    Calendar Module intermittently stop working
    19 Posts 2 Posters 4.5k Views 2 Watching
      pastormingle
      Re: [Calendar Event Display start and end date](/topic/15523/calend```
      code_text
        pastormingle @sdetweil
        @sdetweil thanks for all the help… I have it working now… Just went out and copied a new ics link and that seem to fix it…
          sdetweil @pastormingle
          @pastormingle uh. could you be a bit more descriptive?
            @sdetweil I am getting the following error "Error in the calendar module. Check logs for more details. I don’t see an error log for the calendar to see what the issue might be… After a few minutes, it will display the calendar. Then after a couple of seconds display the same error again.
              @pastormingle logs is the output where u start mm. or in the browser log
              ctrl-shift-i, select the console tab
                @sdetweil i check the install log and nothing in it about errors… I also open the debug console but not sure what I am looking for in it.
                  @pastormingle red text, or set filter to cal (for calendar)
                  and it’s not install log, it’s runtime log
                  two places
                  the node_helpers report in the
                  terminal window where u start mm
                  either npm start
                  or using pm2
                  if pm2, it captures the output
                  pm2 logs --lines=100
                  to display both error (red text) or mormal ( white text)
                      @pastormingle ok, that’s the dev window. now need the other logs
                        @sdetweil fb32ef1c-1281-43b3-82ee-ecae493dfc42-image.png i am getting the following error on the IP and port I changed it but still the same error.
                          @pastormingle
                          do
                          pm2 status
                          pm2 stop all
                          pm2 start x
                          where x is
                          the number of the row in pm2 status output
                          or the name in the row
