    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 443.5k Views 65 Watching
    • AssassinsA
      Assassins @sdetweil
      @sdetweil No, only the .ics to you Icloud Calendar
      • G
        ggfuzzy
        Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
        M R 2 Replies Last reply
          mr190e @ggfuzzy
          @ggfuzzy Where is that file? I’m too much of a noob to find it :D
          M 1 Reply Last reply
            mr190e @mr190e
            @mr190e said in Sync private iCloud calendar with MagicMirror:
            Seems like I got to work again.
            First of all, I installed vdirsyncer via
            “sudo apt-get install vdirsyncer”,
            and not using pip.
            Second the command to start the systemd timer
            systemctl --user enable vdirsyncer.timer
            did not work at all. When typing
            systemctl --user status vdirsyncer.timer
            It always said the timer was dead. So I started it with its start command:
            systemctl --user start vdirsyncer.timer
            Third, I made the modification to vdirsyncer.service as suggested by @Beh
            Run
            which vdirsyncer
            And remember the path. After, edit the vdirsyncer.service file
            sudo nano /etc/systemd/user/vdirsyncer.service
            Correct the right path after “ExecStart”. My .service file looks like this:
            [Unit]
            Description=Synchronize calendars and contacts
            Documentation=https://vdirsyncer.readthedocs.org/
            [Service]
            ExecStart=/home/pi/.local/bin/vdirsyncer sync
            RuntimeMaxSec=3m
            Restart=on-failure
              spor4
              I get the the message:
              Error in calendar module. Check logs for more details.
              ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/0505190Dxxxxxxxxxxxxxxxx.ics Error: Not Found
              at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
              it would be awesome if somebody can help me.
                sdetweil @spor4
                @spor4 said in Sync private iCloud calendar with MagicMirror:
                where did the syncher put the ics file… cause its not there
                ps, on linux/raspina all filenames are case sensitive
                cd ~/MagicMirror/modules
                ls -laF
                to see the file list
                  spor4 @sdetweil
                  thank you very much. I moved the file to /modules and not it is working. Unfortunately now it says “no upcoming events.”
                    sdetweil @spor4
                    @spor4 that file should just be text
                    u can edit it
                    it should look like this layout
                    BEGIN:VCALENDAR
                    BEGIN:VEVENT
                    END:VEVENT
                    repeat for all events
                    END:VCALENDAR
                      spor4 @sdetweil
                      @sdetweil sorry for asking stupid (total noob), I should edit the .ics file with the text editor into this?
                      If I do so it says Error in calendar module. Check logs for more details. again
                      BEGIN:VCALENDAR
                      BEGIN:VEVENT
                      END:VEVENT
                      END:VCALENDAR
                        sdetweil @spor4
                        @spor4 no. you are going to look at the generated ics file and see if it contains the format I described
                          spor4 @sdetweil
                          @sdetweil no it’s empty
                            sdetweil @spor4
                            @spor4 then thats why no events on the calendar…
                            so the syncher didn’t work correctly
                            now you need someone elses help on that problem
                              Saabman Project Sponsor
                              Just wanted to say thanks for posting these instructions just secured my calendar. Much apreciated
                              A 1 Reply Last reply
                              • A
                                anhanyoung @Beh
                                @Beh Okay, I apologize because I’m sure this is a very basic question but how do you create an array in the config? I tried doing [], [] but that didn’t work.
                                Also, I keep getting this error when discovering and press y.
                                Should vdirsyncer attempt to create it? [y/N]: y
                                error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                                How can I bypass this?
                                • A
                                  anhanyoung
                                  @sdetweil Any idea why I’m getting an error when running discover and saying yes to sync?
                                  error: Use -vdebug to see the full traceback.
                                    sdetweil @anhanyoung
                                    @anhanyoung I do not know anything about this syncing tool, never had to use it
                                    • A
                                      anhanyoung91 @Saabman
                                      @Saabman do you know how to get the syncer to work? I keep getting an error saying I don’t have permissions to /home/pi
                                      S S 2 Replies Last reply
                                        sdetweil @anhanyoung91
                                        @anhanyoung91 please don’t double post, all posts from users w reputation below 2 are reviewed
                                          @anhanyoung how to create array
                                           name_of_field: [],
                                          you are not just creating an array. you are creating a field that IS an array
                                          • A
                                            anhanyoung91 @sdetweil
                                            @sdetweil sounds good. Sorry about that. New to this forum and I wanted to tag him too. I suppose I could have just used @
                                            • 7 / 9
