    Calendar Module intermittently stop working
    19 Posts 2 Posters 6.6k Views 2 Watching
      pastormingle @sdetweil
      @sdetweil fb32ef1c-1281-43b3-82ee-ecae493dfc42-image.png i am getting the following error on the IP and port I changed it but still the same error.
        sdetweil @pastormingle
        @pastormingle
        do
        pm2 status
        pm2 stop all
        pm2 start x
        where x is
        the number of the row in pm2 status output
        or the name in the row
          @sdetweil OK… not sure what this is giving me… Now I have only the one instance started…But I still don’t see an error. listen EADDRINUSE: address already in use 127.0.0.1:8087
            @pastormingle did u do npm start someplace??
            do
            ps -ef | grep npm
              @sdetweil yes… so i am setup using rdp into the PI and then open up a terminal window then do a npm start in the MM directory.
              P S 2 Replies Last reply Reply Quote 0
                pastormingle @pastormingle
                  @pastormingle but u have pm2 doing the start, so don’t need manual npm start
                    @sdetweil ok i am lost here… Thanks for being patient with me… Yes PM2 start it so I should do that?
                      @pastormingle pm2 should start it at boot… that is what it is for…
                      if not, then fix it with my fixuppm2.sh script from
                      pm2’s job is to start at boot, and KEEP running if it fails…
                      there are lots of command options
                      pm2 --help
                      start, stop,m restart, logs, flush , save
                      u name it
                        @sdetweil thanks for all the help… I have it working now… Just went out and copied a new ics link and that seem to fix it…
                          @pastormingle weird… but glad u got it working
