    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 256.9k Views 33 Watching
    • I
      ianperrin @Arjan
      @Arjan said in MMM-NetworkScanner:
      Is there a way to only show devices if they are off-line.
      Unfortunately, there’s not currently an option to hide online devices via the config. Feel free to raise a issue suggesting this enhancement via GitHub or even a Pull Request :winking_face:
      However, there may be a way to do it using css. Devices which are online should be rendered in a table row (tr) with the class of bright, whilst offline devices will have the class of dimmed.
      I’m away from my mirror right now, so the example below may not be quite right, but try adding the following to the custom.css.
      .MMM-NetworkScanner table tr.bright {
        display: none;
      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
      • I
        ianperrin @Arjan
        Also I’m trying to get there some colour in . But nonmatter what I do, there is only white. What is wrong in my config?
        As I’m away from my mirror at the moment, I can’t test your config, however, there may be an issue with the new color functionality introduced following a recent pull request.
        Until I get chance to look at it, then if you want to color the icons for all offline devices in the same color (e.g. red), then again try adding this to the custom.css file
        .MMM-NetworkScanner table tr.dimmed td i {
          color: #f00;
        To color online devices, change tr.dimmed to tr.bright
        To color the text as well as the icon, remove the trailing td i
        • A
          Arjan Project Sponsor @ianperrin
          @ianperrin : Cool, The colors are working now and the part for only displaying Off-Line is also working.
          Thanks guys.
          • A
            AshDarko @ianperrin
            @ianperrin I am able to reproduce quite often, but it is seemingly running normally?
            i had several of these happen just now:
            MMM-NetworkScanner received SCAN_NETWORK
            MMM-NetworkScanner is performing arp-scan
            TypeError: Cannot read property 'network' of undefined
                at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                at emitTwo (events.js:126:13)
                at Socket.emit (events.js:214:7)
                at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                at _combinedTickCallback (internal/process/next_tick.js:132:7)
                at process._tickCallback (internal/process/next_tick.js:181:9)
              banbutcher
              ive installed network scanner and its working great, im looking to tweek it a bit and was hoping for a little help…
              i have mmm-pages installed with 3 pages and what im hoping for is when the resident is home it displays page 1 and when resident is not home it displays page 3, hoping to add voice triggers later as page 2 is a fullscreen google traffic map, but thats later! i have to get this working first. i also have mmm-remote-control installed as i think i need this, im trying to figure what commands to put in where in this code snippet.
               	                occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                          		vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
              as always your help is very much appreciated! :)
                banbutcher @banbutcher
                @banbutcher
                            occupiedCMD: {notification: 'PAGE_CHANGED', payload:{payload:1}},
                            vacantCMD  : {notification: 'PAGE_CHANGED', payload: {'payload':'2'}},
                i think it something like this but cant figure it out! :/
                  banbutcher
                  Nailed it down…
                              occupiedCMD: {notification: 'PAGE_CHANGED', payload: 2},
                              vacantCMD  : {notification: 'PAGE_CHANGED', payload: 0},
                  happy days, now i can go to bed! :D
                    Christiaan99
                    So i just installed this module. For some reason the name/devices does not get highlighted.
                    This is my code:
                            module: "MMM-NetworkScanner",
                            header: "Wie is er thuis?",
                                devices: [
                                    { macAddress: "xx:xx", name: "Dad", icon: "male"},
                                    { macAddress: "xx:xx", name: "Mum", icon: "female"},
                                    { macAddress: "xx:xx", name: "Son", icon: "male"},
                                    { macAddress: "xx:xx", name: "Daughter", icon: "female"}
                                showUnknown: false
                    Someone know why its not working?
                    • T
                      Tak
                      Hi Guys !
                      I’ve added MMM-NetworkScanner to my MM and I’m not able to see the result as columns.
                      My code in the config.js :
                              position: "top_center",
                              header: "E-Tak Network",
                                  devices: [
                                          ipAddress: "192.168.0.1",
                                          icon: "wifi",
                                          colorStateOnline: "green",
                                          colorStateOffline: "#f00",
                                          ipAddress: "192.168.0.2",
                                          icon: "wifi",
                                          ipAddress: "192.168.0.22",
                                          icon: "desktop",
                                          ipAddress: "192.168.0.29",
                                          icon: "database",
                                          ipAddress: "192.168.0.30",
                                          icon: "database",
                                          ipAddress: "192.168.0.13",
                                          icon: "mobile",
                                          ipAddress: "192.168.0.11",
                                          icon: "mobile",
                                          ipAddress: "192.168.0.16",
                                          icon: "gamepad",
                                          ipAddress: "192.168.0.40",
                                          icon: "tv",
                                  sort: true,
                                  showUnknown: false,
                      			showOffline: true,
                                  showDeviceColums: true,
                      			residents: [],
                                  coloredState: true,
                      			keepAlive: 300,
                                  updateInterval: 5
                      Any idea ?
                      Many thanks for your time !
                      JerryPJ 1 Reply Last reply Reply Quote 0
                      • JerryPJ
                        JerryP @Tak
                        @tak
                        cd ~/
                        sudo apt-get install arp-scan
                        • T
                          Tak @JerryP
                          @jerryp said in MMM-NetworkScanner:
                          @tak
                          cd ~/
                          It’s installed (1st step of the README) …
                          All it’s OK but impossible to display the result in columns. It’s always like a list.
                          (And sometimes, some peripherals are not OK … per ex. my computer)
                          • 6 / 6
