    Clock format
    41 Posts 2 Posters 26.2k Views 2 Watching
      sdetweil @louise
      @louise
      NEVER change the CODE
      in config.js
      			module: "clock",
      			position: "top_left"
      whatever u need to configure goes inside a config:{} section,…
      if not there, add one
      			module: "clock",
                                  .... whatever
      L 1 Reply Last reply
      • L
        louise @sdetweil
        @sdetweil I didn’t think I did change anything.
          sdetweil @louise
          @louise after the paste
          select the text in the message, and the push the </> button above the editor
          • L
            louise @sdetweil
            @sdetweil OH, that’s what you meant by block.
            But as far as changing anything in the code I didn’t, except the 12 and imperial
            L S 2 Replies Last reply
            • L
              louise @louise
              @louise
              deleted  sam
                sdetweil @louise
                @louise said in Clock format:
                then u changed something
                NEVER edit the source files… ALL changes go thru config.js
                the design is that things u specify in config.js override thing in the source code… so you NEVER have to touch the source file.
                if you DON’T specify something, then the module default setting will be used…
                (each module should document what that is… )
                  sdetweil @louise
                  @louise again you are pasting the source code… and missed a step,
                  after the paste into the message here, SELECT the text AGAIN, and then push the code button
                  we want to see what settings are in config.js for clock, not clock.js
                  • L
                    louise @sdetweil
                    aaaaa
                    • L
                      louise @louise
                      @louise I forgot to take out private stuff again
                        sdetweil @louise
                        @louise nope, still don’t want to see the code
                        edit your ~/MagicMirror/config/config.js
                        find the section that says
                           module:"clock"
                        and copy from the line above that is
                        to the macthing line below
                        that is
                        and paste THAT, and then select it all (ctrl a)
                        and then it the button
                        please read the two topics below in my signature…
                        • L
                          louise @sdetweil
                          @sdetweil This?
                          		module: "clock",
                          code_text
                          			module: "clock",
                          code_text
                            sdetweil @louise
                            @louise hmm… still not sure what the problem is
                            select/copy from config.js
                            replay to message here
                            paste text
                            ctrl-a (select all)
                            (it will have my userid in the select of the reply )
                            press code block button
                            I just did this and got
                            @louise
                            			module: "clock",
                            L 2 Replies Last reply
                            • L
                              louise @sdetweil
                              @sdetweil Would it be easier if I just started over?
                                sdetweil @louise
                                with what? ignore what is above
                                • L
                                  louise @sdetweil
                                  @sdetweil Just a new install of Magic Mirror, rename this as MagicMirror1 and do a new install.
                                    sdetweil @louise
                                    @louise no… u havent hurt anything… we can get back the changed files easy
                                    the design makes it so we can change the code whenever we need to (we own it) and your implementation is not impacted, and you also aren’t blocked from getting the quarterly updates (next one coming Jan 1) …
                                    if you think it would be easier for you, then sure ,rename the folder, use my script to install again
                                    and then migrate your source file changes to config.js
                                    but u can migrate the changes now, no harm …
                                    • L
                                      louise @sdetweil
                                      deleted
                                        sdetweil @louise
                                        module: “clock”,
                                        position: “top_left”
                                        still didnt’ get the select all
                                        and this is the only part we needed
                                        module: “clock”,
                                        it has no config:{} section, so all the module defaults are used
                                        to change some setting here do
                                        module: “clock”,
                                        position: “top_left”,     // <-  add a comma (more stuff follows this line)
                                        config : {
                                             timeFormat:24,
                                        in the setting above clock will use 24 hour format, even if the base is set to 12 hour format
                                        • L
                                          louise @sdetweil
                                          @sdetweil Given a choice I would rather just have this figured out. Did I do right this time?
                                            sdetweil @louise
                                            @louise no
