    After update 2.23.0 crash
    56 Posts 9 Posters 32.4k Views 8 Watching
      sdetweil @JerryP
      @JerryP AND then npm install after, yes??
      the doc says
      git pull && npm run install-mm
      you don’t use my upgrade script?
      • JerryPJ Offline
        JerryP @sdetweil
        @sdetweil ```
        magicmirror@2.23.0 start
        App threw an error during load
        Error: Cannot find module ‘envsub’
        Require stack:
        • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
          at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:811:27)
          at f._load (node:electron/js2c/asar_bundle:2:13328)
          at Module.require (node:internal/modules/cjs/loader:1035:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object. (/home/pi/MagicMirror/js/app.js:13:16)
          at Module._compile (node:internal/modules/cjs/loader:1141:14)
          at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
          A JavaScript error occurred in the main process
          Uncaught Exception:
          Require stack:
          MESA-LOADER: failed to retrieve device information
          MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
          failed to load driver: kms_swrast
          MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
          failed to load swrast driver
          sdetweil @JerryP
          @JerryP do
          npm install
          we’ve updated a bunch of dependencies for this release, you have to install them
          swvalentiS JerryPJ 2 Replies Last reply Reply Quote 0
          • swvalentiS Offline
            swvalenti Project Sponsor @sdetweil
            Don’t want to hijack but didn’t want to create another thread. MM doesn’t run after upgrade with this error. I think it is related to MMM-PGA module but not sure what changed as dev window won’t run either.
            [04.04.2023 16:29.46.158] [ERROR] (node:11188) UnhandledPromiseRejectionWarning: Error: Cannot find module 'jsdom'
            Require stack:
            • JerryPJ Offline
              JerryP @sdetweil
              @sdetweil ```
              Already up to date.
              magicmirror@2.23.0 install-mm
              npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
              npm WARN config only Use --omit=dev to omit dev dependencies from the install.
              npm ERR! code EACCES
              npm ERR! syscall open
              npm ERR! path /home/pi/MagicMirror/package-lock.json
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’
              npm ERR! [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’] {
              npm ERR! errno: -13,
              npm ERR! code: ‘EACCES’,
              npm ERR! syscall: ‘open’,
              npm ERR! path: ‘/home/pi/MagicMirror/package-lock.json’
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR! /home/pi/.npm/_logs/2023-04-04T20_38_11_536Z-debug-0.log
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @swvalenti
                @swvalenti yes, there is no package.json describing the dependencies…
                some of the local add on scripts use request and jsdom and others…
                swvalentiS 1 Reply Last reply Reply Quote 0
                  sdetweil @JerryP
                  @JerryP said in After update 2.23.0 crash:
                  erase that file… seems u might have used sudo at some time before …
                  sudo rm /home/pi/MagicMirror/package-lock.json
                  then npm install again
                  JerryPJ 1 Reply Last reply Reply Quote 0
                    @sdetweil said in After update 2.23.0 crash:
                    So I should revert back to 2.22 then?
                    • JerryPJ Offline
                      JerryP @sdetweil
                      pi@raspberrypi:~/MagicMirror $ ls
                       CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
                       clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
                      pi@raspberrypi:~/MagicMirror $ npm install
                      npm ERR! code ENOTEMPTY
                      npm ERR! syscall rename
                      npm ERR! path /home/pi/MagicMirror/node_modules/acorn
                      npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
                      npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
                      S swvalentiS 2 Replies Last reply Reply Quote 0
                        @swvalenti no, i think you got bit by the security cleanup
                        if a package is not listed in the (any) dependencies and you run npm install it will be removed…
                        so, go thru the requires in the .js files and do this for each one
                          sdetweil @JerryP
                          @JerryP fun, fun
                          rm -rf node_modules
                          and then npm install again
                          JerryPJ H 2 Replies Last reply Reply Quote 0
                          • JerryPJ Offline
                            JerryP @sdetweil
                            @sdetweil same error
                            pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                            npm ERR! code ENOENT
                            npm ERR! path /home/pi/MagicMirror/package.json
                            npm ERR! errno -2
                            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/package.json'
                            npm ERR! enoent This is related to npm not being able to find a file.
                            npm ERR! enoent
                            npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_47_07_273Z-debug-0.log
                              sdetweil @JerryP
                              @JerryP looks like u got carried away with sudo rm /home/pi/MagicMirror/package-lock.json (notice the -lock)
                              and deleted the package.json
                              git checkout package.json
                              and npm install again
                                swvalenti Project Sponsor @JerryP
                                npm ERR! errno -39
                                That didn’t work, no worries I will revert
                                  sdetweil @swvalenti
                                  @swvalenti what didn’t work?
                                  u are supposed to be doing the npm install of the missing libs in the module (MMM-PGA) folder
                                  i don’t think revert will help, the undocumented libraries were deleted by npm… not us
                                  that .acorn file needs to be deleted
                                    swvalenti Project Sponsor @swvalenti
                                    @swvalenti said in After update 2.23.0 crash:
                                    npm ERR! errno -39
                                    The package.json showed no issue with that command. It worked when I reverted no issue.
                                      sdetweil @swvalenti
                                      @swvalenti how did you revert?
                                        Copied original file and renamed before using your script.
                                          sdetweil @swvalenti
                                          @swvalenti got it…
                                            @swvalenti got it…
                                            Thought maybe the script would catch it. Ha. Oh well thanks for all your help and work.
