    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 440.5k Views 65 Watching
      spor4 @sdetweil
      @sdetweil no it’s empty
        sdetweil @spor4
        @spor4 then thats why no events on the calendar…
        so the syncher didn’t work correctly
        now you need someone elses help on that problem
          Saabman Project Sponsor
          Just wanted to say thanks for posting these instructions just secured my calendar. Much apreciated
          • A
            anhanyoung @Beh
            @Beh Okay, I apologize because I’m sure this is a very basic question but how do you create an array in the config? I tried doing [], [] but that didn’t work.
            Also, I keep getting this error when discovering and press y.
            Should vdirsyncer attempt to create it? [y/N]: y
            error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
            How can I bypass this?
            • A
              anhanyoung
              @sdetweil Any idea why I’m getting an error when running discover and saying yes to sync?
              error: Use -vdebug to see the full traceback.
                sdetweil @anhanyoung
                @anhanyoung I do not know anything about this syncing tool, never had to use it
                • A
                  anhanyoung91 @Saabman
                  @Saabman do you know how to get the syncer to work? I keep getting an error saying I don’t have permissions to /home/pi
                  S S 2 Replies Last reply Reply Quote 0
                    sdetweil @anhanyoung91
                    @anhanyoung91 please don’t double post, all posts from users w reputation below 2 are reviewed
                      @anhanyoung how to create array
                       name_of_field: [],
                      you are not just creating an array. you are creating a field that IS an array
                      • A
                        anhanyoung91 @sdetweil
                        @sdetweil sounds good. Sorry about that. New to this forum and I wanted to tag him too. I suppose I could have just used @
                          Saabman Project Sponsor @anhanyoung91
                          @anhanyoung91 Hi, I just followed the instructions on the first page.
                          I did have an issue at one point and it was just because I didn’t follow the instructions exactly as written.
                          If your getting an error Permission denied: /home/pi to me that sounds like you may not have the path to the vdirsyncer status folder set right. It appears it is trying to write to the /home/pi folder rather than ~/.vdirsyncer/status/
                          Id go through the steps again and make sure you don’t skip anything.
                          As for the array issue in the vdirsyncer config I have 2 calendars I sync and the line looks something like this
                          where home is my main calendar and the random number string is my birthdays calendar.
                          collections = ["home","57B7E3E-AB79-4DC3-9CF1-A63EB181DB"]
                          hope that helps
                          A 2 Replies Last reply Reply Quote 0
                          • A
                            @Saabman thank you so much for the reply. I’ll trace my steps and give it a shot!
                            • A
                              @Saabman I’ve literally re-done the steps over and over and I keep getting the permissions error. Have any other ideas what might be causing this or how to fix it? Thanks in advance
                                @anhanyoung91 did u do the tutorial
                                https://vdirsyncer.pimutils.org/en/stable/tutorial.html
                                • A
                                  Alfnie
                                  I run into a problem with vdirsyncer (discover) which is raised some times before in this thread, but I can’t find the solution. I have tried with other internet resources to solve my problem, but I ran out of options. Hopefully one of you can help me troubleshoot.
                                  1.) First, I successfully followed the steps of @Beh with additionally the clean, easy way from here:
                                  https://vdirsyncer.pimutils.org/en/stable/installation.html#the-clean-hard-way
                                  I got stuck at the part: Let vdirsyncer discover the collections and do the inital sync, with the command vdirsyncer discover. It returned:
                                  adm@raspberrypi:~ $ vdirsyncer discover
                                    File "/home/adm/.local/bin/vdirsyncer", line 5, in <module>
                                      from vdirsyncer.cli import main
                                  ModuleNotFoundError: No module named 'vdirsyncer'
                                  2.) Second, I followed the routine from @mr190e, on page 13 in this thread (link), after i used pipx uninstall vdirsyncer from The clean, easy way.
                                  Seems like I got to work again.
                                  First of all, I installed vdirsyncer via
                                  “sudo apt-get install vdirsyncer”,
                                  and not using pip.
                                  Now, vdirsyncer discover returns:
                                  critical: Error during reading config /home/adm/.config/vdirsyncer/config: [Errno 2] No such file or directory: '/home/adm/.config/vdirsyncer/config'
                                  Now I am out of tricks, I’m not sure how to troubleshoot this. What do I need to check, or to modify, to get it to work…
                                  Thanks advance for your help!
                                  • A Alfnie referenced this topic on
                                    sdetweil @Alfnie
                                    @Alfnie so create the folder .config/.vdirsyncer
                                    And add the config file there
                                    • A
                                      Alfnie @sdetweil
                                      Thanks for your reply, it sounds simple, however it seems complicated for me.
                                      I do as you say by taking these commands from the instruction (is this correct?)
                                      mkdir /home/adm/.config/vdirsyncer/
                                      touch /home/adm/.config/vdirsyncer/config
                                      nano /home/adm/.config/vdirsyncer/config
                                      It results in:
                                      admns@raspberrypi:~ $ mkdir /home/adm/.config/vdirsyncer/
                                      mkdir: cannot create directory ‘/home/adm/.config/vdirsyncer/’: No such file or directory
                                      admns@raspberrypi:~ $ touch /home/adm/.config/vdirsyncer/config
                                      touch: cannot touch '/home/adm/.config/vdirsyncer/config': No such file or directory
                                      How should I create the folder .config/.vdirsyncer as you pointed out?
                                        sdetweil @Alfnie
                                        @Alfnie you missed the . in front of vdirsyncer…
                                        the dot on linux makes the folder ‘hidden’ from normal ls commands… as linux file system doesn’t have a hidden attribute
                                          @Alfnie
                                          who is adm? should be the current username (pi?)
                                          always best to use the shortcut
                                          ~/.config
                                          ~ means the home folder of the current user , same as
                                          /home/$USER
                                          or /home/pi is pi is logged in
                                          • A
                                            Alfnie @sdetweil
                                            Thanks, it works now.
                                            Also, I have learned about the dot (.) implying Hidden folders, thanks.
                                            Tomorrow I’m gonna try to add multiple calendars.
                                            • 8 / 9
