    After update 2.23.0 crash
    56 Posts 9 Posters 31.9k Views 8 Watching
      sdetweil @JerryP
      @JerryP said in After update 2.23.0 crash:
      magicmirror@2.22.0 start
      should be 2.23
      JerryPJ 2 Replies Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @sdetweil
        pi@raspberrypi:~/MagicMirror $ sudo git pull
          sdetweil @JerryP
          @JerryP AND then npm install after, yes??
          the doc says
          git pull && npm run install-mm
          you don’t use my upgrade script?
          • JerryPJ Offline
            JerryP @sdetweil
            @sdetweil ```
            magicmirror@2.23.0 start
            App threw an error during load
            Error: Cannot find module ‘envsub’
            Require stack:
            • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
              at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Module._load (node:internal/modules/cjs/loader:811:27)
              at f._load (node:electron/js2c/asar_bundle:2:13328)
              at Module.require (node:internal/modules/cjs/loader:1035:19)
              at require (node:internal/modules/cjs/helpers:102:18)
              at Object. (/home/pi/MagicMirror/js/app.js:13:16)
              at Module._compile (node:internal/modules/cjs/loader:1141:14)
              at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
              A JavaScript error occurred in the main process
              Uncaught Exception:
              Require stack:
              MESA-LOADER: failed to retrieve device information
              MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
              failed to load driver: kms_swrast
              MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
              failed to load swrast driver
              sdetweil @JerryP
              @JerryP do
              npm install
              we’ve updated a bunch of dependencies for this release, you have to install them
              swvalentiS JerryPJ 2 Replies Last reply Reply Quote 0
              • swvalentiS Offline
                swvalenti Project Sponsor @sdetweil
                Don’t want to hijack but didn’t want to create another thread. MM doesn’t run after upgrade with this error. I think it is related to MMM-PGA module but not sure what changed as dev window won’t run either.
                [04.04.2023 16:29.46.158] [ERROR] (node:11188) UnhandledPromiseRejectionWarning: Error: Cannot find module 'jsdom'
                Require stack:
                • JerryPJ Offline
                  JerryP @sdetweil
                  @sdetweil ```
                  Already up to date.
                  magicmirror@2.23.0 install-mm
                  npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                  npm WARN config only Use --omit=dev to omit dev dependencies from the install.
                  npm ERR! code EACCES
                  npm ERR! syscall open
                  npm ERR! path /home/pi/MagicMirror/package-lock.json
                  npm ERR! errno -13
                  npm ERR! Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’
                  npm ERR! [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/package-lock.json’] {
                  npm ERR! errno: -13,
                  npm ERR! code: ‘EACCES’,
                  npm ERR! syscall: ‘open’,
                  npm ERR! path: ‘/home/pi/MagicMirror/package-lock.json’
                  npm ERR! }
                  npm ERR!
                  npm ERR! The operation was rejected by your operating system.
                  npm ERR! It is likely you do not have the permissions to access this file as the current user
                  npm ERR!
                  npm ERR! If you believe this might be a permissions issue, please double-check the
                  npm ERR! permissions of the file and its containing directories, or try running
                  npm ERR! the command again as root/Administrator.
                  npm ERR! /home/pi/.npm/_logs/2023-04-04T20_38_11_536Z-debug-0.log
                  S mumblebajM 2 Replies Last reply Reply Quote 0
                    sdetweil @swvalenti
                    @swvalenti yes, there is no package.json describing the dependencies…
                    some of the local add on scripts use request and jsdom and others…
                    swvalentiS 1 Reply Last reply Reply Quote 0
                      sdetweil @JerryP
                      erase that file… seems u might have used sudo at some time before …
                      sudo rm /home/pi/MagicMirror/package-lock.json
                      then npm install again
                      JerryPJ 1 Reply Last reply Reply Quote 0
                        @sdetweil said in After update 2.23.0 crash:
                        So I should revert back to 2.22 then?
                        • JerryPJ Offline
                          JerryP @sdetweil
                          pi@raspberrypi:~/MagicMirror $ ls
                           CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
                           clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
                          pi@raspberrypi:~/MagicMirror $ npm install
                          npm ERR! code ENOTEMPTY
                          npm ERR! syscall rename
                          npm ERR! path /home/pi/MagicMirror/node_modules/acorn
                          npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
                          npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
                          S swvalentiS 2 Replies Last reply Reply Quote 0
                            @swvalenti no, i think you got bit by the security cleanup
                            if a package is not listed in the (any) dependencies and you run npm install it will be removed…
                            so, go thru the requires in the .js files and do this for each one
                              sdetweil @JerryP
                              @JerryP fun, fun
                              rm -rf node_modules
                              and then npm install again
                              JerryPJ H 2 Replies Last reply Reply Quote 0
                              • JerryPJ Offline
                                JerryP @sdetweil
                                @sdetweil same error
                                pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                                npm ERR! code ENOENT
                                npm ERR! path /home/pi/MagicMirror/package.json
                                npm ERR! errno -2
                                npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/package.json'
                                npm ERR! enoent This is related to npm not being able to find a file.
                                npm ERR! enoent
                                npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_47_07_273Z-debug-0.log
                                  sdetweil @JerryP
                                  @JerryP looks like u got carried away with sudo rm /home/pi/MagicMirror/package-lock.json (notice the -lock)
                                  and deleted the package.json
                                  git checkout package.json
                                  and npm install again
                                    swvalenti Project Sponsor @JerryP
                                    npm ERR! errno -39
                                    That didn’t work, no worries I will revert
                                      sdetweil @swvalenti
                                      @swvalenti what didn’t work?
                                      u are supposed to be doing the npm install of the missing libs in the module (MMM-PGA) folder
                                      i don’t think revert will help, the undocumented libraries were deleted by npm… not us
                                      that .acorn file needs to be deleted
                                        swvalenti Project Sponsor @swvalenti
                                        @swvalenti said in After update 2.23.0 crash:
                                        npm ERR! errno -39
                                        The package.json showed no issue with that command. It worked when I reverted no issue.
                                          sdetweil @swvalenti
                                          @swvalenti how did you revert?
                                            Copied original file and renamed before using your script.
