    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 243.9k Views 13 Watching
      jagerpower @RedNax
      @RedNax yes i installed the updates version, when i type 192.168.178.***:8080 in the browser i get an error and i f12 doesn’t work in the black screen
        jagerpower @jagerpower
        @jagerpower said in Weatherunderground - currently - hourly - daily - configurable:
        when i type ip:8080 i get a black screen (i forgot to start mm.sh the first time)
          RedNax Module Developer @jagerpower
          @jagerpower Think i found the issue. The module name on github was Wunderground while it should have been MMM-Wunderground (i’ve now renamed it on git). Since you have MMM-Wunderground in your config.js the MagicMirror can’t find it as the module dir you have is just named Wunderground…
          Quick fix (i hope) is to rename the dir…
            jagerpower @RedNax
            @RedNax you renamed it to MMM-WunderGround but in the config it is MMM-Wunderground, (g,G) does this matter?
              @jagerpower Maybe, i’ve renamed the git again just to be sure :)
                jagerpower @RedNax
                @RedNax ok i fixed the black screen, i changed MMM-Wunderground in the config to MMM-WunderGround, but i now it says loading
                  @jagerpower Anything on F12/console?
                    jagerpower @RedNax
                    @RedNax alt text
                    1 error
                      @jagerpower Doing a vanilla install… but it’s slow. BEfore you edited your post it showed IUTRECHT148 as your chosen pws… Is that correct? THe wu api returns an error on it.
                        jagerpower @RedNax
                        @RedNax yes that is correct
                          jagerpower @RedNax
                          @RedNax /* Magic Mirror Config Sample
                          		module: 'MMM-WunderGround',
                          		position: 'top_right',  // This can be any of the regions.
                                                          // Best results in left or right regions.
                                  			apikey: '+++++++++++', // private; don't share!
                                  			pws: 'IUTRECHT148;loctype:1',
                                  			lang: 'NL',
                                  			fctext: '1',
                                          		fcdaycount: "5",
                                      		fcdaystart: "0",
                                      		hourly: '1',
                                      		hourlyinterval: "3",
                                          		hourlycount: "2"
                            @jagerpower Could you omit the loctype ie: IUTRECHT148 without the :loctype:1
                              jagerpower @RedNax
                              @RedNax it’s still stuck on loading
                                @jagerpower try setting pws to ‘pws:IUTRECHT148’ in your config:
                                pws: 'pws:IUTRECHT148',
                                  jagerpower @RedNax
                                  @RedNax Thank you for this module and help, it works now
                                    @jagerpower Thanks and enjoy!!
                                      jagerpower @RedNax
                                      @RedNax alt text
                                      is there a way to remove the time? and get more days (like weather forecast from sunday to saterday?)
                                        pugsly
                                        Thanks for all the help, its working now with the correct directory and icons in the directory and icon settings in the config.js file.
                                        I didn’t realize that the bit temp was also part of this module so I don’t need to call the original weather module for that ether.
                                        Great work!!!
                                          CommanderB
                                          Love this. Thanks. There are a couple of issues I’m working through, trying to help fix. The first is that beaufort icon isn’t showing because this isn’t defined in the CSS files. I would expect it to be in weather-icons-wind.css but its not.
                                          Adding the definitions -
                                          .wi-wind-beaufort-0:before {
                                            content: "\f0b7";
                                          .wi-wind-beaufort-1:before {
                                            content: "\f0b8";
                                          .wi-wind-beaufort-2:before {
                                            content: "\f0b9";
                                          .wi-wind-beaufort-3:before {
                                            content: "\f0ba";
                                          .wi-wind-beaufort-4:before {
                                            content: "\f0bb";
                                          .wi-wind-beaufort-5:before {
                                            content: "\f0bc";
                                          .wi-wind-beaufort-6:before {
                                            content: "\f0bd";
                                          .wi-wind-beaufort-7:before {
                                            content: "\f0be";
                                          .wi-wind-beaufort-8:before {
                                            content: "\f0bf";
                                          .wi-wind-beaufort-9:before {
                                            content: "\f0c0";
                                          .wi-wind-beaufort-10:before {
                                            content: "\f0c1";
                                          .wi-wind-beaufort-11:before {
                                            content: "\f0c2";
                                          .wi-wind-beaufort-12:before {
                                            content: "\f0c3";
                                          to MMM-WunderGround.css fixes this.
                                            CommanderB
                                            The next issue is that the config variable hourlyInterval gets ignored. This can be fixed by changing line 238 to
                                            var forecast = this.hourlyforecast[f * this.config.hourlyinterval];
                                            • 1 / 7
