    Calendar Module intermittently stop working
    19 Posts 2 Posters 6.3k Views 2 Watching
      sdetweil @pastormingle
      @pastormingle uh. could you be a bit more descriptive?
        pastormingle @sdetweil
        @sdetweil I am getting the following error "Error in the calendar module. Check logs for more details. I don’t see an error log for the calendar to see what the issue might be… After a few minutes, it will display the calendar. Then after a couple of seconds display the same error again.
          @pastormingle logs is the output where u start mm. or in the browser log
          ctrl-shift-i, select the console tab
            @sdetweil i check the install log and nothing in it about errors… I also open the debug console but not sure what I am looking for in it.
              @pastormingle red text, or set filter to cal (for calendar)
              and it’s not install log, it’s runtime log
              two places
              the node_helpers report in the
              terminal window where u start mm
              either npm start
              or using pm2
              if pm2, it captures the output
              pm2 logs --lines=100
              to display both error (red text) or mormal ( white text)
                  @pastormingle ok, that’s the dev window. now need the other logs
                    @sdetweil fb32ef1c-1281-43b3-82ee-ecae493dfc42-image.png i am getting the following error on the IP and port I changed it but still the same error.
                      @pastormingle
                      do
                      pm2 status
                      pm2 stop all
                      pm2 start x
                      where x is
                      the number of the row in pm2 status output
                      or the name in the row
                        @sdetweil OK… not sure what this is giving me… Now I have only the one instance started…But I still don’t see an error. listen EADDRINUSE: address already in use 127.0.0.1:8087
                          @pastormingle did u do npm start someplace??
                          do
                          ps -ef | grep npm
                            @sdetweil yes… so i am setup using rdp into the PI and then open up a terminal window then do a npm start in the MM directory.
                            P S 2 Replies Last reply Reply Quote 0
                              pastormingle @pastormingle
                                @pastormingle but u have pm2 doing the start, so don’t need manual npm start
                                  @sdetweil ok i am lost here… Thanks for being patient with me… Yes PM2 start it so I should do that?
                                    @pastormingle pm2 should start it at boot… that is what it is for…
                                    if not, then fix it with my fixuppm2.sh script from
                                    pm2’s job is to start at boot, and KEEP running if it fails…
                                    there are lots of command options
                                    pm2 --help
                                    start, stop,m restart, logs, flush , save
                                    u name it
                                      @sdetweil thanks for all the help… I have it working now… Just went out and copied a new ics link and that seem to fix it…
                                        @pastormingle weird… but glad u got it working
