    After update 2.23.0 crash
    56 Posts 9 Posters 29.8k Views 8 Watching
      sdetweil @JerryP
      @JerryP how did you update?
        sdetweil @JerryP
        @JerryP said in After update 2.23.0 crash:
        magicmirror@2.22.0 start
        should be 2.23
        JerryPJ 2 Replies Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @sdetweil
          pi@raspberrypi:~/MagicMirror $ sudo git pull
            sdetweil @JerryP
            @JerryP AND then npm install after, yes??
            the doc says
            git pull && npm run install-mm
            you don’t use my upgrade script?
            • JerryPJ Offline
              JerryP @sdetweil
              @sdetweil ```
              magicmirror@2.23.0 start
              App threw an error during load
              Error: Cannot find module ‘envsub’
              Require stack:
              • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
                at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
                at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (node:internal/modules/cjs/loader:811:27)
                at f._load (node:electron/js2c/asar_bundle:2:13328)
                at Module.require (node:internal/modules/cjs/loader:1035:19)
                at require (node:internal/modules/cjs/helpers:102:18)
                at Object. (/home/pi/MagicMirror/js/app.js:13:16)
                at Module._compile (node:internal/modules/cjs/loader:1141:14)
                at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
                A JavaScript error occurred in the main process
                Uncaught Exception:
                Require stack:
                MESA-LOADER: failed to retrieve device information
                MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                failed to load driver: kms_swrast
                MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                failed to load swrast driver
                sdetweil @JerryP
                @JerryP do
                npm install
                we’ve updated a bunch of dependencies for this release, you have to install them
                swvalentiS JerryPJ 2 Replies Last reply Reply Quote 0
                • swvalentiS Offline
                  swvalenti Project Sponsor @sdetweil
                  Don’t want to hijack but didn’t want to create another thread. MM doesn’t run after upgrade with this error. I think it is related to MMM-PGA module but not sure what changed as dev window won’t run either.
                  [04.04.2023 16:29.46.158] [ERROR] (node:11188) UnhandledPromiseRejectionWarning: Error: Cannot find module 'jsdom'
                  Require stack:
                  • JerryPJ Offline
                    JerryP @sdetweil
                    @sdetweil ```
                    Already up to date.
                    magicmirror@2.23.0 install-mm
                    npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                    npm WARN config only Use --omit=dev to omit dev dependencies from the install.
                    npm ERR! code EACCES
                    npm ERR! syscall open
                    npm ERR! path /home/pi/MagicMirror/package-lock.json
                    npm ERR! errno -13
                    npm ERR! Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’
                    npm ERR! [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’] {
                    npm ERR! errno: -13,
                    npm ERR! code: ‘EACCES’,
                    npm ERR! syscall: ‘open’,
                    npm ERR! path: ‘/home/pi/MagicMirror/package-lock.json’
                    npm ERR! }
                    npm ERR!
                    npm ERR! The operation was rejected by your operating system.
                    npm ERR! It is likely you do not have the permissions to access this file as the current user
                    npm ERR!
                    npm ERR! If you believe this might be a permissions issue, please double-check the
                    npm ERR! permissions of the file and its containing directories, or try running
                    npm ERR! the command again as root/Administrator.
                    npm ERR! /home/pi/.npm/_logs/2023-04-04T20_38_11_536Z-debug-0.log
                    S mumblebajM 2 Replies Last reply Reply Quote 0
                      sdetweil @swvalenti
                      @swvalenti yes, there is no package.json describing the dependencies…
                      some of the local add on scripts use request and jsdom and others…
                      swvalentiS 1 Reply Last reply Reply Quote 0
                        sdetweil @JerryP
                        erase that file… seems u might have used sudo at some time before …
                        sudo rm /home/pi/MagicMirror/package-lock.json
                        then npm install again
                        JerryPJ 1 Reply Last reply Reply Quote 0
                          @sdetweil said in After update 2.23.0 crash:
                          So I should revert back to 2.22 then?
                          • JerryPJ Offline
                            JerryP @sdetweil
                            pi@raspberrypi:~/MagicMirror $ ls
                             CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
                             clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
                            pi@raspberrypi:~/MagicMirror $ npm install
                            npm ERR! code ENOTEMPTY
                            npm ERR! syscall rename
                            npm ERR! path /home/pi/MagicMirror/node_modules/acorn
                            npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
                            npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
                            S swvalentiS 2 Replies Last reply Reply Quote 0
                              @swvalenti no, i think you got bit by the security cleanup
                              if a package is not listed in the (any) dependencies and you run npm install it will be removed…
                              so, go thru the requires in the .js files and do this for each one
                                sdetweil @JerryP
                                @JerryP fun, fun
                                rm -rf node_modules
                                and then npm install again
                                JerryPJ H 2 Replies Last reply Reply Quote 0
                                • JerryPJ Offline
                                  JerryP @sdetweil
                                  @sdetweil same error
                                  pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                                  npm ERR! code ENOENT
                                  npm ERR! path /home/pi/MagicMirror/package.json
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/package.json'
                                  npm ERR! enoent This is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_47_07_273Z-debug-0.log
                                    sdetweil @JerryP
                                    @JerryP looks like u got carried away with sudo rm /home/pi/MagicMirror/package-lock.json (notice the -lock)
                                    and deleted the package.json
                                    git checkout package.json
                                    and npm install again
                                      swvalenti Project Sponsor @JerryP
                                      npm ERR! errno -39
                                      That didn’t work, no worries I will revert
                                        sdetweil @swvalenti
                                        @swvalenti what didn’t work?
                                        u are supposed to be doing the npm install of the missing libs in the module (MMM-PGA) folder
                                        i don’t think revert will help, the undocumented libraries were deleted by npm… not us
                                        that .acorn file needs to be deleted
                                          swvalenti Project Sponsor @swvalenti
                                          @swvalenti said in After update 2.23.0 crash:
                                          npm ERR! errno -39
                                          The package.json showed no issue with that command. It worked when I reverted no issue.
                                            sdetweil @swvalenti
                                            @swvalenti how did you revert?
