    Changing MMM-Traffic into using TomTom API
    17 Posts 2 Posters 7.0k Views 2 Watching
      rxlDavid @sdetweil
      hi,
      I changed the API Return, there is an option to get it back in JSON.
      What do you mean with write message to the console? & where/when should I execute “npm start >somefile.txt”
      S 3 Replies Last reply
        sdetweil @rxlDavid
        @rxldavid
        write message to console
        console,log(“some message”+variable+…)
          sdetweil @rxlDavid
          @rxldavid u probably use pm2, so
          pm2 stop all
          then
          then u can
          ctrl-c to end
          repeat til working
            sdetweil @rxlDavid
            @rxldavid the json data u posted is not valid… something is missing after the trailing comma
            R 1 Reply Last reply
              rxlDavid @sdetweil
              I know, it was just an extinct, since it used private Data,
              I updated it to the full return with random Data
                sdetweil @rxlDavid
                @rxldavid if u put it thru the formatter
                  "formatVersion": "0.0.12",
                  "routes": [
                      "summary": {
                        "lengthInMeters": 1147,
                        "travelTimeInSeconds": 140,
                        "trafficDelayInSeconds": 0,
                        "trafficLengthInMeters": 0,
                        "departureTime": "2021-09-19T17:16:54+02:00",
                        "arrivalTime": "2021-09-19T17:19:14+02:00"
                      "legs": [
                          "summary": {
                          "points": [
                              "latitude": 52.5093,
                              "longitude": 13.42937
                              "latitude": 52.50904,
                              "longitude": 13.42913
                              "latitude": 52.50895,
                              "longitude": 13.42904
                              "latitude": 52.50868,
                              "longitude": 13.4288
                              "latitude": 52.5084,
                              "longitude": 13.42857
                              "latitude": 52.50816,
                              "longitude": 13.42839
                              "latitude": 52.50791,
                              "longitude": 13.42825
                              "latitude": 52.50757,
                              "longitude": 13.42772
                              "latitude": 52.50752,
                              "longitude": 13.42785
                              "latitude": 52.50742,
                              "longitude": 13.42809
                              "latitude": 52.50735,
                              "longitude": 13.42824
                              "latitude": 52.5073,
                              "longitude": 13.42837
                              "latitude": 52.50696,
                              "latitude": 52.50673,
                              "longitude": 13.42961
                              "latitude": 52.50619,
                              "longitude": 13.43092
                              "latitude": 52.50608,
                              "longitude": 13.43116
                              "latitude": 52.50574,
                              "longitude": 13.43195
                              "latitude": 52.50564,
                              "longitude": 13.43218
                              "latitude": 52.50528,
                              "longitude": 13.43299
                              "latitude": 52.50513,
                              "longitude": 13.43336
                              "latitude": 52.505,
                              "longitude": 13.43366
                              "latitude": 52.50464,
                              "longitude": 13.43451
                              "latitude": 52.50451,
                              "longitude": 13.43482
                              "latitude": 52.50444,
                              "longitude": 13.43499
                              "latitude": 52.50418,
                              "longitude": 13.43564
                              "latitude": 52.50364,
                              "longitude": 13.4369
                              "latitude": 52.50343,
                              "longitude": 13.43738
                              "latitude": 52.5033,
                              "longitude": 13.43767
                              "latitude": 52.50275,
                              "longitude": 13.43873
                      "sections": [
                          "startPointIndex": 0,
                          "endPointIndex": 28,
                          "sectionType": "TRAVEL_MODE",
                          "travelMode": "car"
                  rxlDavid @sdetweil
                  this is also the view Tomtom provided me.
                  but I don’t get what I need to change.
                  right now I got the following error in the console:
                  [19.09.2021 17:22.10.688] [ERROR] Failed to fetch git data for MMM-Traffic: Erro r: block timeout reached
                    sdetweil @rxlDavid
                    @rxldavid that is from the updateNotifcation module which has a bug … fixed in next release
                    after u got the data, then what did u do?
                      rxlDavid @sdetweil
                      Sorry, Tomtom provides a website which returns the data.
                      So it wasn’t my MagicMirror returning it
                        sdetweil @rxlDavid
                        @rxldavid javascript provides a built in library call JSON
                        which provides 2 useful functions
                        parse (text) = converts to javascript object
                        stringify(object,routine(most if the time u would use null ),indentation ) = returns string of text
                        so then u could
                        console.log("mesage="+JSON.stringify(pointer_to_data_returned_from_api))
                        to see it on the console (or somefile.txt if u redirect to a file)
                          rxlDavid @sdetweil
                          I do know I think this project is too hard for me lol
                          I now changed this:
                            getCommute: function (api_url) {
                              var self = this;
                              fetch('https://api.tomtom.com/routing/1/calculateRoute/4x.xxx%2C9.xxx%3A4x.xxx%2C9.xx/json?avoid=unpavedRoads&key=<key>')
                          	  .then(console.log('API SUCESS')
                                .then(json => {
                                  self.duration = Math.round(json.routes[0].duration / 60);
                                  self.errorMessage = self.errorDescription = undefined;
                                  self.loading = false;
                                  self.updateDom();
                                .catch(e => {
                                  self.errorMessage = payload.error.message;
                                  self.errorDescription = payload.error.description;
                                  self.updateDom();
                          Now the "loading does not even appear I don’t know if that’s good or bad, but I cant even see my (console.log(‘API SUCESS’) in the .txt
                            sdetweil @rxlDavid
                            @rxldavid ah, you are doing this in the modulename.js side, not node_helper…
                            all messages in the modulename are shown in the developers window console
                            ctrl-shift-i on the MM screen,
                            select the console tab in the window that pops up
                            u can filter to messages from a module by adding some unique part of the module name to the filter field (middle above the list of messages)
                              rxlDavid
                                rxlDavid @sdetweil
                                So I forgot to close a bracket, so now its again showing the Loading screen.
                                I get the following error:
                                What does the :69 mean?
                                Edit: this is line 69
                                 .catch(e => {
                                        Line 69 self.errorMessage = payload.error.message;
                                        self.updateDom();
                                  rxlDavid @rxlDavid
                                  The Same Error accured for Line 70, so I both commented those 2 lines.
                                  Now I get no Error, and the Loading disappeared, it now says:
