    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 437.1k Views 65 Watching
      sdetweil @Assassins
      @assassins is there supposed to be a script added to that folder?
      AssassinsA 1 Reply Last reply Reply Quote 0
      • AssassinsA
        Assassins @sdetweil
        @sdetweil No, only the .ics to you Icloud Calendar
        • G
          ggfuzzy
          Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
          M R 2 Replies Last reply Reply Quote 0
            mr190e @ggfuzzy
            @ggfuzzy Where is that file? I’m too much of a noob to find it :D
              mr190e @mr190e
              @mr190e said in Sync private iCloud calendar with MagicMirror:
              Seems like I got to work again.
              First of all, I installed vdirsyncer via
              “sudo apt-get install vdirsyncer”,
              and not using pip.
              Second the command to start the systemd timer
              systemctl --user enable vdirsyncer.timer
              did not work at all. When typing
              systemctl --user status vdirsyncer.timer
              It always said the timer was dead. So I started it with its start command:
              systemctl --user start vdirsyncer.timer
              Third, I made the modification to vdirsyncer.service as suggested by @Beh
              Run
              which vdirsyncer
              And remember the path. After, edit the vdirsyncer.service file
              sudo nano /etc/systemd/user/vdirsyncer.service
              Correct the right path after “ExecStart”. My .service file looks like this:
              [Unit]
              Description=Synchronize calendars and contacts
              Documentation=https://vdirsyncer.readthedocs.org/
              [Service]
              ExecStart=/home/pi/.local/bin/vdirsyncer sync
              RuntimeMaxSec=3m
              Restart=on-failure
                spor4
                I get the the message:
                Error in calendar module. Check logs for more details.
                ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/0505190Dxxxxxxxxxxxxxxxx.ics Error: Not Found
                at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
                it would be awesome if somebody can help me.
                  sdetweil @spor4
                  @spor4 said in Sync private iCloud calendar with MagicMirror:
                  where did the syncher put the ics file… cause its not there
                  ps, on linux/raspina all filenames are case sensitive
                  cd ~/MagicMirror/modules
                  ls -laF
                  to see the file list
                    spor4 @sdetweil
                    thank you very much. I moved the file to /modules and not it is working. Unfortunately now it says “no upcoming events.”
                      sdetweil @spor4
                      @spor4 that file should just be text
                      u can edit it
                      it should look like this layout
                      BEGIN:VCALENDAR
                      BEGIN:VEVENT
                      END:VEVENT
                      repeat for all events
                      END:VCALENDAR
                        spor4 @sdetweil
                        @sdetweil sorry for asking stupid (total noob), I should edit the .ics file with the text editor into this?
                        If I do so it says Error in calendar module. Check logs for more details. again
                        BEGIN:VCALENDAR
                        BEGIN:VEVENT
                        END:VEVENT
                        END:VCALENDAR
                          sdetweil @spor4
                          @spor4 no. you are going to look at the generated ics file and see if it contains the format I described
                            spor4 @sdetweil
                            @sdetweil no it’s empty
                              sdetweil @spor4
                              @spor4 then thats why no events on the calendar…
                              so the syncher didn’t work correctly
                              now you need someone elses help on that problem
                                Saabman Project Sponsor
                                Just wanted to say thanks for posting these instructions just secured my calendar. Much apreciated
                                • A
                                  anhanyoung @Beh
                                  @Beh Okay, I apologize because I’m sure this is a very basic question but how do you create an array in the config? I tried doing [], [] but that didn’t work.
                                  Also, I keep getting this error when discovering and press y.
                                  Should vdirsyncer attempt to create it? [y/N]: y
                                  error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                                  How can I bypass this?
                                  • A
                                    anhanyoung
                                    @sdetweil Any idea why I’m getting an error when running discover and saying yes to sync?
                                    error: Use -vdebug to see the full traceback.
                                      sdetweil @anhanyoung
                                      @anhanyoung I do not know anything about this syncing tool, never had to use it
                                      • A
                                        anhanyoung91 @Saabman
                                        @Saabman do you know how to get the syncer to work? I keep getting an error saying I don’t have permissions to /home/pi
                                        S S 2 Replies Last reply Reply Quote 0
                                          sdetweil @anhanyoung91
                                          @anhanyoung91 please don’t double post, all posts from users w reputation below 2 are reviewed
                                            @anhanyoung how to create array
                                             name_of_field: [],
                                            you are not just creating an array. you are creating a field that IS an array
                                            • 7 / 9
