    Clock format
    41 Posts 2 Posters 26.2k Views 2 Watching
    • L
      louise @sdetweil
      @sdetweil Given a choice I would rather just have this figured out. Did I do right this time?
        sdetweil @louise
        @louise no
        L 1 Reply Last reply
        • L
          louise @sdetweil
          @sdetweil frustrated yet?
          It is my config.js
          I know it says sample on top but it didn’t mess with any of that. I added in the disabled the compliment and newsfeed like u said so that worked.
          I don’t understand apparently.
            sdetweil @louise
            @louise here
            https://forum.magicmirror.builders/topic/15954/clock-format/18?_=1638300432581
            the part of config.js is right, but the code block is wrong… and its doubled for some reason
            when we ask for a module config, we don’t want the WHOLE config.js…
            (also, there are private things in there, api keys, maybe passwords, … )
            so we want as small as possible focused on A module usually
            • L
              louise @sdetweil
              @sdetweil So you are saying I should I this under the the area it says clock module?
              config : {
              timeFormat:24,
                sdetweil @louise
                @louise ONLY IF you want to control it separately from (and have it different then ) the base MagicMirror setting
                • L
                  louise @sdetweil
                  @sdetweil I tried to put the code you had in my config but still 24 hr clock.
                    sdetweil @louise
                    @louise the config setting I had above said 24 hour format, not 12
                    • L
                      louise @sdetweil
                      @sdetweil Actually tried it both ways, but neither worked.
                      Did you say I had something duplicated?
                        sdetweil @louise
                        @louise in the post I linked u had 2 copies of the config.js content
                          @sdetweil I wonder
                          are u using pm2 to launch mm?
                          do
                          pm2 status
                          if so do pm2 stop all
                          I think u are getting the default cause there was an error
                          • L
                            louise @sdetweil
                            @sdetweil ok, did that. Just restart now?
                              sdetweil @louise
                              @louise lets check to make sure nothing is stuck
                              do
                              ps -ef | grep MagicMirror
                              should return 1 line of output
                              • L
                                louise @sdetweil
                                @sdetweil pi 1390 1361 0 18:33 pets/0. 00:00:00 grep — color=auto MagicMirror
                                  sdetweil @louise
                                  @louise ok, NOW we can
                                  pm2 start 0
                                  • L
                                    louise @sdetweil
                                    @sdetweil restarted, still 24 clock
                                    • 2 / 3
