    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 437.1k Views 65 Watching
    • AssassinsA
      Assassins @sdetweil
      @sdetweil The step to this synsc iCloud calendar is
      mkdir /home/pi/MagicMirror/modules/calendars
        sdetweil @Assassins
        @assassins is there supposed to be a script added to that folder?
        AssassinsA 1 Reply Last reply Reply Quote 0
        • AssassinsA
          Assassins @sdetweil
          @sdetweil No, only the .ics to you Icloud Calendar
          • G
            ggfuzzy
            Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
            M R 2 Replies Last reply Reply Quote 0
              mr190e @ggfuzzy
              @ggfuzzy Where is that file? I’m too much of a noob to find it :D
                mr190e @mr190e
                @mr190e said in Sync private iCloud calendar with MagicMirror:
                Seems like I got to work again.
                First of all, I installed vdirsyncer via
                “sudo apt-get install vdirsyncer”,
                and not using pip.
                Second the command to start the systemd timer
                systemctl --user enable vdirsyncer.timer
                did not work at all. When typing
                systemctl --user status vdirsyncer.timer
                It always said the timer was dead. So I started it with its start command:
                systemctl --user start vdirsyncer.timer
                Third, I made the modification to vdirsyncer.service as suggested by @Beh
                Run
                which vdirsyncer
                And remember the path. After, edit the vdirsyncer.service file
                sudo nano /etc/systemd/user/vdirsyncer.service
                Correct the right path after “ExecStart”. My .service file looks like this:
                [Unit]
                Description=Synchronize calendars and contacts
                Documentation=https://vdirsyncer.readthedocs.org/
                [Service]
                ExecStart=/home/pi/.local/bin/vdirsyncer sync
                RuntimeMaxSec=3m
                Restart=on-failure
                  spor4
                  I get the the message:
                  Error in calendar module. Check logs for more details.
                  ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/0505190Dxxxxxxxxxxxxxxxx.ics Error: Not Found
                  at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
                  it would be awesome if somebody can help me.
                    sdetweil @spor4
                    @spor4 said in Sync private iCloud calendar with MagicMirror:
                    where did the syncher put the ics file… cause its not there
                    ps, on linux/raspina all filenames are case sensitive
                    cd ~/MagicMirror/modules
                    ls -laF
                    to see the file list
                      spor4 @sdetweil
                      thank you very much. I moved the file to /modules and not it is working. Unfortunately now it says “no upcoming events.”
                        sdetweil @spor4
                        @spor4 that file should just be text
                        u can edit it
                        it should look like this layout
                        BEGIN:VCALENDAR
                        BEGIN:VEVENT
                        END:VEVENT
                        repeat for all events
                        END:VCALENDAR
                          spor4 @sdetweil
                          @sdetweil sorry for asking stupid (total noob), I should edit the .ics file with the text editor into this?
                          If I do so it says Error in calendar module. Check logs for more details. again
                          BEGIN:VCALENDAR
                          BEGIN:VEVENT
                          END:VEVENT
                          END:VCALENDAR
                            sdetweil @spor4
                            @spor4 no. you are going to look at the generated ics file and see if it contains the format I described
                              spor4 @sdetweil
                              @sdetweil no it’s empty
                                sdetweil @spor4
                                @spor4 then thats why no events on the calendar…
                                so the syncher didn’t work correctly
                                now you need someone elses help on that problem
                                  Saabman Project Sponsor
                                  Just wanted to say thanks for posting these instructions just secured my calendar. Much apreciated
                                  • A
                                    anhanyoung @Beh
                                    @Beh Okay, I apologize because I’m sure this is a very basic question but how do you create an array in the config? I tried doing [], [] but that didn’t work.
                                    Also, I keep getting this error when discovering and press y.
                                    Should vdirsyncer attempt to create it? [y/N]: y
                                    error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                                    How can I bypass this?
                                    • A
                                      anhanyoung
                                      @sdetweil Any idea why I’m getting an error when running discover and saying yes to sync?
                                      error: Use -vdebug to see the full traceback.
                                        sdetweil @anhanyoung
                                        @anhanyoung I do not know anything about this syncing tool, never had to use it
                                        • A
                                          anhanyoung91 @Saabman
                                          @Saabman do you know how to get the syncer to work? I keep getting an error saying I don’t have permissions to /home/pi
                                          S S 2 Replies Last reply Reply Quote 0
                                            sdetweil @anhanyoung91
                                            @anhanyoung91 please don’t double post, all posts from users w reputation below 2 are reviewed
                                            • 7 / 9
