    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 445.5k Views 65 Watching
      mr190e @mr190e
      @mr190e said in Sync private iCloud calendar with MagicMirror:
      @ggfuzzy Where is that file? I’m too much of a noob to find it :D
      Seems like I got to work again.
      First of all, I installed vdirsyncer via
      “sudo apt-get install vdirsyncer”,
      and not using pip.
      Second the command to start the systemd timer
      systemctl --user enable vdirsyncer.timer
      did not work at all. When typing
      systemctl --user status vdirsyncer.timer
      It always said the timer was dead. So I started it with its start command:
      systemctl --user start vdirsyncer.timer
      Third, I made the modification to vdirsyncer.service as suggested by @Beh
      Run
      which vdirsyncer
      And remember the path. After, edit the vdirsyncer.service file
      sudo nano /etc/systemd/user/vdirsyncer.service
      Correct the right path after “ExecStart”. My .service file looks like this:
      [Unit]
      Description=Synchronize calendars and contacts
      Documentation=https://vdirsyncer.readthedocs.org/
      [Service]
      ExecStart=/home/pi/.local/bin/vdirsyncer sync
      RuntimeMaxSec=3m
      Restart=on-failure
        spor4
        I get the the message:
        Error in calendar module. Check logs for more details.
        ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/0505190Dxxxxxxxxxxxxxxxx.ics Error: Not Found
        at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
        it would be awesome if somebody can help me.
          sdetweil @spor4
          @spor4 said in Sync private iCloud calendar with MagicMirror:
          where did the syncher put the ics file… cause its not there
          ps, on linux/raspina all filenames are case sensitive
          cd ~/MagicMirror/modules
          ls -laF
          to see the file list
            spor4 @sdetweil
            thank you very much. I moved the file to /modules and not it is working. Unfortunately now it says “no upcoming events.”
              sdetweil @spor4
              @spor4 that file should just be text
              u can edit it
              it should look like this layout
              BEGIN:VCALENDAR
              BEGIN:VEVENT
              END:VEVENT
              repeat for all events
              END:VCALENDAR
                spor4 @sdetweil
                @sdetweil sorry for asking stupid (total noob), I should edit the .ics file with the text editor into this?
                If I do so it says Error in calendar module. Check logs for more details. again
                BEGIN:VCALENDAR
                BEGIN:VEVENT
                END:VEVENT
                END:VCALENDAR
                  sdetweil @spor4
                  @spor4 no. you are going to look at the generated ics file and see if it contains the format I described
                    spor4 @sdetweil
                    @sdetweil no it’s empty
                      sdetweil @spor4
                      @spor4 then thats why no events on the calendar…
                      so the syncher didn’t work correctly
                      now you need someone elses help on that problem
                        Saabman Project Sponsor
                        Just wanted to say thanks for posting these instructions just secured my calendar. Much apreciated
                        A 1 Reply Last reply
                        • A
                          anhanyoung @Beh
                          @Beh Okay, I apologize because I’m sure this is a very basic question but how do you create an array in the config? I tried doing [], [] but that didn’t work.
                          Also, I keep getting this error when discovering and press y.
                          Should vdirsyncer attempt to create it? [y/N]: y
                          error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                          How can I bypass this?
                          • A
                            anhanyoung
                            @sdetweil Any idea why I’m getting an error when running discover and saying yes to sync?
                            error: Use -vdebug to see the full traceback.
                              sdetweil @anhanyoung
                              @anhanyoung I do not know anything about this syncing tool, never had to use it
                              • A
                                anhanyoung91 @Saabman
                                @Saabman do you know how to get the syncer to work? I keep getting an error saying I don’t have permissions to /home/pi
                                S S 2 Replies Last reply
                                  sdetweil @anhanyoung91
                                  @anhanyoung91 please don’t double post, all posts from users w reputation below 2 are reviewed
                                    @anhanyoung how to create array
                                     name_of_field: [],
                                    you are not just creating an array. you are creating a field that IS an array
                                    • A
                                      anhanyoung91 @sdetweil
                                      @sdetweil sounds good. Sorry about that. New to this forum and I wanted to tag him too. I suppose I could have just used @
                                        Saabman Project Sponsor @anhanyoung91
                                        @anhanyoung91 Hi, I just followed the instructions on the first page.
                                        I did have an issue at one point and it was just because I didn’t follow the instructions exactly as written.
                                        If your getting an error Permission denied: /home/pi to me that sounds like you may not have the path to the vdirsyncer status folder set right. It appears it is trying to write to the /home/pi folder rather than ~/.vdirsyncer/status/
                                        Id go through the steps again and make sure you don’t skip anything.
                                        As for the array issue in the vdirsyncer config I have 2 calendars I sync and the line looks something like this
                                        where home is my main calendar and the random number string is my birthdays calendar.
                                        collections = ["home","57B7E3E-AB79-4DC3-9CF1-A63EB181DB"]
                                        hope that helps
                                        A 2 Replies Last reply
                                        • A
                                          @Saabman thank you so much for the reply. I’ll trace my steps and give it a shot!
                                          • A
                                            @Saabman I’ve literally re-done the steps over and over and I keep getting the permissions error. Have any other ideas what might be causing this or how to fix it? Thanks in advance
                                            • 7 / 9
