    Clock format
    41 Posts 2 Posters 25.2k Views 2 Watching
    • L Offline
      louise @sdetweil
      deleted
        sdetweil @louise
        @louise said in Clock format:
        module: “clock”,
        position: “top_left”
        still didnt’ get the select all
        and this is the only part we needed
        module: “clock”,
        it has no config:{} section, so all the module defaults are used
        to change some setting here do
        module: “clock”,
        position: “top_left”,     // <-  add a comma (more stuff follows this line)
        config : {
             timeFormat:24,
        in the setting above clock will use 24 hour format, even if the base is set to 12 hour format
        • L Offline
          louise @sdetweil
          @sdetweil Given a choice I would rather just have this figured out. Did I do right this time?
            sdetweil @louise
            @louise no
            • L Offline
              louise @sdetweil
              @sdetweil frustrated yet?
              It is my config.js
              I know it says sample on top but it didn’t mess with any of that. I added in the disabled the compliment and newsfeed like u said so that worked.
              I don’t understand apparently.
                sdetweil @louise
                @louise here
                https://forum.magicmirror.builders/topic/15954/clock-format/18?_=1638300432581
                the part of config.js is right, but the code block is wrong… and its doubled for some reason
                when we ask for a module config, we don’t want the WHOLE config.js…
                (also, there are private things in there, api keys, maybe passwords, … )
                so we want as small as possible focused on A module usually
                • L Offline
                  louise @sdetweil
                  @sdetweil So you are saying I should I this under the the area it says clock module?
                  config : {
                  timeFormat:24,
                    sdetweil @louise
                    @louise ONLY IF you want to control it separately from (and have it different then ) the base MagicMirror setting
                    • L Offline
                      louise @sdetweil
                      @sdetweil I tried to put the code you had in my config but still 24 hr clock.
                        sdetweil @louise
                        @louise the config setting I had above said 24 hour format, not 12
                        • L Offline
                          louise @sdetweil
                          @sdetweil Actually tried it both ways, but neither worked.
                          Did you say I had something duplicated?
                            sdetweil @louise
                            @louise in the post I linked u had 2 copies of the config.js content
                              @sdetweil I wonder
                              are u using pm2 to launch mm?
                              do
                              pm2 status
                              if so do pm2 stop all
                              I think u are getting the default cause there was an error
                              • L Offline
                                louise @sdetweil
                                @sdetweil ok, did that. Just restart now?
                                  sdetweil @louise
                                  @louise lets check to make sure nothing is stuck
                                  do
                                  ps -ef | grep MagicMirror
                                  should return 1 line of output
                                  • L Offline
                                    louise @sdetweil
                                    @sdetweil pi 1390 1361 0 18:33 pets/0. 00:00:00 grep — color=auto MagicMirror
                                      sdetweil @louise
                                      @louise ok, NOW we can
                                      pm2 start 0
                                      • L Offline
                                        louise @sdetweil
                                        @sdetweil restarted, still 24 clock
                                        • 2 / 3
