    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
    • A
      Alyx
      Hi Sam,
      I installed this just there on a fresh image and MM install. All good except my web-view is blank. Well the title comes up with the light brown background but there’s no content beyond that.
      Do I need to begin installing other modules in tandem with this?
        sdetweil @Alyx
        @alyx no… should work as is for the defaults…
        let me look
        • A
          Alyx @sdetweil
          @sdetweil Sure what file/ image do you want to see?
            sdetweil @Alyx
            @alyx hang on… let me test here… I am working on other fixes…
            • A
              Alyx @sdetweil
              @sdetweil no worries cheers buddy lemme know if you need anything
                sdetweil @Alyx
                @alyx did you do the npm install in the module folder?? I need libs installed
                http://mmip:mmport/modules/MMM-Config/review
                I got
                • A
                  Alyx @sdetweil
                  @sdetweil Yep I did it within the MMM-Config directory, did it again there with no luck. Got some audit issues for npm but nothing big
                  A S 2 Replies Last reply Reply Quote 0
                  • A
                    Alyx @Alyx
                    @alyx actually i had a harder look, does this seem important?
                    smartmirror@smartmirror-ThinkCentre-M72e:~/MagicMirror/modules/MMM-Config$ sudo npm install
                    npm WARN lifecycle mmm-config@1.0.0~postinstall: cannot run in wd mmm-config@1.0.0 node exec_script.js ./postinstall:postinstall.cmd (wd=/home/smartmirror/MagicMirror/modules/MMM-Config)
                    npm WARN mmm-config@1.0.0 No repository field.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
                    audited 136 packages in 1.22s
                    7 packages are looking for funding
                    run npm fund for details
                    found 3 moderate severity vulnerabilities
                    run npm audit fix to fix them, or npm audit for details
                      sdetweil @Alyx
                      @alyx ok, add debug:true
                      to my module def in config.js
                      (stop any pm2 version running, pm2 stop all)
                      then start MM like this
                      npm start >somefile.txt
                      there are all kinds of interesting problems with other modules, but none on the base that I know of.
                      send me the somefile.txt and the defaults. js from the MMM-Config folder… it is constructed from the modules installed
                      same userid as here at gmail
                        sdetweil @Alyx
                        @alyx no… all useless messages we cannot do anything about
                        wait… is this windows?
                          sdetweil @Alyx
                          @alyx said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                          sudo npm install
                          NEVER EVER use sudo on any MM command…
                          delete my module folder and git clone and then npm install
                          • A
                            Alyx @sdetweil
                            @sdetweil So I did as you said and the npm run is stuck loading for a while and the text file is empty.
                            Now I’m running in server mode if that matters? I used npm run server >somefile.txt
                              sdetweil @Alyx
                              @alyx but you used sudo, which messed things up… permissions as root when we need user level…
                              please delete my module folder, and reinstall without sudo…
                              you MAY have messed up the rest of the MM files too…
                              linux has very strict permissions
                              the postinstall failed which moves files to the right places…
                              • A
                                Alyx @sdetweil
                                @sdetweil I used sudo because some package files reported back errors and that I dont have the required permissions?
                                  sdetweil @Alyx
                                  @alyx probably cause you used sudo before…
                                  so, I’d start over again… delete the MM folder
                                  and run my install script, then add my module and npm install in its folder…
                                  A D 2 Replies Last reply Reply Quote 0
                                  • A
                                    Alyx @sdetweil
                                    @sdetweil ok I flash reinstalled MM (worryingly good at it now…) and it seems to be working :)
                                    The config pops up on the webpage correctly and all.
                                    Thanks Sam!
                                      Dinschal @sdetweil
                                      @sdetweil hi sam, i hope you haven’t much work from my issues :/ can you tell me if you have a solution? at this time i had to deinstall your module to finish my project for university but i want to use it again ;)
                                        sdetweil @Dinschal
                                        @dinschal I have 2 of the 3 fixed I think, but not finished testing… I would just skip using for now… sorry… you found some good ones…
                                          Dinschal @sdetweil
                                          @sdetweil oh its totally fine ;) just tell me when you finished ;)
                                            sdetweil @Dinschal
                                            @dinschal so, 3 problems (all issued opened on the module github page
                                            1. timeFormat was changed to a string, easy, done
                                              https://github.com/sdetweil/MMM-Config/issues/27
                                            2. changed parm for clock was not saved… in progress,
                                              https://github.com/sdetweil/MMM-Config/issues/29
                                            3. weather lost parms on save. fixed I think. this takes a special schema file to expose the providers parameters. (this schema file is to make the UI correct, above what I can do to discover the variables)
                                              https://github.com/sdetweil/MMM-Config/issues/28
                                            I save the generated on (little script provided to do that, upgraded cause of this problem to allow just ONE modules info to be saved) and then customize it to the module…
                                            I can ship some (I will for this) , but if the module author ships that is good too (won’t happen for base)
                                            • 14
                                            • 15
                                            • 7 / 15
