    After update 2.23.0 crash
    56 Posts 9 Posters 33.5k Views 8 Watching
    • JerryPJ
      JerryP
      After the update.
      error at reboot
      > magicmirror@2.23.0 start
      App threw an error during load
      Error: Cannot find module 'envsub'
      Require stack:
          at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
          at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:811:27)
          at f._load (node:electron/js2c/asar_bundle:2:13328)
          at Module.require (node:internal/modules/cjs/loader:1035:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:13:16)
          at Module._compile (node:internal/modules/cjs/loader:1141:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      MESA-LOADER: failed to retrieve device information
      MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      failed to load driver: kms_swrast
      MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      failed to load swrast driver
      Please help
      S 2 Replies Last reply
        sdetweil @JerryP
        @JerryP how did you update?
          sdetweil @JerryP
          @JerryP said in After update 2.23.0 crash:
          magicmirror@2.22.0 start
          should be 2.23
          JerryPJ 2 Replies Last reply
          • JerryPJ
            JerryP @sdetweil
            pi@raspberrypi:~/MagicMirror $ sudo git pull
              sdetweil @JerryP
              @JerryP AND then npm install after, yes??
              the doc says
              git pull && npm run install-mm
              you don’t use my upgrade script?
              • JerryPJ
                JerryP @sdetweil
                @sdetweil ```
                Error: Cannot find module ‘envsub’
                Require stack:
                • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
                  at Object. (/home/pi/MagicMirror/js/app.js:13:16)
                  at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
                  Uncaught Exception:
                  Require stack:
                  MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                  MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                  sdetweil @JerryP
                  @JerryP do
                  npm install
                  we’ve updated a bunch of dependencies for this release, you have to install them
                  swvalentiS JerryPJ 2 Replies Last reply
                  • swvalentiS
                    swvalenti Project Sponsor @sdetweil
                    Don’t want to hijack but didn’t want to create another thread. MM doesn’t run after upgrade with this error. I think it is related to MMM-PGA module but not sure what changed as dev window won’t run either.
                    [04.04.2023 16:29.46.158] [ERROR] (node:11188) UnhandledPromiseRejectionWarning: Error: Cannot find module 'jsdom'
                    Require stack:
                    • JerryPJ
                      JerryP @sdetweil
                      @sdetweil ```
                      Already up to date.
                      magicmirror@2.23.0 install-mm
                      npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                      npm WARN config only Use --omit=dev to omit dev dependencies from the install.
                      npm ERR! code EACCES
                      npm ERR! syscall open
                      npm ERR! path /home/pi/MagicMirror/package-lock.json
                      npm ERR! errno -13
                      npm ERR! Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’
                      npm ERR! [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’] {
                      npm ERR! errno: -13,
                      npm ERR! code: ‘EACCES’,
                      npm ERR! syscall: ‘open’,
                      npm ERR! path: ‘/home/pi/MagicMirror/package-lock.json’
                      npm ERR! }
                      npm ERR!
                      npm ERR! The operation was rejected by your operating system.
                      npm ERR! It is likely you do not have the permissions to access this file as the current user
                      npm ERR!
                      npm ERR! If you believe this might be a permissions issue, please double-check the
                      npm ERR! permissions of the file and its containing directories, or try running
                      npm ERR! the command again as root/Administrator.
                      npm ERR! /home/pi/.npm/_logs/2023-04-04T20_38_11_536Z-debug-0.log
                      S mumblebajM 2 Replies Last reply
                        sdetweil @swvalenti
                        @swvalenti yes, there is no package.json describing the dependencies…
                        some of the local add on scripts use request and jsdom and others…
                        swvalentiS 1 Reply Last reply
                          sdetweil @JerryP
                          erase that file… seems u might have used sudo at some time before …
                          sudo rm /home/pi/MagicMirror/package-lock.json
                          then npm install again
                          JerryPJ 1 Reply Last reply
                          • swvalentiS
                            @sdetweil said in After update 2.23.0 crash:
                            So I should revert back to 2.22 then?
                            • JerryPJ
                              JerryP @sdetweil
                              pi@raspberrypi:~/MagicMirror $ ls
                               CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
                               clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
                              pi@raspberrypi:~/MagicMirror $ npm install
                              npm ERR! code ENOTEMPTY
                              npm ERR! syscall rename
                              npm ERR! path /home/pi/MagicMirror/node_modules/acorn
                              npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
                              npm ERR! errno -39
                              npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
                              npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
                              S swvalentiS 2 Replies Last reply
                                @swvalenti no, i think you got bit by the security cleanup
                                if a package is not listed in the (any) dependencies and you run npm install it will be removed…
                                so, go thru the requires in the .js files and do this for each one
                                  sdetweil @JerryP
                                  @JerryP fun, fun
                                  rm -rf node_modules
                                  and then npm install again
                                  JerryPJ H 2 Replies Last reply
                                  • JerryPJ
                                    JerryP @sdetweil
                                    @sdetweil same error
                                    pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                                    npm ERR! code ENOENT
                                    npm ERR! path /home/pi/MagicMirror/package.json
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/package.json'
                                    npm ERR! enoent This is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_47_07_273Z-debug-0.log
                                      sdetweil @JerryP
                                      @JerryP looks like u got carried away with sudo rm /home/pi/MagicMirror/package-lock.json (notice the -lock)
                                      and deleted the package.json
                                      git checkout package.json
                                      and npm install again
                                      • swvalentiS
                                        swvalenti Project Sponsor @JerryP
                                        npm ERR! errno -39
                                        That didn’t work, no worries I will revert
                                          sdetweil @swvalenti
                                          @swvalenti what didn’t work?
                                          u are supposed to be doing the npm install of the missing libs in the module (MMM-PGA) folder
                                          i don’t think revert will help, the undocumented libraries were deleted by npm… not us
                                          that .acorn file needs to be deleted
                                          • swvalentiS
                                            swvalenti Project Sponsor @swvalenti
                                            @swvalenti said in After update 2.23.0 crash:
                                            npm ERR! errno -39
                                            The package.json showed no issue with that command. It worked when I reverted no issue.
