    After update 2.23.0 crash
    56 Posts 9 Posters 32.3k Views 8 Watching
    • JerryPJ Offline
      JerryP @sdetweil
      @sdetweil ```
      magicmirror@2.23.0 start
      App threw an error during load
      Error: Cannot find module ‘envsub’
      Require stack:
      • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
        at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:811:27)
        at f._load (node:electron/js2c/asar_bundle:2:13328)
        at Module.require (node:internal/modules/cjs/loader:1035:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object. (/home/pi/MagicMirror/js/app.js:13:16)
        at Module._compile (node:internal/modules/cjs/loader:1141:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
        A JavaScript error occurred in the main process
        Uncaught Exception:
        Require stack:
        MESA-LOADER: failed to retrieve device information
        MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load driver: kms_swrast
        MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load swrast driver
        sdetweil @JerryP
        @JerryP do
        npm install
        we’ve updated a bunch of dependencies for this release, you have to install them
        swvalentiS JerryPJ 2 Replies Last reply Reply Quote 0
        • swvalentiS Offline
          swvalenti Project Sponsor @sdetweil
          Don’t want to hijack but didn’t want to create another thread. MM doesn’t run after upgrade with this error. I think it is related to MMM-PGA module but not sure what changed as dev window won’t run either.
          [04.04.2023 16:29.46.158] [ERROR] (node:11188) UnhandledPromiseRejectionWarning: Error: Cannot find module 'jsdom'
          Require stack:
          • JerryPJ Offline
            JerryP @sdetweil
            @sdetweil ```
            Already up to date.
            magicmirror@2.23.0 install-mm
            npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
            npm WARN config only Use --omit=dev to omit dev dependencies from the install.
            npm ERR! code EACCES
            npm ERR! syscall open
            npm ERR! path /home/pi/MagicMirror/package-lock.json
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’
            npm ERR! [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’] {
            npm ERR! errno: -13,
            npm ERR! code: ‘EACCES’,
            npm ERR! syscall: ‘open’,
            npm ERR! path: ‘/home/pi/MagicMirror/package-lock.json’
            npm ERR! }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator.
            npm ERR! /home/pi/.npm/_logs/2023-04-04T20_38_11_536Z-debug-0.log
            S mumblebajM 2 Replies Last reply Reply Quote 0
              sdetweil @swvalenti
              @swvalenti yes, there is no package.json describing the dependencies…
              some of the local add on scripts use request and jsdom and others…
              swvalentiS 1 Reply Last reply Reply Quote 0
                sdetweil @JerryP
                @JerryP said in After update 2.23.0 crash:
                erase that file… seems u might have used sudo at some time before …
                sudo rm /home/pi/MagicMirror/package-lock.json
                then npm install again
                JerryPJ 1 Reply Last reply Reply Quote 0
                  @sdetweil said in After update 2.23.0 crash:
                  So I should revert back to 2.22 then?
                  • JerryPJ Offline
                    JerryP @sdetweil
                    pi@raspberrypi:~/MagicMirror $ ls
                     CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
                     clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
                    pi@raspberrypi:~/MagicMirror $ npm install
                    npm ERR! code ENOTEMPTY
                    npm ERR! syscall rename
                    npm ERR! path /home/pi/MagicMirror/node_modules/acorn
                    npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
                    npm ERR! errno -39
                    npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
                    npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
                    S swvalentiS 2 Replies Last reply Reply Quote 0
                      @swvalenti no, i think you got bit by the security cleanup
                      if a package is not listed in the (any) dependencies and you run npm install it will be removed…
                      so, go thru the requires in the .js files and do this for each one
                        sdetweil @JerryP
                        @JerryP fun, fun
                        rm -rf node_modules
                        and then npm install again
                        JerryPJ H 2 Replies Last reply Reply Quote 0
                        • JerryPJ Offline
                          JerryP @sdetweil
                          @sdetweil same error
                          pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                          npm ERR! code ENOENT
                          npm ERR! path /home/pi/MagicMirror/package.json
                          npm ERR! errno -2
                          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/package.json'
                          npm ERR! enoent This is related to npm not being able to find a file.
                          npm ERR! enoent
                          npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_47_07_273Z-debug-0.log
                            sdetweil @JerryP
                            @JerryP looks like u got carried away with sudo rm /home/pi/MagicMirror/package-lock.json (notice the -lock)
                            and deleted the package.json
                            git checkout package.json
                            and npm install again
                              swvalenti Project Sponsor @JerryP
                              npm ERR! errno -39
                              That didn’t work, no worries I will revert
                                sdetweil @swvalenti
                                @swvalenti what didn’t work?
                                u are supposed to be doing the npm install of the missing libs in the module (MMM-PGA) folder
                                i don’t think revert will help, the undocumented libraries were deleted by npm… not us
                                that .acorn file needs to be deleted
                                  swvalenti Project Sponsor @swvalenti
                                  @swvalenti said in After update 2.23.0 crash:
                                  npm ERR! errno -39
                                  The package.json showed no issue with that command. It worked when I reverted no issue.
                                    sdetweil @swvalenti
                                    @swvalenti how did you revert?
                                      Copied original file and renamed before using your script.
                                        sdetweil @swvalenti
                                        @swvalenti got it…
                                          @swvalenti got it…
                                          Thought maybe the script would catch it. Ha. Oh well thanks for all your help and work.
                                            sdetweil @swvalenti
                                            @swvalenti the script DID catch for request, but not jsdom…
                                            these are the undocumented libs used
                                            OWGR.js:const request = require('request');
                                            OWGR.js:const jsdom = require("jsdom");
                                            I just added that to the upgrade script list of missing libs
