft
        Hi everyone, please help with setting up customs.css
        Can anyone advise me how to change the font and icon size only for the first three rooms? (Red marked)
        I would also need to delete the dividing lines marked in green.
        I will be very grateful for more detailed advice.
        customs.css
        .domoCellState {
          text-align: right;
        vertical-align: center;
          padding-left: 10px;
        font-size: 300%; 			/* velikost čísla teploměru */
        color: #FFFFFF;
        line-height: 100%;
        .domoIconDiv {
          padding-right: 5px;
          font-size: 200%;                        /* velikost ikony teploměru */
        .domoCell {
          text-align: left;
         font-size: 200%;			/* velikost pisma popisku teplomeru - vedle ikony teploměru */
        line-height: 100%;
        .domoRoomCell {
          padding-right: 20px;
        font-size: 0%;			/* velikost pisma nadpisu room */
        Config.js
        the room numbers for which I would like to change the font size are idx 1, 8, 9
          module: "MMM-Domoticz-ext",
          position: "bottom_bar",
            apiBase: "192.168.2.80",
            apiPort: "8081",
                updateInterval: 15,
        displayType: "room",
                  alwaysShowDashboard: false,
                  alwaysShowActions: false,
                  showButtons: false,
                         horizontal: true,
                  columnCount: 3,
                  dashboardColumnCount: 12,
                  maxTitleLength: 18,
             rooms: [
              { idx: "1" },
        { idx: "9" },
        { idx: "8" },
        { idx: "11" },
        { idx: "12" },
        { idx: "13" },
        Another question is whether it is possible to replace the character C with ° (character Celsius)
        G majsoftM 2 Replies Last reply Reply Quote 0
        • G
          goedh452 @majsoft
          @majsoft
          I don’t think it is possible to just change the font for the first lines. All are in the same class.
          • majsoftM
            majsoft @majsoft
            @majsoft
            How to remove the lines (marked in green) I have already come.
            using this code
            hr.domoDivider {
              display: none;
            If it is not possible to change the font size of only the first three sensors, it is possible to run 2 instances of the module in config.js, but I do not know how to distinguish these instances in customs.css
            • G
              goedh452 @majsoft
              @majsoft
              I think this is also not possible, but I’m not an css expert. Maybe others have soms ideas.
              You could create your own module based on the code and modify that css.
              majsoftM 3 Replies Last reply Reply Quote 0
              • majsoftM
                majsoft @goedh452
                @goedh452
                yes, I’m just trying to create a new mmm-domoticz-ext-2 module, but even if I replace the text mmm-domoticz-ext with mmm-domoticz-ext-2 in all files, it doesn’t work. then it would be easy in CSS to assign a font size to each module. I’m not a programmer either. I have to follow the trial and error method
                • majsoftM
                  majsoft @goedh452
                  @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
                  @majsoft
                  I can’t get the copied module up and running, it still reports loading. Basic methods for copying a module fail. Can you advise me how to copy the module?
                      apiPort: "8081",
                          updateInterval: 15,
                            showButtons: false,
                                   horizontal: true,
                            columnCount: 3,
                            maxTitleLength: 18,
                   	     rooms: [
                        { idx: "1" },
                  { idx: "9" },
                  { idx: "8" },
                    module: "MMM-Domoticz-ext2",
                      apiPort: "8081",
                          updateInterval: 20,
                            showButtons: false,
                                   horizontal: true,
                            columnCount: 3,
                            maxTitleLength: 18,
                   	     rooms: [
                        { idx: "11" },
                  { idx: "12" },
                  { idx: "13" },
                  majsoftM 1 Reply Last reply Reply Quote 0
                  • majsoftM
                    majsoft @majsoft
                    @majsoft
                    I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
                    If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
                      maxs @goedh452
                      @goedh452
                      Sorry for late reaction. Here is the file you request. I think I uploaded wrong, but I hope you can do something with it.
                      “ActTime” : 1630944398,
                      “AstrTwilightEnd” : “22:12”,
                      “AstrTwilightStart” : “04:58”,
                      “CivTwilightEnd” : “20:46”,
                      “CivTwilightStart” : “06:24”,
                      “DayLength” : “13:14”,
                      “NautTwilightEnd” : “21:27”,
                      “NautTwilightStart” : “05:43”,
                      “ServerTime” : “2021-09-06 18:06:38”,
                      “SunAtSouth” : “13:35”,
                      “Sunrise” : “06:58”,
                      “Sunset” : “20:12”,
                      “app_version” : “2021.1”,
                      “result” :
                      “AddjMulti” : 1.0,
                      “AddjMulti2” : 1.0,
                      “AddjValue” : 0.0,
                      “AddjValue2” : 0.0,
                      “BatteryLevel” : 255,
                      “Counter” : “5077.807”,
                      “CounterDeliv” : “0.000”,
                      “CounterDelivToday” : “18446744073709552.000 kWh”,
                      “CounterToday” : “2.151 kWh”,
                      “CustomImage” : 0,
                      “Data” : “2794757;2283050;6;0;123;0”,
                      “Description” : “”,
                      “Favorite” : 1,
                      “HardwareDisabled” : false,
                      “HardwareID” : 2,
                      “HardwareName” : “Smart Meter”,
                      “HardwareType” : “P1 Smart Meter USB”,
                      “HardwareTypeVal” : 4,
                      “HaveTimeout” : false,
                      “ID” : “0001”,
                      “LastUpdate” : “2021-09-06 18:06:38”,
                      “Name” : “Power”,
                      “Notifications” : “false”,
                      “PlanID” : “4”,
                      “PlanIDs” :
                      “Protected” : false,
                      “ShowNotifications” : true,
                      “SignalLevel” : “-”,
                      “SubType” : “Energy”,
                      “SwitchTypeVal” : 0,
                      “Timers” : “false”,
                      “Type” : “P1 Smart Meter”,
                      “TypeImg” : “counter”,
                      “Unit” : 1,
                      “Usage” : “123 Watt”,
                      “UsageDeliv” : “0 Watt”,
                      “Used” : 1,
                      “XOffset” : “0”,
                      “YOffset” : “0”,
                      “idx” : “1”
                      “status” : “OK”,
                      “title” : “Devices”
                      • G
                        goedh452 @maxs
                        @maxs
                        I see what’s the problem. For the usage per day the CounterToday and CounterDelivToday are substracted. The value for your CounterDelivToday has a very strange value. Only option would be that such values are set to 0 in the code.
                          maxs @goedh452
                          @goedh452
                          can I do that by my own? I have idee how, but maybe with some help from you? Thans for quick answer.
                          G 2 Replies Last reply Reply Quote 0
                          • G
                            goedh452 @maxs
                            @maxs I’ll see what I can do and let you know when you can download the new code from GitHub.
                              maxs @goedh452
                              @goedh452
                              Thanks, that would be nice. I really like your module.
                              • G
                                goedh452 @maxs
                                @maxs
                                I made some changes in the code. Can you download the latest version from GitHub and add the option enableReturn to the utility device? When set to false the return values are ignored and the correct value should be displayed. I’m unable to test properly since my device doesn’t generate this strange value.
                                enableReturn: false,
                                My config example looks like this:
                                devices: [
                                                idx: "304",
                                                deviceHeader: "Elektriciteit",
                                                useHeaderSymbol: true,
                                                headerSymbol: "plug",
                                                counterTodayLabel: "Vandaag",
                                                counterTodayAppendText: "kWh",
                                                gaugeMinValue: -3000,
                                                gaugeMaxValue: 3000,
                                                gaugeAppendText: "watt",
                                                gaugeWidth: 200,
                                                lineWidth: 16,
                                                markerWidth: 16,
                                                markerColor: "#F4D03F"
                                  maxs @goedh452
                                  @goedh452
                                  Thanks for quick reply. Test it and works like a charm.
                                  :thumbs_up:
                                  Thanks.
                                  • majsoftM
                                    majsoft @goedh452
                                      Manu663
                                      Hi all, I’m an old geek who’s trying to keep up but learning by doing without initial training is long, difficult and the age of my brain cells doesn’t help me much.
                                      Could you please post some examples of your MMM-Domoticz-ext config? (from the simplest to the most elaborate, I’ll take anything that comes along!)
                                      It would help me to test different configurations and customize mine.
                                      Thanks in advance !
                                      • G
                                        goedh452 @Manu663
                                        @manu663
                                        Please see the GitHub-page for some examples: MMM-Domoticz-ext
                                          Manu663 @goedh452
                                          @goedh452 Thank you for your quick reply, it’s much appreciated!
                                          I have read the whole github unfortunately, I don’t manage to get a convincing result. It doesn’t matter, I’ll calm down and read the github again over a cup of coffee and start all over again.
                                          But if others have examples, I’ll take them anyway ;-)
                                            Manu663 @Manu663
                                            Once I calmed down and reread everything from the beginning I finally managed to get a nice result.
                                            I feel ashamed that I called for help when it was just a silly syntax error. :sad_but_relieved_face:
                                            Anyway, thank you for the marvelous job done there !
                                            • 4 / 7
