    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 243.8k Views 13 Watching
      joerod
      Do I install this as a separate module? When I add it to my config.js file my MM does not start. I have a valid API key.
        pugsly
        I have the same problem, my screen goes black when I run my mirror with this in the config.
          paviro
          Have you checked your config file with jslint.com?
          – The Doctor
            pugsly
            Yes, no errors. it just goes black. Log just shows Launching Application then stops.
            here is my config file
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
                port: 8080,
                language: 'en',
                timeFormat: 12,
                units: 'imperial',
                        module: 'alert'
                        module: 'clock',
                        position: 'top_left'
                        module: 'calendar',
                        header: 'Family Calendar',
                        position: 'top_left',
                                    symbol: 'calendar',
                                    url: 'https://xxx/calendar.ics'
                                    symbol: 'birthday-cake',
                                    url: 'https://xxx/birthdays.ics'
                            timeFormat: 'absolute',
                            urgency: 7
                        module: 'compliments',
                        position: 'lower_third'
                        module: 'currentweather',
                        position: 'top_right',
                            appid: 'xxx'
                        module: 'MMM-WunderGround',
                            apikey: 'xxx',
                            pws: 'locid:KDExxx;loctype:1',
                            fctext: '1',
                            fcdaycount: "5",
                            fcdaystart: "0",
                            hourly: '1',
                            hourlyinterval: "3",
                            hourlycount: "2"
                        module: 'newsfeed',
                        position: 'bottom_bar',
                            feeds: [
                                    title: "NBC 10",
                                    url: "http://www.nbcphiladelphia.com/news/top-stories/?rss=y&embedThumb=y&summary=y"
                            showSourceTitle: true,
                            showPublishDate: true
                        module: 'MMM-Traffic',
                        position: 'bottom_right',
                        classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                            api_key: 'xxx',
                            mode: 'driving',
                            origin: 'home address',
                            destination: 'work address,
                            route_name: 'Home to Work',
                            changeColor: true,
                            showGreen: false,
                            limitYellow: 10, //Greater than 10% of journey time due to traffic
                            limitRed: 30, //Greater than 30% of journey time due to traffic
                            traffic_model: 'pessimistic',
                            interval: 120000 //2 minutes
                        module: 'MMM-Wunderlist',
                        position: 'bottom_left',  // This can be any of the regions. Best results in left or right regions.
                        header: 'Menu', // This is optional
                            accessToken: 'xxx',
                            clientID: 'xxx',
                            lists: ["Dinner"]
              aubcar
                jagerpower @pugsly
                @pugsly @RedNax i have the same problem, when i start my MM the screen goes black
                  RedNax Module Developer @jagerpower
                  @jagerpower Did you get the most recent version (with all the icon files)?
                  Are you able to use a browser to go to the mm? (ip:8080) and have a look at the console (F12) to see is there’s any messages?
                    jagerpower @RedNax
                    @RedNax yes i installed the updates version, when i type 192.168.178.***:8080 in the browser i get an error and i f12 doesn’t work in the black screen
                      jagerpower @jagerpower
                      @jagerpower said in Weatherunderground - currently - hourly - daily - configurable:
                      when i type ip:8080 i get a black screen (i forgot to start mm.sh the first time)
                        @jagerpower Think i found the issue. The module name on github was Wunderground while it should have been MMM-Wunderground (i’ve now renamed it on git). Since you have MMM-Wunderground in your config.js the MagicMirror can’t find it as the module dir you have is just named Wunderground…
                        Quick fix (i hope) is to rename the dir…
                          jagerpower @RedNax
                          @RedNax you renamed it to MMM-WunderGround but in the config it is MMM-Wunderground, (g,G) does this matter?
                            @jagerpower Maybe, i’ve renamed the git again just to be sure :)
                              jagerpower @RedNax
                              @RedNax ok i fixed the black screen, i changed MMM-Wunderground in the config to MMM-WunderGround, but i now it says loading
                                @jagerpower Anything on F12/console?
                                  jagerpower @RedNax
                                  @RedNax alt text
                                  1 error
                                    @jagerpower Doing a vanilla install… but it’s slow. BEfore you edited your post it showed IUTRECHT148 as your chosen pws… Is that correct? THe wu api returns an error on it.
                                      jagerpower @RedNax
                                      @RedNax yes that is correct
                                        jagerpower @RedNax
                                        @RedNax /* Magic Mirror Config Sample
                                        		position: 'top_right',  // This can be any of the regions.
        // Best results in left or right regions.
                                                			apikey: '+++++++++++', // private; don't share!
                                                			pws: 'IUTRECHT148;loctype:1',
                                                			lang: 'NL',
                                                			fctext: '1',
                                                        		fcdaycount: "5",
                                                    		fcdaystart: "0",
                                                    		hourly: '1',
                                                        		hourlycount: "2"
                                          @jagerpower Could you omit the loctype ie: IUTRECHT148 without the :loctype:1
                                            jagerpower @RedNax
                                            @RedNax it’s still stuck on loading
                                            • 1 / 7
