    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 243.9k Views 13 Watching
      RedNax Module Developer @jagerpower
      @jagerpower Anything on F12/console?
        jagerpower @RedNax
        @RedNax alt text
        1 error
          @jagerpower Doing a vanilla install… but it’s slow. BEfore you edited your post it showed IUTRECHT148 as your chosen pws… Is that correct? THe wu api returns an error on it.
            jagerpower @RedNax
            @RedNax yes that is correct
              jagerpower @RedNax
              @RedNax /* Magic Mirror Config Sample
              		module: 'MMM-WunderGround',
              		position: 'top_right',  // This can be any of the regions.
                                              // Best results in left or right regions.
                      			apikey: '+++++++++++', // private; don't share!
                      			pws: 'IUTRECHT148;loctype:1',
                      			lang: 'NL',
                      			fctext: '1',
                              		fcdaycount: "5",
                          		fcdaystart: "0",
                          		hourly: '1',
                          		hourlyinterval: "3",
                              		hourlycount: "2"
                @jagerpower Could you omit the loctype ie: IUTRECHT148 without the :loctype:1
                  jagerpower @RedNax
                  @RedNax it’s still stuck on loading
                    @jagerpower try setting pws to ‘pws:IUTRECHT148’ in your config:
                    pws: 'pws:IUTRECHT148',
                      jagerpower @RedNax
                      @RedNax Thank you for this module and help, it works now
                        @jagerpower Thanks and enjoy!!
                          jagerpower @RedNax
                          @RedNax alt text
                          is there a way to remove the time? and get more days (like weather forecast from sunday to saterday?)
                            pugsly
                            Thanks for all the help, its working now with the correct directory and icons in the directory and icon settings in the config.js file.
                            I didn’t realize that the bit temp was also part of this module so I don’t need to call the original weather module for that ether.
                            Great work!!!
                              CommanderB
                              Love this. Thanks. There are a couple of issues I’m working through, trying to help fix. The first is that beaufort icon isn’t showing because this isn’t defined in the CSS files. I would expect it to be in weather-icons-wind.css but its not.
                              Adding the definitions -
                              .wi-wind-beaufort-0:before {
                                content: "\f0b7";
                              .wi-wind-beaufort-1:before {
                                content: "\f0b8";
                              .wi-wind-beaufort-2:before {
                                content: "\f0b9";
                              .wi-wind-beaufort-3:before {
                                content: "\f0ba";
                              .wi-wind-beaufort-4:before {
                                content: "\f0bb";
                              .wi-wind-beaufort-5:before {
                                content: "\f0bc";
                              .wi-wind-beaufort-6:before {
                                content: "\f0bd";
                              .wi-wind-beaufort-7:before {
                                content: "\f0be";
                              .wi-wind-beaufort-8:before {
                                content: "\f0bf";
                              .wi-wind-beaufort-9:before {
                                content: "\f0c0";
                              .wi-wind-beaufort-10:before {
                                content: "\f0c1";
                              .wi-wind-beaufort-11:before {
                                content: "\f0c2";
                              .wi-wind-beaufort-12:before {
                                content: "\f0c3";
                              to MMM-WunderGround.css fixes this.
                                CommanderB
                                The next issue is that the config variable hourlyInterval gets ignored. This can be fixed by changing line 238 to
                                var forecast = this.hourlyforecast[f * this.config.hourlyinterval];
                                  RedNax Module Developer @CommanderB
                                  @CommanderB Thanks for cleaning up my messes! :)
                                  The icons you seek are in the included weather-icons.css. I do agree you’d expect them in weather-icons-wind.css
                                  However it’s entirely possible that MM uses the one weather-icons included in the vendor dir first. They’re not in that one.
                                    content: "\f0b7";
                                    content: "\f0b8";
                                    content: "\f0b9";
                                    content: "\f0ba";
                                    content: "\f0bb";
                                    content: "\f0bc";
                                    content: "\f0bd";
                                    content: "\f0be";
                                    content: "\f0bf";
                                    content: "\f0c0";
                                    content: "\f0c1";
                                    content: "\f0c2";
                                    content: "\f0c3";
                                    pugsly
                                    if you put a copy of weather-icons-wind.css into the vendor/weather-icons folder that should fix it.
                                      @jagerpower You can set hourly to 0 in the config. This will remove the hourly forecasts… You can also adjust fcdaycount to the number of days you want to be shown.
                                        jagerpower @RedNax
                                        @RedNax is it possible to remove the English translation in the alert?
                                          Could be done by manipulating the string, however this might break things when other languages are selected. Could even be dependent on your pws… I’ll have a go at making it configurable…
                                            It’s a bit of a hack, but after getting the new version from github you can define
                                            alerttruncatestring: "english:"
                                            in your config. The alerttext will hen be truncated at the defined word/string
                                            • 2 / 7
