    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      josh45631 @sdetweil
      @sdetweil I did have showQR set to true in the module config, but the QR code wasn’s showing up.
      After changing the address in the mm config from localhost to 0.0.0.0 the QR code is now appearing on the magic mirror.
      Now when I try to access the form from my pc I get “This device is not allowed to access your mirror.
      Please check your config.js or config.js.sample to change this.”
      and the terminal on the pi says “Access denied to IP address: 192.168.2.5”
      I tried to add it to the ipWhitelist, but I don’t think I have the proper format because it’s not working?
      Module entry is:
                             module:"MMM-Config",
                             position:"top_right",  // the QR code (if requested) will appear here
                             config:{
                             module: "alert",
                             module: "updatenotification",
                             position: "top_bar"
                             module: "clock",
                             position: "top_left"
                             header: "US Holidays",
                                                     symbol: "calendar-check",
                                                     url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      etc
      This is how I tried to whitelist my computers ip
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","192.168.2.5"],    // Set [] to allow all IP addresses
      I appreciate your help very much!
        sdetweil @josh45631
        @josh45631 said in Are you tired of editing config.js, or have trouble doing it, see my new module:
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,“192.168.2.5”],
        this means ONLY apps on THIS machine (127.0.0.1 = localhost) are allowed to connect, EVEN if address: is NOT localhost
        1st thing to do is disable whitelist , set to [] (means no ip filtering)
        fix it after u get things working
        also u really want to add
        showQR:true
        in the MMM-Config
        config section
                               config:{
                                      showQR:true
          josh45631 @sdetweil
          @sdetweil Ok here’s where I am. I think I’ve made the proper changes in the config file.
          Changed address to 0.0.0.0
          Changed ipWhitelist to []
          Added showQR: “true”
          * Magic Mirror Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * see https://docs.magicmirror.builders/getting-started/configuration.html#general
           * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
                  address: "0.0.0.0",     // Address to listen on, can be:
                  port: 8080,
                  basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                  ipWhitelist: [],        // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.168>
        // ["127.0.0.1", "::ffff:127.0.0.1",>
        // or IPv4 range of 192.168.3.0 --> >
                  useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                  httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                  httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                  language: "en",
                  locale: "en-US",
                  timeFormat: 24,
                  units: "metric",
                                  config:{
                                          showQR: "true"
                                  module: "alert",
                                  position: "top_bar"
                                  module: "clock",
                                  module: "compliments",
                                  position: "lower_third"
                                  module: "weather",
                                          type: "current",
                                          locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                          apiKey: "YOUR_OPENWEATHER_API_KEY"
                                  module: "weather",
                                  header: "Weather Forecast",
                                          type: "forecast",
                                          locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your ci>
                                  module: "newsfeed",
                                  position: "bottom_bar",
                                          feeds: [
                                                          title: "New York Times",
                                                          url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                          showSourceTitle: true,
                                          showPublishDate: true,
                                          broadcastNewsFeeds: true,
                                          broadcastNewsUpdates: true
          The QR code is showing up in the top right of the magic mirror.
          When I try to navigate to
          http://192.168.2.13:8080/modules/MM-Config/review
          all I get is “Cannot GET /modules/MM-Config/review”
          If it helps, this is the terminal output at startup:
          [27.11.2021 23:08.01.269] [LOG]   Starting MagicMirror: v2.17.1
          [27.11.2021 23:08.01.283] [LOG]   Loading config ...
          [27.11.2021 23:08.01.296] [LOG]   Loading module helpers ...
          [27.11.2021 23:08.01.954] [LOG]   Initializing new module helper ...
          [27.11.2021 23:08.01.956] [LOG]   Module helper loaded: MMM-Config
          [27.11.2021 23:08.01.959] [LOG]   No helper found for module: alert.
          [27.11.2021 23:08.01.968] [LOG]   Initializing new module helper ...
          [27.11.2021 23:08.01.969] [LOG]   Module helper loaded: updatenotification
          [27.11.2021 23:08.01.971] [LOG]   No helper found for module: clock.
          [27.11.2021 23:08.02.295] [LOG]   Initializing new module helper ...
          [27.11.2021 23:08.02.296] [LOG]   Module helper loaded: calendar
          [27.11.2021 23:08.02.298] [LOG]   No helper found for module: compliments.
          [27.11.2021 23:08.02.301] [LOG]   No helper found for module: weather.
          [27.11.2021 23:08.02.348] [LOG]   Initializing new module helper ...
          [27.11.2021 23:08.02.349] [LOG]   Module helper loaded: newsfeed
          [27.11.2021 23:08.02.350] [LOG]   All module helpers loaded.
          [27.11.2021 23:08.02.521] [LOG]   Starting server on port 8080 ...
          [27.11.2021 23:08.02.532] [WARN]  You're using a full whitelist configuration to allow for all IPs
          [27.11.2021 23:08.02.545] [LOG]   Server started ...
          [27.11.2021 23:08.02.547] [LOG]   Connecting socket for: MMM-Config
          [27.11.2021 23:08.02.548] [LOG]   Starting module helper: MMM-Config
          [27.11.2021 23:08.02.550] [LOG]   Connecting socket for: updatenotification
          [27.11.2021 23:08.02.552] [LOG]   Connecting socket for: calendar
          [27.11.2021 23:08.02.553] [LOG]   Starting node helper for: calendar
          [27.11.2021 23:08.02.554] [LOG]   Connecting socket for: newsfeed
          [27.11.2021 23:08.02.556] [LOG]   Starting node helper for: newsfeed
          [27.11.2021 23:08.02.557] [LOG]   Sockets connected & modules started ...
          [27.11.2021 23:08.02.932] [LOG]   Launching application.
          [27.11.2021 23:08.06.686] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          [27.11.2021 23:08.07.027] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          [27.11.2021 23:08.07.039] [LOG]   MMM-Config received a socket notification: CONFIG - Payload: [object Object]
          [27.11.2021 23:08.07.042] [LOG]   command =/home/pi/MagicMirror/modules/MMM-Config/test_convert.sh override
          [27.11.2021 23:08.07.044] [LOG]   Starting module helper:MMM-Config
          [27.11.2021 23:08.07.045] [LOG]   execing /home/pi/MagicMirror/modules/MMM-Config/test_convert.sh override
          [27.11.2021 23:08.07.340] [INFO]  Checking git for module: default
          [27.11.2021 23:08.07.378] [INFO]  Checking git for module: MMM-Config
          [27.11.2021 23:08.07.579] [LOG]    got port=8300
          [27.11.2021 23:08.08.352] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
          [27.11.2021 23:08.09.037] [INFO]  Newsfeed-Fetcher: Broadcasting 55 items.
          [27.11.2021 23:08.13.839] [LOG]   stdout: completed
          I apologize if I’m being difficult. I was just getting very frustrated trying to manually configure modules, and when I stumbled across your module, I got excited! I feel like I’m overlooking something simple!:grimacing_face:
          mumblebajM S 2 Replies Last reply Reply Quote 0
          • mumblebajM
            mumblebaj Module Developer @josh45631
            showQR: “true”
            This should be showQR: true without the quotes. Not sure if it makes much of a difference.
            The URL I used and which worked for me was:
            http://localhost:8080/modules/MMM-Config/config.html?port=8300
            @sdetweil Very cool module.
              sdetweil @josh45631
              @josh45631 I had a typo which I corrected
              notice the module name is MMM-Config
              3 M’s
              the content says the module is running
              if you use your phone on the qr does the page show?
                sdetweil @mumblebaj
                @mumblebaj don’t use the final url… use the review url as provided in the doc
                as the module discovers a free port for communication between the form and the module.
                  josh45631 @sdetweil
                  @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                  3 M’s
                  :man_facepalming:
                  There it is. I knew it would come down to something simple! I still can’t get to the form page by scanning the QR code, but I’m ok with that for now because I can access it via browser!
                  Thank you so much!
                    sdetweil @josh45631
                    @josh45631 what are you using to scan the qr?
                    • mumblebajM
                      @sdetweil Which URL in the doc? From the screenshots? The review URL did not work for me. The one I posted above did. The QR code gave me a different URL which did not work for me but guess it is because of my install on my Windows laptop.
                      • mumblebajM
                        mumblebaj Module Developer @mumblebaj
                        @sdetweil I found the URL bit in the doc.
                        http://machine_name:MM_Port/modules/MMM-Config/review
                        Did not work for me when I tried it though.
                          sdetweil @mumblebaj
                          @mumblebaj u did change the symbolic names to actual, right?
                          machine_name
                          MM_port
                          right?
                            sdetweil @mumblebaj
                            @mumblebaj windows should have worked
                            can u tell me what the url was?
                            when u configure mm for address:“0.0.0.0”
                            it’s not something I can connect to
                            so I get the machine hostname
                            I guess I need to figure out an IP address…
                            • mumblebajM
                              @sdetweil The QR code gave me machine name. But I figured that could not be correct. When I used the review URL earlier it did not work, When I started my Ubuntu Instance now and tried review with this URL:
                              http://localhost:8080/modules/MMM-Config/review
                              it worked fine and resolved to the following:
                              which I guess is what you were referring to?
                                sdetweil @mumblebaj
                                @mumblebaj yes but localhost will only work w browser inside same machine as mm
                                  sdetweil @mumblebaj
                                  @mumblebaj typically dhcp addresses now register the hostname in the router DNS server.
                                    josh45631 @sdetweil
                                    @sdetweil I am using my cell phone connected to my wifi network. When I scan the code it sends me to
                                    http://raspberrypi:8080/modules/MMM-Config/review
                                    When I replace “raspberrypi” with the actual ip of the pi, it works.
                                      sdetweil @josh45631
                                      @josh45631 yes
                                      I ‘assumed’ that name will work… doesn’t…
                                      will fix, thx
                                        @josh45631 @mumblebaj do a git pull in the module folder, and then restart mm and try the qr image again
                                        • L
                                          louise
                                          When I try to use your MMM-config I get this error…
                                          pi@raspberrypi:~ $ ~/MagicMirror/modules
                                          bash: /home/pi/MagicMirror/modules: No such file or directory
                                            sdetweil @louise
                                            @louise explain a little more… where are u typing that info ?
                                            where is your MagicMirror installed?
                                            read the link in my signature How to add modules (I didn’t write it)
                                            L 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
