updatenotification seems not to work
Hello!
I have a problem with default module updatenotification and need your help.{ module: "updatenotification", position: "top_bar", ignoreModules: ["MMM-NewPIR"] },With this configuration I assume not to get update notification for the module MMM-NewPIR anymore.
But this happen since yesterday evening :angry_face:
Thanks for your help!
Hi, it’s not related to
updatenotificationjust update the module
@bdream as u can see, he provides his own update notification function
@sdetweil with a bug lol :)
The problem is, I Love the Module :beaming_face_with_smiling_eyes:
But wach time I have to Update I Run in Problems I have to rebuild the MM.I wanted only geht rid of These Messages and stay withbthe Version of NewPIR euch Run perfectly in NY Environment.
@bugsounet I had already an post in your community where you stated I should not use your module what is not the best option to me
Is there a option to hide notifications regarding the NewPIR module?
Or do I mistakes using the updatenotification module? -
@bdream the built in updatenotification module provides a modulename filter…
however HIS module is the one issuing the message and there appears to be NO mechanism to turn off the update notice
Thanks @sdetweil for clarification!
I’m back to start now and search a module working with PIR to shut monitor off and on. After a time I got NewPIR running and I was quite happy. Now I’m unhappy about the way of this module running outside the normal way modules working for MM.
Any idea?
@bdream said in updatenotification seems not to work:
see how he does it in his screen module and copy those commands to some other pir module…
https://forum.magicmirror.builders/topic/15288/face-recognizes-display-on-off/7?_=1635974008253
