    Calendar Module intermittently stop working
    19 Posts 2 Posters 5.3k Views 2 Watching
      pastormingle @sdetweil
      @sdetweil I am getting the following error "Error in the calendar module. Check logs for more details. I don’t see an error log for the calendar to see what the issue might be… After a few minutes, it will display the calendar. Then after a couple of seconds display the same error again.
        sdetweil @pastormingle
        @pastormingle logs is the output where u start mm. or in the browser log
        ctrl-shift-i, select the console tab
          @sdetweil i check the install log and nothing in it about errors… I also open the debug console but not sure what I am looking for in it.
            @pastormingle red text, or set filter to cal (for calendar)
            and it’s not install log, it’s runtime log
            two places
            the node_helpers report in the
            terminal window where u start mm
            either npm start
            or using pm2
            if pm2, it captures the output
            pm2 logs --lines=100
            to display both error (red text) or mormal ( white text)
                @pastormingle ok, that’s the dev window. now need the other logs
                  @sdetweil fb32ef1c-1281-43b3-82ee-ecae493dfc42-image.png i am getting the following error on the IP and port I changed it but still the same error.
                    @pastormingle
                    do
                    pm2 status
                    pm2 stop all
                    pm2 start x
                    where x is
                    the number of the row in pm2 status output
                    or the name in the row
                      @sdetweil OK… not sure what this is giving me… Now I have only the one instance started…But I still don’t see an error. listen EADDRINUSE: address already in use 127.0.0.1:8087
                        @pastormingle did u do npm start someplace??
                        do
                        ps -ef | grep npm
