    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 440.5k Views 65 Watching
    • T
      Tribun @jlnxaer
      @jlnxaer
      (/home/pi/.vdirsyncer/status) is a hidden folder in /home/pi
      you can also find the pm2 log in /home/pi/.pm2/logs this is also hidden.
        Beh
        I have another hint related to the systemd timer that was originally described in my tutorial.
        It is advised to download the vdirsyncer.service and vdirsyncer.timer directly from the web.
        You need to adjust the path to the executable in the vdirsyncer.service file!
        It defaults to ExecStart=/usr/bin/vdirsyncer sync, which can be wrong.
        But probably it is in ~/.local/bin. (Can be different depending on your installation. Just check location with which vdirsyncer.
        This should make the initially described automatic sync work again.
          Beh @Jaunney
          @Jaunney I don’t see that this has ben answered yet.
          collections = [“UUID1”, “UUID2”, “UUID3”] is what I use in my config and it works.
          Of course, you need to add a new calender to your calender module to make them visible on the mirror. You need one for every UUID. If you look into your target sync folder on the Pi, there should be 3 .ics files for each UUID. Those are, in fact, 3 separate calendars
          • N
            Nd_27
            Hey,
            im new to this but trying my best.
            The Sync with calendar works fine, but the sync to the reminders won’t work.
            I added the “VTODO” but there are do VTODO in the *.ics File.
            Does i have to do anything else and how the calendar shown the Reminders?
            Sorry again, im very new and this is my very first project.
            best regards
            Niklas
              mwallis
              Ok … Trying to sync my iCal calendars and I get this every time:
              error: Unknown error occurred: name 'r130' is not defined
              error: Use `-vdebug` to see the full traceback.
              error: 1 out of 1 tasks failed.
              Any ideas?
              • AssassinsA
                Assassins
                @Beh thanks for this. everything is working fine for me just a small error I wanted to ask about in my /home/pi/.pm2/logs/MagicMirror-error.log, it complains the following:
                ERROR! Could not find main module js file for calendars
                Its not a show stopper but because the calendars folder is created in the modules folder this is why it is asking for a js file.
                  sdetweil @Assassins
                  @assassins calendar is actually in the modules/default folder
                  AssassinsA 1 Reply Last reply Reply Quote 0
                  • AssassinsA
                    Assassins @sdetweil
                    @sdetweil Yes i now, but i have do all the step, and this error come up
                      sdetweil @Assassins
                      @assassins but u said the calendar folder was created. and its looking for the js file… so i think you didnt use the right folder
                      • AssassinsA
                        Assassins @sdetweil
                        @sdetweil The step to this synsc iCloud calendar is
                        mkdir /home/pi/MagicMirror/modules/calendars
                          sdetweil @Assassins
                          @assassins is there supposed to be a script added to that folder?
                          • AssassinsA
                            Assassins @sdetweil
                            @sdetweil No, only the .ics to you Icloud Calendar
                            • G
                              ggfuzzy
                              Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
                              M R 2 Replies Last reply Reply Quote 0
                                mr190e @ggfuzzy
                                @ggfuzzy Where is that file? I’m too much of a noob to find it :D
                                  mr190e @mr190e
                                  @mr190e said in Sync private iCloud calendar with MagicMirror:
                                  Seems like I got to work again.
                                  First of all, I installed vdirsyncer via
                                  “sudo apt-get install vdirsyncer”,
                                  and not using pip.
                                  Second the command to start the systemd timer
                                  systemctl --user enable vdirsyncer.timer
                                  did not work at all. When typing
                                  systemctl --user status vdirsyncer.timer
                                  It always said the timer was dead. So I started it with its start command:
                                  systemctl --user start vdirsyncer.timer
                                  Third, I made the modification to vdirsyncer.service as suggested by @Beh
                                  Run
                                  which vdirsyncer
                                  And remember the path. After, edit the vdirsyncer.service file
                                  sudo nano /etc/systemd/user/vdirsyncer.service
                                  Correct the right path after “ExecStart”. My .service file looks like this:
                                  [Unit]
                                  Description=Synchronize calendars and contacts
                                  Documentation=https://vdirsyncer.readthedocs.org/
                                  [Service]
                                  ExecStart=/home/pi/.local/bin/vdirsyncer sync
                                  RuntimeMaxSec=3m
                                  Restart=on-failure
                                    spor4
                                    I get the the message:
                                    Error in calendar module. Check logs for more details.
                                    ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/0505190Dxxxxxxxxxxxxxxxx.ics Error: Not Found
                                    at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
                                    it would be awesome if somebody can help me.
                                      sdetweil @spor4
                                      @spor4 said in Sync private iCloud calendar with MagicMirror:
                                      where did the syncher put the ics file… cause its not there
                                      ps, on linux/raspina all filenames are case sensitive
                                      cd ~/MagicMirror/modules
                                      ls -laF
                                      to see the file list
                                        spor4 @sdetweil
                                        thank you very much. I moved the file to /modules and not it is working. Unfortunately now it says “no upcoming events.”
                                          sdetweil @spor4
                                          @spor4 that file should just be text
                                          u can edit it
                                          it should look like this layout
                                          BEGIN:VCALENDAR
                                          BEGIN:VEVENT
                                          END:VEVENT
                                          repeat for all events
                                          END:VCALENDAR
                                            spor4 @sdetweil
                                            @sdetweil sorry for asking stupid (total noob), I should edit the .ics file with the text editor into this?
                                            If I do so it says Error in calendar module. Check logs for more details. again
                                            BEGIN:VCALENDAR
                                            BEGIN:VEVENT
                                            END:VEVENT
                                            END:VCALENDAR
                                            • 7 / 9
