    module not found error loading module in MagicMirror
    41 Posts 12 Posters 52.2k Views 14 Watching
    • N Offline
      np27np27 @sdetweil
      Ran your update script today and now got black screen. Should I still check each module for json files and npm install or will the script have done that already?
      How to I go about trying to troubleshoot this ? Any help is much appreciated!
        sdetweil @np27np27
        @np27np27 want to see installers/upgrade.log
        same process as listed in post 1
        ‘request’ is NOT the only library missing
        the messages tell you what needs to be added
        • N Offline
          np27np27 @sdetweil
          hi, im getting this error in the pm2 log:
          0|mm       | the module (for instance, using `npm rebuild` or `npm install`).
          0|mm       |     at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1800)
          0|mm       |     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1199:18)
          0|mm       |     at Object.func [as .node] (node:electron/js2c/asar_bundle:5:1800)
          0|mm       |     at Module.load (node:internal/modules/cjs/loader:988:32)
          0|mm       |     at Module._load (node:internal/modules/cjs/loader:829:12)
          0|mm       |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
          0|mm       |     at Module.require (node:internal/modules/cjs/loader:1012:19)
          0|mm       |     at require (node:internal/modules/cjs/helpers:94:18)
          0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
          0|mm       |     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31 {
          0|mm       |   code: 'ERR_DLOPEN_FAILED'
          0|mm       | }
          0|mm       | [30.01.2022 19:11.04.155] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm       | [30.01.2022 19:11.04.156] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm       | Gdk-Message: 19:12:35.663: electron: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
          0|mm       |
          0|mm       | [30.01.2022 19:13.00.598] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | was compiled against a different Node.js version using
          0|mm       | NODE_MODULE_VERSION 93. This version of Node.js requires
          0|mm       | NODE_MODULE_VERSION 99. Please try re-compiling or re-installing
          0|mm       | [30.01.2022 19:13.00.615] [ERROR] App threw an error during load
          0|mm       | [30.01.2022 19:13.00.618] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | [30.01.2022 19:13.00.622] [ERROR] Whoops! There was an uncaught exception...
          0|mm       | [30.01.2022 19:13.00.632] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | }
          0|mm       | [30.01.2022 19:13.00.634] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm       | [30.01.2022 19:13.00.635] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|mm       | [31.01.2022 10:27.29.417] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | [31.01.2022 10:27.29.428] [ERROR] App threw an error during load
          0|mm       | [31.01.2022 10:27.29.431] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | [31.01.2022 10:27.29.433] [ERROR] Whoops! There was an uncaught exception...
          0|mm       | [31.01.2022 10:27.29.439] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | }
          0|mm       | [31.01.2022 10:27.29.440] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm       | [31.01.2022 10:27.29.441] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          • N Offline
            np27np27 @np27np27
            Looks like the issue is the PIR sensor module. I believe there is a new PIR module?
              sdetweil @np27np27
              @np27np27 see this
              https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?_=1643636158919
              • N Offline
                np27np27 @sdetweil
                Thanks, installed the newer PIR module from @bugsounet and all seems to work fine now. Thanks for the help 👍🏾
                • swvalentiS swvalenti referenced this topic on
                • mumblebajM mumblebaj referenced this topic on
                • karsten13K karsten13 referenced this topic on
                • L Offline
                  lodevries @sdetweil
                  @sdetweil Thank you for your instruction.
                  One question, my modules are in the directory:
                  home/pi/MagicMirror/modules/default.
                  You don’t mention the default subdirectory.
                  I presume that my path is okay, because all the modules are located in this subdirectory. Is that okay?
                  Thank you.
                    sdetweil @lodevries
                    @lodevries you should never put your extra modules in the default folder, that is reserved for modules MM ships as part of the package
                    see the ‘How to add modules’ link in my signature below
                      sdetweil @lodevries
                      @lodevries you can move the out pretty easily
                      cd modules/default
                      mv whatever-name …
                      then the config.js shoudl change from
                      “module”: “default/whatever_name”
                      to
                      “module”:“whatever-name”
                      • L Offline
                        lodevries @sdetweil
                        @sdetweil Thank you.
                        • O oggo referenced this topic on
                        • JerryPJ JerryP referenced this topic on
                        • L Lazershrimp referenced this topic on
                        • B blackbull referenced this topic on
                          captsi
                          Thank you so much @sdetweil. I tried to update a module, ran out of memory (8GB SD card install), had to upgrade then got the dreaded black screen. Your first post in this thread solved it.
                          I’ve written a couple of modules, mainly by using other people’s code as a base and then changing the functionality, only because my coding is basic.
                          So… one module uses request in the node helper. You’ve already helped someone install it, so thanks for that. The code is
                          request(options, function (error, response, body) {
                          if (!error && response.statusCode == 200) {
                          var result = JSON.parse(body)
                          // console.log(response.statusCode + result); // uncomment to see in terminal
                          self.sendSocketNotification(‘TIDAL_RESULT’, result)
                          What should I be using instead of “request”?
                          Another module I use is calendarweek. Again its broken through the deprecated function “valid url” and “rrule”
                          createFetcher: function(url, fetchInterval, excludedEvents, maximumEntries, maximumNumberOfDays, auth) {
                          var self = this;
                          if (!validUrl.isUri(url)) {
                          self.sendSocketNotification(“INCORRECT_URL”, {url: url});
                          return;
                          and
                          if (typeof event.rrule !== “undefined” && event.rrule !== null && !isFacebookBirthday) {
                          var rule = event.rrule;
                          var addedEvents = 0;
                          					// can cause problems with e.g. birthdays before 1900
                          					if(rule.options && rule.origOptions && rule.origOptions.dtstart && rule.origOptions.dtstart.getFullYear() < 1900 ||
                          						rule.options && rule.options.dtstart && rule.options.dtstart.getFullYear() < 1900){
                          						rule.origOptions.dtstart.setYear(1900);
                          						rule.options.dtstart.setYear(1900);
                          					// For recurring events, get the set of start dates that fall within the range
                          					// of dates we"re looking for.</code>
                          Is there an elegant solution other than pulling the deprecated libraries?
                            sdetweil @captsi
                            @captsi there is no ‘no work’ solution.
                            built in fetch replaces request
                            I don’t know on the others.
                            • 2 / 3
