    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 242.4k Views 33 Watching
    • I Offline
      ianperrin @Arjan
      @Arjan said in MMM-NetworkScanner:
      Also I’m trying to get there some colour in . But nonmatter what I do, there is only white. What is wrong in my config?
      As I’m away from my mirror at the moment, I can’t test your config, however, there may be an issue with the new color functionality introduced following a recent pull request.
      Until I get chance to look at it, then if you want to color the icons for all offline devices in the same color (e.g. red), then again try adding this to the custom.css file
      .MMM-NetworkScanner table tr.dimmed td i {
        color: #f00;
      To color online devices, change tr.dimmed to tr.bright
      To color the text as well as the icon, remove the trailing td i
      "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
        Arjan Project Sponsor @ianperrin
        @ianperrin : Cool, The colors are working now and the part for only displaying Off-Line is also working.
        Thanks guys.
          AshDarko @ianperrin
          @ianperrin I am able to reproduce quite often, but it is seemingly running normally?
          i had several of these happen just now:
          MMM-NetworkScanner received SCAN_NETWORK
          MMM-NetworkScanner is performing arp-scan
          TypeError: Cannot read property 'network' of undefined
              at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
              at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
              at emitTwo (events.js:126:13)
              at Socket.emit (events.js:214:7)
              at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
              at _combinedTickCallback (internal/process/next_tick.js:132:7)
              at process._tickCallback (internal/process/next_tick.js:181:9)
            banbutcher
            ive installed network scanner and its working great, im looking to tweek it a bit and was hoping for a little help…
            i have mmm-pages installed with 3 pages and what im hoping for is when the resident is home it displays page 1 and when resident is not home it displays page 3, hoping to add voice triggers later as page 2 is a fullscreen google traffic map, but thats later! i have to get this working first. i also have mmm-remote-control installed as i think i need this, im trying to figure what commands to put in where in this code snippet.
             	                occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                        		vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
            as always your help is very much appreciated! :)
              banbutcher @banbutcher
              @banbutcher
                          occupiedCMD: {notification: 'PAGE_CHANGED', payload:{payload:1}},
                          vacantCMD  : {notification: 'PAGE_CHANGED', payload: {'payload':'2'}},
              i think it something like this but cant figure it out! :/
                banbutcher
                Nailed it down…
                            occupiedCMD: {notification: 'PAGE_CHANGED', payload: 2},
                            vacantCMD  : {notification: 'PAGE_CHANGED', payload: 0},
                happy days, now i can go to bed! :D
                  Christiaan99
                  So i just installed this module. For some reason the name/devices does not get highlighted.
                  This is my code:
                          module: "MMM-NetworkScanner",
                          header: "Wie is er thuis?",
                              devices: [
                                  { macAddress: "xx:xx", name: "Dad", icon: "male"},
                                  { macAddress: "xx:xx", name: "Mum", icon: "female"},
                                  { macAddress: "xx:xx", name: "Son", icon: "male"},
                                  { macAddress: "xx:xx", name: "Daughter", icon: "female"}
                              showUnknown: false
                  Someone know why its not working?
                  • T Offline
                    Tak
                    Hi Guys !
                    I’ve added MMM-NetworkScanner to my MM and I’m not able to see the result as columns.
                    My code in the config.js :
                            position: "top_center",
                            header: "E-Tak Network",
                                devices: [
                                        ipAddress: "192.168.0.1",
                                        icon: "wifi",
                                        colorStateOnline: "green",
                                        colorStateOffline: "#f00",
                                        ipAddress: "192.168.0.2",
                                        icon: "wifi",
                                        ipAddress: "192.168.0.22",
                                        icon: "desktop",
                                        ipAddress: "192.168.0.29",
                                        icon: "database",
                                        ipAddress: "192.168.0.30",
                                        icon: "database",
                                        ipAddress: "192.168.0.13",
                                        icon: "mobile",
                                        ipAddress: "192.168.0.11",
                                        icon: "mobile",
                                        ipAddress: "192.168.0.16",
                                        icon: "gamepad",
                                        ipAddress: "192.168.0.40",
                                        icon: "tv",
                                sort: true,
                                showUnknown: false,
                    			showOffline: true,
                                showDeviceColums: true,
                    			residents: [],
                                coloredState: true,
                    			keepAlive: 300,
                                updateInterval: 5
                    Any idea ?
                    Many thanks for your time !
                    JerryPJ 1 Reply Last reply Reply Quote 0
                    • JerryPJ Offline
                      JerryP @Tak
                      @tak
                      cd ~/
                      sudo apt-get install arp-scan
                      • T Offline
                        Tak @JerryP
                        @jerryp said in MMM-NetworkScanner:
                        @tak
                        cd ~/
                        It’s installed (1st step of the README) …
                        All it’s OK but impossible to display the result in columns. It’s always like a list.
                        (And sometimes, some peripherals are not OK … per ex. my computer)
                        • 6 / 6
