    module not found error loading module in MagicMirror
    41 Posts 12 Posters 54.0k Views 14 Watching
    • L
      levon @sdetweil
      @sdetweil @mumblebaj Thank you two for helping me solve this problem after the last update - I spent a LOT of time looking for the solution that you two helped me (the grep made it easier to find the right modules), the two commands were what fixed it.
      Will I have to do this again with the next update?
        sdetweil @levon
        @levon maybe. but if you use my upgrade script, it will do the fixes for you
        see
        L A 2 Replies Last reply Reply Quote 0
        • L
          levon @sdetweil
          @sdetweil Thanks … I will give this a try next time I’m updating. I thought I had tried it before, but perhaps not. I appreciate you sharing this.
          • A
            Arena @sdetweil
            @sdetweil I did everything as you said, but …
            [17.12.2021 04:05.03.723] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
            Require stack:
            • /home/pi/MagicMirror/modules/MMM-bitcoin/node_helper.js
              sdetweil @Arena
              @arena and , what is the module/library u need to install?
              • A
                Arena @sdetweil
                @sdetweil fiddled all day today and figured out
                it turned out I did not install or update the dependencies inside the module
                sorry, thanks
                • kusselinK
                  kusselin @sdetweil
                  @sdetweil Hello everyone, I haven’t been here for a while and my Magic Mirror was switched off…after I switched it on again I made updates to the modules via remote…but I still don’t have any display for some modules like Tankerkönig…when I start the Mirror it always says “Modules cannot be loaded”.
                  Now, as described by sdetweil, there are commands that you have to execute in the modules in question…but unfortunately I haven’t quite understood how I have to do this in the right order?
                  It would be really nice if you could explain to me how I have to proceed in order to display the modules again, such as Tankerkönig or mmm-fuel.
                  Thank you very much in advance for your help.
                  Greetings
                  Kussel
                  i don´t understand that here:
                  npm install ???
                  where ??? is the library noted in the message Cannot find module ‘???’
                  | in the example message above, ??? is request
                  to find this message, look in the output of npm start. or if you use pm2 to launch mm do
                  pm2 logs --lines=50
                  how do I proceed exactly?
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Tankerkoenig $ npm init -y
                  Wrote to /home/pi/MagicMirror/modules/MMM-Tankerkoenig/package.json:
                    "name": "MMM-Tankerkoenig",
                    "version": "1.0.0",
                    "description": "This is a module for the [MagicMirror²](https://github.com/MichMich/MagicMirror/) which displays a fuel prices from [Tankerkoenig](https://www.tankerkoenig.de/).",
                    "main": "MMM-Tankerkoenig.js",
                    "scripts": {
                      "test": "echo \"Error: no test specified\" && exit 1"
                    "repository": {
                      "type": "git",
                      "url": "git+https://github.com/terenc3/MMM-Tankerkoenig.git"
                    "keywords": [],
                    "author": "",
                    "license": "ISC",
                    "bugs": {
                      "url": "https://github.com/terenc3/MMM-Tankerkoenig/issues"
                    "homepage": "https://github.com/terenc3/MMM-Tankerkoenig#readme"
                    sdetweil @kusselin
                    @kusselin find the messages output by mm
                    search the messages for one like shown (without the ???)
                    find the name of the library in quotes (now u have ???)
                    issue a command using that info
                    kusselinK 1 Reply Last reply Reply Quote 0
                    • kusselinK
                      kusselin @sdetweil
                      @sdetweil thank you…it´s working now.
                      • L
                        LMAC
                        I ran the command as recommended (request was my error as well). I now have this error and MM will not load:
                        A JavaScript error occurred in the main process
                        Uncaught Exception:
                        Error: Cannot find module ‘logger’
                        Require stack:
                        • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                          at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                          at Module._load (node:internal/modules/cjs/loader:785:27)
                          at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                          at Module.require (node:internal/modules/cjs/loader:1012:19)
                          at require (node:internal/modules/cjs/helpers:94:18)
                          at Object. (/home/pi/MagicMirror/js/app.js:13:13)
                          at Module._compile (node:internal/modules/cjs/loader:1116:14)
                          at Object.Module._extensions…js (node:internal/modules/cjs/loader:1169:10)
                          sdetweil @LMAC
                          @lmac well you ran it in the wrong place… oops
                          do this
                          rm -rf node_modules
                          rm package-lock.json
                          npm install
                          then for whatever module was causing problem
                          cd ~/MagicMirror/modules/modulename
                          do the same last 3 steps as above
                          AND THEN
                          npm install request --save
                            DarrenHill
                            Just wanted to say thanks for the fix here.
                            Did an update and hit exactly this with MMM-GmailFeed and the request module.
                            Installed it back (with an audit fix afterwards) and now all up and running again :)
                              sdetweil @DarrenHill
                              @darrenhill said in fix for black screen in 2.16 and later:
                              don’t do those… many times leave more trouble than they fix…
                              we can’t suppress the audit warning message
                                DarrenHill @sdetweil
                                @sdetweil OK, thanks for the pointer.
                                Always kinda worried when that style of message pops up, for security and suchlike.
                                I see from the update that my node is very much out of date, so now just backing things up before setting the update script onto it to try and bring that up too.
                                  @darrenhill upgrade is for MM, not node, (altho it might do it, works sometimes, need to move to n) …
                                  easiest is using the node version of nvm, called n
                                  do
                                  sudo npm i n -g
                                  PATH="$PATH"
                                  n 16
                                  then node 16 will be installed…
                                  note that you will have to do another npm install in the mm (and maybe module folders)
                                  this the upgrade would do (with force instead of apply)
                                  n also allows you to SWITCH versions, or use a particular version for ONE app…
                                  see n --help
                                    @sdetweil - I did it via your update script, and it has updated Node from v10.x to v16.x (or at least that is what appears to have happened from what I could read).
                                    It’s quite an old install that just sits on my desk and largely gets left to its own devices. It is in a PiTop Ceed rather than a true mirror, and basically the only thing it runs is MM (it’s actually a dual-boot via PINN also with RetroPie, but the Raspi OS partition is essentially only MM). So no need to keep things focussed to one app or anything like that - no issue of cross-contamination.
                                    All is working fine after the update though, so no problems.
                                      @darrenhill cool. thx for the feedback
                                      • N
                                        np27np27 @sdetweil
                                        Ran your update script today and now got black screen. Should I still check each module for json files and npm install or will the script have done that already?
                                        How to I go about trying to troubleshoot this ? Any help is much appreciated!
                                          sdetweil @np27np27
                                          @np27np27 want to see installers/upgrade.log
                                          same process as listed in post 1
                                          ‘request’ is NOT the only library missing
                                          the messages tell you what needs to be added
                                          • N
                                            np27np27 @sdetweil
                                            hi, im getting this error in the pm2 log:
                                            0|mm       | the module (for instance, using `npm rebuild` or `npm install`).
                                            0|mm       |     at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1800)
                                            0|mm       |     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1199:18)
                                            0|mm       |     at Object.func [as .node] (node:electron/js2c/asar_bundle:5:1800)
                                            0|mm       |     at Module.load (node:internal/modules/cjs/loader:988:32)
                                            0|mm       |     at Module._load (node:internal/modules/cjs/loader:829:12)
                                            0|mm       |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                                            0|mm       |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                                            0|mm       |     at require (node:internal/modules/cjs/helpers:94:18)
                                            0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
                                            0|mm       |     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31 {
                                            0|mm       |   code: 'ERR_DLOPEN_FAILED'
                                            0|mm       | }
                                            0|mm       | [30.01.2022 19:11.04.155] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm       | [30.01.2022 19:11.04.156] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            0|mm       | Gdk-Message: 19:12:35.663: electron: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
                                            0|mm       |
                                            0|mm       | [30.01.2022 19:13.00.598] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                            0|mm       | was compiled against a different Node.js version using
                                            0|mm       | NODE_MODULE_VERSION 93. This version of Node.js requires
                                            0|mm       | NODE_MODULE_VERSION 99. Please try re-compiling or re-installing
                                            0|mm       | [30.01.2022 19:13.00.615] [ERROR] App threw an error during load
                                            0|mm       | [30.01.2022 19:13.00.618] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                            0|mm       | [30.01.2022 19:13.00.622] [ERROR] Whoops! There was an uncaught exception...
                                            0|mm       | [30.01.2022 19:13.00.632] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                            0|mm       | }
                                            0|mm       | [30.01.2022 19:13.00.634] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm       | [30.01.2022 19:13.00.635] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                            0|mm       | [31.01.2022 10:27.29.417] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                            0|mm       | [31.01.2022 10:27.29.428] [ERROR] App threw an error during load
                                            0|mm       | [31.01.2022 10:27.29.431] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                            0|mm       | [31.01.2022 10:27.29.433] [ERROR] Whoops! There was an uncaught exception...
                                            0|mm       | [31.01.2022 10:27.29.439] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                            0|mm       | }
                                            0|mm       | [31.01.2022 10:27.29.440] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm       | [31.01.2022 10:27.29.441] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            • 2 / 3
