    module not found error loading module in MagicMirror
    41 Posts 12 Posters 54.9k Views 14 Watching
      sdetweil @MacG
      @macg as for the cert error, not the mm code at all
      the certificate authority cert expired and electron didn’t handle it. chromium did
      but we have to upgrade electron to a version that works, and drag along all the other stuff
      libs not found I already explained
      welcome to the world of open source
      in my career at IBM there was one cardinal rule
      never EVER make changes that break existing apps.
      same data in produces the same data out, always.
      u made a mistake?! oops, somehow have to make a DIFFERENT input to get a different output.
      it takes work, and thought and time.
      but developers and customers can work on new value instead of costly rework
      in the new internet world time is critical, so ship, and fix as fast as u can, breaking changes need to be DOCUMENTED. what a relief THAT is for users and customers…!
      and, stuff that can’t keep up will be discarded ‘quickly’…, yeh, sure… hahahaha… customers think that makes their life easier too.
        MacG @sdetweil
        @sdetweil I understand that some authors do not use the current libs. The “strange” referred to the fact that I have no problems with MMM-DWD-WarnWeather, but others have to install the module “request”.
        Open source is both a curse and a blessing. Now everything works again and MM’s layout changes to the clock module were also quickly undone. :slightly_smiling_face:
          sdetweil @MacG
          @macg said in fix for black screen in 2.16 and later:
          did u npm install request in the mm folder, or in a module folder where there was no package.json, the latter ends up putting it in the mm/node_modules, the same as the former
          mumblebajM M 2 Replies Last reply
          • mumblebajM
            Maybe this can help some users.
            The following will search all *.js files in the modules folder for the reference of request. You can then just enter the module folders and install as per @sdetweil suggestion above. The same can be done for the other missing modules.
            grep -r -E '('request')' ~/MagicMirror/modules/*/*.js
            or search for multiple problem modules
            grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
            Produces the following:
              sdetweil @mumblebaj
              @mumblebaj and then pull off the module name and scan it’s package.json to see if it’s referenced
              S L kusselinK 3 Replies Last reply
                MacG @sdetweil
                @sdetweil said in fix for black screen in 2.16 and later:
                I installed it the way you suggested. In the two module folders with the addition of package.json (npm init -y) and then npm install request. The MMM-DWD-WarnWeather worked on my mirror from the beginning after updating to MM2.17.
                  I enhanced my upgrade script to do all this for all installed modules…
                  • L
                    levon @sdetweil
                    @sdetweil @mumblebaj Thank you two for helping me solve this problem after the last update - I spent a LOT of time looking for the solution that you two helped me (the grep made it easier to find the right modules), the two commands were what fixed it.
                    Will I have to do this again with the next update?
                      sdetweil @levon
                      @levon maybe. but if you use my upgrade script, it will do the fixes for you
                      see
                      L A 2 Replies Last reply
                      • L
                        levon @sdetweil
                        @sdetweil Thanks … I will give this a try next time I’m updating. I thought I had tried it before, but perhaps not. I appreciate you sharing this.
                        • A
                          Arena @sdetweil
                          @sdetweil I did everything as you said, but …
                          [17.12.2021 04:05.03.723] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                          Require stack:
                          • /home/pi/MagicMirror/modules/MMM-bitcoin/node_helper.js
                            sdetweil @Arena
                            @arena and , what is the module/library u need to install?
                            A 1 Reply Last reply
                            • A
                              Arena @sdetweil
                              @sdetweil fiddled all day today and figured out
                              it turned out I did not install or update the dependencies inside the module
                              sorry, thanks
                              • kusselinK
                                kusselin @sdetweil
                                @sdetweil Hello everyone, I haven’t been here for a while and my Magic Mirror was switched off…after I switched it on again I made updates to the modules via remote…but I still don’t have any display for some modules like Tankerkönig…when I start the Mirror it always says “Modules cannot be loaded”.
                                Now, as described by sdetweil, there are commands that you have to execute in the modules in question…but unfortunately I haven’t quite understood how I have to do this in the right order?
                                It would be really nice if you could explain to me how I have to proceed in order to display the modules again, such as Tankerkönig or mmm-fuel.
                                Thank you very much in advance for your help.
                                Greetings
                                Kussel
                                i don´t understand that here:
                                npm install ???
                                where ??? is the library noted in the message Cannot find module ‘???’
                                | in the example message above, ??? is request
                                to find this message, look in the output of npm start. or if you use pm2 to launch mm do
                                pm2 logs --lines=50
                                how do I proceed exactly?
                                pi@raspberrypi:~/MagicMirror/modules/MMM-Tankerkoenig $ npm init -y
                                Wrote to /home/pi/MagicMirror/modules/MMM-Tankerkoenig/package.json:
                                  "name": "MMM-Tankerkoenig",
                                  "version": "1.0.0",
                                  "description": "This is a module for the [MagicMirror²](https://github.com/MichMich/MagicMirror/) which displays a fuel prices from [Tankerkoenig](https://www.tankerkoenig.de/).",
                                  "main": "MMM-Tankerkoenig.js",
                                  "scripts": {
                                    "test": "echo \"Error: no test specified\" && exit 1"
                                  "repository": {
                                    "type": "git",
                                    "url": "git+https://github.com/terenc3/MMM-Tankerkoenig.git"
                                  "keywords": [],
                                  "author": "",
                                  "license": "ISC",
                                  "bugs": {
                                    "url": "https://github.com/terenc3/MMM-Tankerkoenig/issues"
                                  "homepage": "https://github.com/terenc3/MMM-Tankerkoenig#readme"
                                  sdetweil @kusselin
                                  @kusselin find the messages output by mm
                                  search the messages for one like shown (without the ???)
                                  find the name of the library in quotes (now u have ???)
                                  issue a command using that info
                                  kusselinK 1 Reply Last reply
                                  • kusselinK
                                    kusselin @sdetweil
                                    @sdetweil thank you…it´s working now.
                                    • L
                                      LMAC
                                      I ran the command as recommended (request was my error as well). I now have this error and MM will not load:
                                      A JavaScript error occurred in the main process
                                      Uncaught Exception:
                                      Error: Cannot find module ‘logger’
                                      Require stack:
                                      • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                                        at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                        at Module._load (node:internal/modules/cjs/loader:785:27)
                                        at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                                        at Module.require (node:internal/modules/cjs/loader:1012:19)
                                        at require (node:internal/modules/cjs/helpers:94:18)
                                        at Object. (/home/pi/MagicMirror/js/app.js:13:13)
                                        at Module._compile (node:internal/modules/cjs/loader:1116:14)
                                        at Object.Module._extensions…js (node:internal/modules/cjs/loader:1169:10)
                                        sdetweil @LMAC
                                        @lmac well you ran it in the wrong place… oops
                                        do this
                                        rm -rf node_modules
                                        rm package-lock.json
                                        npm install
                                        then for whatever module was causing problem
                                        cd ~/MagicMirror/modules/modulename
                                        do the same last 3 steps as above
                                        AND THEN
                                        npm install request --save
                                          DarrenHill
                                          Just wanted to say thanks for the fix here.
                                          Did an update and hit exactly this with MMM-GmailFeed and the request module.
                                          Installed it back (with an audit fix afterwards) and now all up and running again :)
                                            sdetweil @DarrenHill
                                            @darrenhill said in fix for black screen in 2.16 and later:
                                            don’t do those… many times leave more trouble than they fix…
                                            we can’t suppress the audit warning message
                                            D 1 Reply Last reply
