    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 437.1k Views 65 Watching
      sdetweil @Assassins
      @assassins calendar is actually in the modules/default folder
      AssassinsA 1 Reply Last reply Reply Quote 0
      • AssassinsA
        Assassins @sdetweil
        @sdetweil Yes i now, but i have do all the step, and this error come up
          sdetweil @Assassins
          @assassins but u said the calendar folder was created. and its looking for the js file… so i think you didnt use the right folder
          • AssassinsA
            Assassins @sdetweil
            @sdetweil The step to this synsc iCloud calendar is
            mkdir /home/pi/MagicMirror/modules/calendars
              sdetweil @Assassins
              @assassins is there supposed to be a script added to that folder?
              • AssassinsA
                Assassins @sdetweil
                @sdetweil No, only the .ics to you Icloud Calendar
                • G
                  ggfuzzy
                  Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
                  M R 2 Replies Last reply Reply Quote 0
                    mr190e @ggfuzzy
                    @ggfuzzy Where is that file? I’m too much of a noob to find it :D
                      mr190e @mr190e
                      @mr190e said in Sync private iCloud calendar with MagicMirror:
                      Seems like I got to work again.
                      First of all, I installed vdirsyncer via
                      “sudo apt-get install vdirsyncer”,
                      and not using pip.
                      Second the command to start the systemd timer
                      systemctl --user enable vdirsyncer.timer
                      did not work at all. When typing
                      systemctl --user status vdirsyncer.timer
                      It always said the timer was dead. So I started it with its start command:
                      systemctl --user start vdirsyncer.timer
                      Third, I made the modification to vdirsyncer.service as suggested by @Beh
                      Run
                      which vdirsyncer
                      And remember the path. After, edit the vdirsyncer.service file
                      sudo nano /etc/systemd/user/vdirsyncer.service
                      Correct the right path after “ExecStart”. My .service file looks like this:
                      [Unit]
                      Description=Synchronize calendars and contacts
                      Documentation=https://vdirsyncer.readthedocs.org/
                      [Service]
                      ExecStart=/home/pi/.local/bin/vdirsyncer sync
                      RuntimeMaxSec=3m
                      Restart=on-failure
                        spor4
                        I get the the message:
                        Error in calendar module. Check logs for more details.
                        ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/0505190Dxxxxxxxxxxxxxxxx.ics Error: Not Found
                        at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
                        it would be awesome if somebody can help me.
                          sdetweil @spor4
                          @spor4 said in Sync private iCloud calendar with MagicMirror:
                          where did the syncher put the ics file… cause its not there
                          ps, on linux/raspina all filenames are case sensitive
                          cd ~/MagicMirror/modules
                          ls -laF
                          to see the file list
                            spor4 @sdetweil
                            thank you very much. I moved the file to /modules and not it is working. Unfortunately now it says “no upcoming events.”
                              sdetweil @spor4
                              @spor4 that file should just be text
                              u can edit it
                              it should look like this layout
                              BEGIN:VCALENDAR
                              BEGIN:VEVENT
                              END:VEVENT
                              repeat for all events
                              END:VCALENDAR
                                spor4 @sdetweil
                                @sdetweil sorry for asking stupid (total noob), I should edit the .ics file with the text editor into this?
                                If I do so it says Error in calendar module. Check logs for more details. again
                                BEGIN:VCALENDAR
                                BEGIN:VEVENT
                                END:VEVENT
                                END:VCALENDAR
                                  sdetweil @spor4
                                  @spor4 no. you are going to look at the generated ics file and see if it contains the format I described
                                    spor4 @sdetweil
                                    @sdetweil no it’s empty
                                      sdetweil @spor4
                                      @spor4 then thats why no events on the calendar…
                                      so the syncher didn’t work correctly
                                      now you need someone elses help on that problem
                                        Saabman Project Sponsor
                                        Just wanted to say thanks for posting these instructions just secured my calendar. Much apreciated
                                        • A
                                          anhanyoung @Beh
                                          @Beh Okay, I apologize because I’m sure this is a very basic question but how do you create an array in the config? I tried doing [], [] but that didn’t work.
                                          Also, I keep getting this error when discovering and press y.
                                          Should vdirsyncer attempt to create it? [y/N]: y
                                          error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                                          How can I bypass this?
                                          • A
                                            anhanyoung
                                            @sdetweil Any idea why I’m getting an error when running discover and saying yes to sync?
                                            error: Use -vdebug to see the full traceback.
                                            • 7 / 9
