    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 236.9k Views 13 Watching
      paviro
      Have you checked your config file with jslint.com?
      – The Doctor
        pugsly
        Yes, no errors. it just goes black. Log just shows Launching Application then stops.
        here is my config file
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
            port: 8080,
            language: 'en',
            timeFormat: 12,
            units: 'imperial',
                    module: 'alert'
                    module: 'clock',
                    position: 'top_left'
                    module: 'calendar',
                    header: 'Family Calendar',
                    position: 'top_left',
                                symbol: 'calendar',
                                url: 'https://xxx/calendar.ics'
                                symbol: 'birthday-cake',
                                url: 'https://xxx/birthdays.ics'
                        timeFormat: 'absolute',
                        urgency: 7
                    module: 'compliments',
                    position: 'lower_third'
                    module: 'currentweather',
                    position: 'top_right',
                        appid: 'xxx'
                    module: 'MMM-WunderGround',
                        apikey: 'xxx',
                        pws: 'locid:KDExxx;loctype:1',
                        fctext: '1',
                        fcdaycount: "5",
                        fcdaystart: "0",
                        hourly: '1',
                        hourlyinterval: "3",
                        hourlycount: "2"
                    module: 'newsfeed',
                    position: 'bottom_bar',
                        feeds: [
                                title: "NBC 10",
                                url: "http://www.nbcphiladelphia.com/news/top-stories/?rss=y&embedThumb=y&summary=y"
                        showSourceTitle: true,
                        showPublishDate: true
                    module: 'MMM-Traffic',
                    position: 'bottom_right',
                    classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                        api_key: 'xxx',
                        mode: 'driving',
                        origin: 'home address',
                        destination: 'work address,
                        route_name: 'Home to Work',
                        changeColor: true,
                        showGreen: false,
                        limitYellow: 10, //Greater than 10% of journey time due to traffic
                        limitRed: 30, //Greater than 30% of journey time due to traffic
                        traffic_model: 'pessimistic',
                        interval: 120000 //2 minutes
                    module: 'MMM-Wunderlist',
                    position: 'bottom_left',  // This can be any of the regions. Best results in left or right regions.
                    header: 'Menu', // This is optional
                        accessToken: 'xxx',
                        clientID: 'xxx',
                        lists: ["Dinner"]
          aubcar
            jagerpower @pugsly
            @pugsly @RedNax i have the same problem, when i start my MM the screen goes black
              RedNax Module Developer @jagerpower
              @jagerpower Did you get the most recent version (with all the icon files)?
              Are you able to use a browser to go to the mm? (ip:8080) and have a look at the console (F12) to see is there’s any messages?
                jagerpower @RedNax
                @RedNax yes i installed the updates version, when i type 192.168.178.***:8080 in the browser i get an error and i f12 doesn’t work in the black screen
                  jagerpower @jagerpower
                  @jagerpower said in Weatherunderground - currently - hourly - daily - configurable:
                  when i type ip:8080 i get a black screen (i forgot to start mm.sh the first time)
                    @jagerpower Think i found the issue. The module name on github was Wunderground while it should have been MMM-Wunderground (i’ve now renamed it on git). Since you have MMM-Wunderground in your config.js the MagicMirror can’t find it as the module dir you have is just named Wunderground…
                    Quick fix (i hope) is to rename the dir…
                      jagerpower @RedNax
                      @RedNax you renamed it to MMM-WunderGround but in the config it is MMM-Wunderground, (g,G) does this matter?
                        @jagerpower Maybe, i’ve renamed the git again just to be sure :)
                          jagerpower @RedNax
                          @RedNax ok i fixed the black screen, i changed MMM-Wunderground in the config to MMM-WunderGround, but i now it says loading
                            @jagerpower Anything on F12/console?
                              jagerpower @RedNax
                              @RedNax alt text
                              1 error
                                @jagerpower Doing a vanilla install… but it’s slow. BEfore you edited your post it showed IUTRECHT148 as your chosen pws… Is that correct? THe wu api returns an error on it.
                                  jagerpower @RedNax
                                  @RedNax yes that is correct
                                    jagerpower @RedNax
                                    @RedNax /* Magic Mirror Config Sample
                                    		position: 'top_right',  // This can be any of the regions.
        // Best results in left or right regions.
                                            			apikey: '+++++++++++', // private; don't share!
                                            			pws: 'IUTRECHT148;loctype:1',
                                            			lang: 'NL',
                                            			fctext: '1',
                                                    		fcdaycount: "5",
                                                		fcdaystart: "0",
                                                		hourly: '1',
                                                    		hourlycount: "2"
                                      @jagerpower Could you omit the loctype ie: IUTRECHT148 without the :loctype:1
                                        jagerpower @RedNax
                                        @RedNax it’s still stuck on loading
                                          @jagerpower try setting pws to ‘pws:IUTRECHT148’ in your config:
                                          pws: 'pws:IUTRECHT148',
                                            jagerpower @RedNax
                                            @RedNax Thank you for this module and help, it works now
                                            • 1 / 7
