    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 425.5k Views 65 Watching
      sdetweil @anhanyoung91
      @anhanyoung91 please don’t double post, all posts from users w reputation below 2 are reviewed
        @anhanyoung how to create array
         name_of_field: [],
        you are not just creating an array. you are creating a field that IS an array
          anhanyoung91 @sdetweil
          @sdetweil sounds good. Sorry about that. New to this forum and I wanted to tag him too. I suppose I could have just used @
            Saabman Project Sponsor @anhanyoung91
            @anhanyoung91 Hi, I just followed the instructions on the first page.
            I did have an issue at one point and it was just because I didn’t follow the instructions exactly as written.
            If your getting an error Permission denied: /home/pi to me that sounds like you may not have the path to the vdirsyncer status folder set right. It appears it is trying to write to the /home/pi folder rather than ~/.vdirsyncer/status/
            Id go through the steps again and make sure you don’t skip anything.
            As for the array issue in the vdirsyncer config I have 2 calendars I sync and the line looks something like this
            where home is my main calendar and the random number string is my birthdays calendar.
            collections = ["home","57B7E3E-AB79-4DC3-9CF1-A63EB181DB"]
            hope that helps
            A 2 Replies Last reply Reply Quote 0
              anhanyoung91 @Saabman
              @Saabman thank you so much for the reply. I’ll trace my steps and give it a shot!
                @Saabman I’ve literally re-done the steps over and over and I keep getting the permissions error. Have any other ideas what might be causing this or how to fix it? Thanks in advance
                  @anhanyoung91 did u do the tutorial
                  https://vdirsyncer.pimutils.org/en/stable/tutorial.html
                    Alfnie
                    I run into a problem with vdirsyncer (discover) which is raised some times before in this thread, but I can’t find the solution. I have tried with other internet resources to solve my problem, but I ran out of options. Hopefully one of you can help me troubleshoot.
                    1.) First, I successfully followed the steps of @Beh with additionally the clean, easy way from here:
                    https://vdirsyncer.pimutils.org/en/stable/installation.html#the-clean-hard-way
                    I got stuck at the part: Let vdirsyncer discover the collections and do the inital sync, with the command vdirsyncer discover. It returned:
                    adm@raspberrypi:~ $ vdirsyncer discover
                      File "/home/adm/.local/bin/vdirsyncer", line 5, in <module>
                        from vdirsyncer.cli import main
                    ModuleNotFoundError: No module named 'vdirsyncer'
                    2.) Second, I followed the routine from @mr190e, on page 13 in this thread (link), after i used pipx uninstall vdirsyncer from The clean, easy way.
                    Seems like I got to work again.
                    First of all, I installed vdirsyncer via
                    “sudo apt-get install vdirsyncer”,
                    and not using pip.
                    Now, vdirsyncer discover returns:
                    critical: Error during reading config /home/adm/.config/vdirsyncer/config: [Errno 2] No such file or directory: '/home/adm/.config/vdirsyncer/config'
                    Now I am out of tricks, I’m not sure how to troubleshoot this. What do I need to check, or to modify, to get it to work…
                    Thanks advance for your help!
                    • A Alfnie referenced this topic on
                      sdetweil @Alfnie
                      @Alfnie so create the folder .config/.vdirsyncer
                      And add the config file there
                        Alfnie @sdetweil
                        Thanks for your reply, it sounds simple, however it seems complicated for me.
                        I do as you say by taking these commands from the instruction (is this correct?)
                        mkdir /home/adm/.config/vdirsyncer/
                        touch /home/adm/.config/vdirsyncer/config
                        nano /home/adm/.config/vdirsyncer/config
                        It results in:
                        admns@raspberrypi:~ $ mkdir /home/adm/.config/vdirsyncer/
                        mkdir: cannot create directory ‘/home/adm/.config/vdirsyncer/’: No such file or directory
                        admns@raspberrypi:~ $ touch /home/adm/.config/vdirsyncer/config
                        touch: cannot touch '/home/adm/.config/vdirsyncer/config': No such file or directory
                        How should I create the folder .config/.vdirsyncer as you pointed out?
                          sdetweil @Alfnie
                          @Alfnie you missed the . in front of vdirsyncer…
                          the dot on linux makes the folder ‘hidden’ from normal ls commands… as linux file system doesn’t have a hidden attribute
                            @Alfnie
                            who is adm? should be the current username (pi?)
                            always best to use the shortcut
                            ~/.config
                            ~ means the home folder of the current user , same as
                            /home/$USER
                            or /home/pi is pi is logged in
                              Alfnie @sdetweil
                              Thanks, it works now.
                              Also, I have learned about the dot (.) implying Hidden folders, thanks.
                              Tomorrow I’m gonna try to add multiple calendars.
                              • kaiK Offline
                                kai @Beh
                                Hi @Beh,
                                thank you very much for this detailed description. This was exactly what I was looking for for my MM, and with your step-by-step instructions it worked for me straight away.
                                Happy New Year and thank you very much again!!! :thumbs_up:
                                May the code be with you
                                -kai
                                  JamesScreech
                                  Thanks for the detailed description, I’ve done this and it works most of the time, however one of my calendars is not updating.
                                  I know very little about Pi’s and am new to Linux it general, are there any suggestions on how to find issues?
                                    JamesScreech @JamesScreech
                                    The problem with not updating looks like it’s related to one of my calendars not having any entries in the requested timescale. If all calendars have entries then they sync however if one (in my case the last one) has no entries then there are no updates. Very strange.
                                    • D dubbedMonster referenced this topic on
                                      raisins @ggfuzzy
                                      @Gailby said in Sync private iCloud calendar with MagicMirror:
                                      @Gailby @ganther @Beh the ics files doesn’t seem to sync in Calendars… all files are empty. Have anyone resolved this?
                                      @ganther said in Sync private iCloud calendar with MagicMirror:
                                      Hi there,
                                      i followed the instructions, my calendars are shown in discovery.
                                      I copied the UUID and it starts syncing, but the saved files are 0kb.
                                      I tried several calendars and checked the UUID’s but can’t find any mistake?
                                      any ideas?
                                      thanks!!
                                      @maestro82
                                      Did you check your calendar-url in conf/config.js?
                                      My calendar is running now correctly. Don‘t know why but now my ics-file isn‘t empty anymore.
                                      @ggfuzzy said in Sync private iCloud calendar with MagicMirror:
                                      Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
                                      I’m getting this same thing. The .ics files are created, but they’re empty. Everything up to there is working. The iCloud credentials must be correct as it’s talking to me and I can see the names and uuids of the remote calendars when I use “vdirsync discover”. I just don’t get any events into the local files with “vdirsync sync”.
                                      I’m aware this is more a vdirsync issue than MagicMirror, but did any of you folks having this problem ever figure it out?
                                        aceahspades
                                        Hello! I can get to the point where I update my collections, but when I run the discover feature again and enter y + enter I get this error message
                                        error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                                        error: Use -vdebug to see the full traceback.
                                        Is there a fix for this?
                                          sdetweil @aceahspades
                                          @aceahspades is the userid you are logged on as
                                          pi??
                                          if not you should change that string the /user/xxxxx
                                          where xxxxx is your logged on username
                                            aceahspades @sdetweil
                                            @sdetweil Up and running, thank you so very much!
                                            • 8 / 9
